01-14-2008, 06:00 | #46 (permalink) |
No Life Poster Join Date: Nov 2007 Location: china
Member: 637177 Status: Offline Sonork: 100.103098 Thanks Meter: 8,663 | hardware not same,the start address not same.so if your phone working. you can use unlock button in program 2.184beta version for your phone go factory defaults |
01-17-2008, 02:54 | #48 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Philippines
Member: 42604 Status: Offline Thanks Meter: 187 | Quote:
is the phone powering on when you try to boot? the phone should NOT power ON i supposed.. here's the trick.. when the soft says released the ON/OFF key..DON'T released it!! wait tell the progress bar is about 10 - 15% then release... it works on ZTC 868... try it.. | |
01-20-2008, 23:32 | #50 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 62
Member: 63042 Status: Offline Thanks Meter: 117 | Hi! I have here A CECT Q380 when you power it on it has an I phone icon on start up, also its a spreadtrum chip . First i used our 18 pins cable succesfully Cable define on MTK /Spreadtrum Tab but cannot make READ function work, second i also tried using Spreadtrum cable # 3 but seems not asking driver! And third i was able to located Rx/ Tx /Gnd which can be seen inside the PCB tried making proper connection on spiderman BOTH universal cable and Thru USB (usb not recognized) not working. Please tell us is this model supported and how should it done so we can have this connected? Thanks for replying........ |
01-21-2008, 11:48 | #51 (permalink) | |
Member: 637177 Status: Offline Sonork: 100.103098 Thanks Meter: 8,663 | Quote:
GND:12 17 18 RXD:11 TXD:13 | |
01-22-2008, 07:13 | #53 (permalink) |
Member: 63042 Status: Offline Thanks Meter: 117 | Sir i followed the above pinouts for a USB cable but no response! key up 18 17 . . . 13 12 11 . . . . . 5 . . . 1 18 17 12 -gnd 13 tx 11 rx 5 + Last edited by rakishi; 01-22-2008 at 07:22. |
01-25-2008, 21:05 | #55 (permalink) |
Freak Poster Join Date: May 2006
Member: 281925 Status: Offline Sonork: 100.113915 Thanks Meter: 63 | i have this phone and also have this problem it showing only i-phone logo and i found coract pinout keypad uper count left to right . . . . . 6-rx . 8-tx . . 17/18 grd also u find pinout back side on display now come to the point i try to connact with in$$ity box and $t box but phone not connacting if u find any solution pls post here bro Last edited by shripalkawdia; 01-25-2008 at 21:11. |
02-01-2008, 06:54 | #56 (permalink) |
Member: 274436 Status: Offline Thanks Meter: 26 | Hi. I have a problem with spiderbox software. when i start it and push the button "Connect" then software just close, no errors on display.(tested on 2 PC). Drivers and soft last ver. 2.186. But strange... on some PC in virtual machine box work perfect. what it's may be? if wondows problem or ....? pls. fix. and MTK_ResV1.2.exe don't run too. |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
