04-23-2008, 20:25 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: In My Dreams
Member: 210304 Status: Offline Sonork: 100.1573283 Thanks Meter: 1,455 | ::Here How To Work With Spider-Man Box :: Here Only You Can Find How To Use Spider-Man Box 1-The Connect button which use for connect box with program If connection Is Good this button will be Disconnect 2-Select Comport which u can use 3-Select Baundrate For Comport 4-Used For Make Conaction With Phone ((Boot The Phone)) 5-Used For Make Order To write selected Flash Files on Nor Flash Or Nand Flash 6-Used For Make Order To Read Flash Files Form Phone And Request for where u want to save backup flash files 7- Used For Make Format Opration and if u check to Manual Format Default this option is required to Make Manual Set For Foramt Area 8-Used For Unlock Phones ((open all network locks )) 9-Used For Find Pinout For Phone and give us Correct Tx And RX Pins (( We Can choose From 2 Options 1St, 1 Cpu Phones - 2Nd, 2Cpu Phones )) 10- We Can Used This Option to Defind Pinouts and Save Our Correct pinouts Searching 11-This Opation allowed us To Convert Flash Files which Had Bin Extension To Bif Extension 12-Used For Abort Any Working Opartion 13-Used TO Know Any New Updates In Support Area 14-This Bar allowed us To Change between Phone Cpu which We Have Like MTK And SPreadtrum ....... 15- here We Can Open Nor Flash which we Want To Flah it to phone 16- here we also can choose where we want to save reading flash files 17- Same as last oprations ((15-16)) But Here For Nor Flah Area 18- Used For Rebuild Iemi for Phone 19- Used For Make Full Factory Defaults 20- The Area For Read all Info About SW and Flash File Details Hope This Info Help U TO Work With This Great Tool |
The Following 87 Users Say Thank You to SiLver GSM For This Useful Post: |
04-23-2008, 20:40 | #2 (permalink) |
Member: 210304 Status: Offline Sonork: 100.1573283 Thanks Meter: 1,455 | Spiderman Read&Flash connect box to computer .connect phone to box and cable YOU Must choose MTK CPU.click”Search Phone”.when found cable pinout 1. Read flash * click”Save” Choose save file folder and save name * click"Read” after press” power on”button in the phone Bootloader phone Reading........ 2. Flash phone. * Click”Open” choose flash the phone flash file * Click”Flash” after press” power on”button in the phone Bootloader phone NOW Flash complete BR, SiLverGSM Last edited by SiLver GSM; 11-27-2008 at 18:56. |
The Following 83 Users Say Thank You to SiLver GSM For This Useful Post: |
04-29-2008, 08:48 | #10 (permalink) |
Freak Poster Join Date: Apr 2006 Location: india
Member: 254397 Status: Offline Thanks Meter: 224 | how i can format spreadtrum cpu very good sir but how i can format & read ,write flash for spreadtrum cpu ..::RICKY RAYYA::.. |
The Following 9 Users Say Thank You to .::ricky rayya::. For This Useful Post: |
04-29-2008, 17:47 | #12 (permalink) |
Freak Poster Join Date: Sep 2004 Location: U A E - Dubai Age: 41
Member: 80172 Status: Offline Sonork: 100.1575306 Thanks Meter: 82 | Great work from my dear brother Best Regards... Your Borther KimoAlex |
The Following 2 Users Say Thank You to -KimoAlex- For This Useful Post: |
04-29-2008, 20:47 | #15 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | and what r u doing for infeneon cpu, pls give fast update.... now badly need the support of speadtrum and infeneon cpu to unlock , flash read/ write .................... |
The Following 3 Users Say Thank You to sharmin For This Useful Post: |
How to calibrate china phone with spider man box | tamungas | Chinese Models & Cloned Phones | 1 | 01-11-2012 21:03 |
LG KG195 unlock sucess with spider man box | ..::My3gtech::.. | Chinese Models & Cloned Phones | 8 | 07-25-2011 09:15 |
karbonn k444 flashing with spider man box? | ramcellular | SpiderMan | 3 | 08-02-2010 09:50 |
How to work with 2-3 boxes simultaneously! | ProGsm2K7 | FuriousGold | 13 | 03-02-2010 22:41 |
I not know how to work with sagdd box . | mileta5 | SAGEM JTAG UNLOCKER | 8 | 02-20-2009 11:49 |
