02-17-2009, 16:59 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: skyw0rk jombang
Member: 239081 Status: Offline Thanks Meter: 253 | problem in spiderman box... if box is conected in pc usb unknown device and i can't instal usb box driver... but in other brand pc,like ASUS MAINBORD & TOSIBA LAPTOP box is run normaly my serial number is :39xxx+usb pin finder i wes format windows & result is same... xp1 xp2 xp3 AND NEW XP, result is same i use intel pentium 4 506 socket 775 lga petiu 4 cpu 2.66 BUS SPEED manufacture PCCHIPS p53g bios america megatrend inc chipset : via p4m900 southbridge : via vt2837s sensor : winbond w83627dhg pc exspres memory ddr2 size 2088mb i use 7 cpu in same brend & same config mainbord in my problem & result is same... pc run normaly in Another toll MXKEY DONGLE hwk+UFS3 box INFINITY CPF2 BOX PADFIDER SETOOL3 CRUISER+UC20 BOX sory my gremer is bed i thing my mainbord not supported..but can i get solution |
The Following User Says Thank You to didin yulian For This Useful Post: |
02-18-2009, 21:13 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Riyadh, KSA Age: 43
Member: 894719 Status: Offline Sonork: 100.1580092 Thanks Meter: 905 | go to device manager and uninstall the usb drivers then reinstall them again good luck |
The Following User Says Thank You to gsm2start For This Useful Post: |
02-19-2009, 17:22 | #3 (permalink) |
Member: 239081 Status: Offline Thanks Meter: 253 | i wes try thet trick but is not work for me..ithink the problem is chipset on the mainbord manufacture PCCHIPS p53g bios america megatrend inc chipset : via p4m900 southbridge : via vt2837s sensor : winbond w83627dhg |
02-20-2009, 05:44 | #4 (permalink) |
No Life Poster Join Date: Nov 2007 Location: china
Member: 637177 Status: Offline Sonork: 100.103098 Thanks Meter: 8,663 | change the usb cable for check it,maybe computer no have enough power usb cable not too long. original spiderman usb cable have two usb port for connect pc usb port. |
The Following User Says Thank You to jack-china For This Useful Post: |
02-21-2009, 19:55 | #5 (permalink) |
Member: 239081 Status: Offline Thanks Meter: 253 | my usb power is 5.03-5.09v and cable is 40cm i use ufs3=hwk infinity cpf2 cruiser+setool mxkey other tool is can run normaly in my configuration computer my spiderman box is run normaly in other computer heve chipset intel or sis but box will showing unknown usb if my spiderman box plug in on my pc configuration..ithink if this problem usual i wil not report my case in this forum ilike spiderman box..this box is very simple&very esy to make a mony ..but unfortunuly i can use it on my computer.. i buy spiderman box on febuary 10 2009..in scp indonesia,.but now imust bay new computer couse my spiderman dont work in my via chipset..thenks jek cina for answer..ihope soon ican gat good news..spiderman box is very greet.. |
02-21-2009, 23:30 | #6 (permalink) | |
Member: 894719 Status: Offline Sonork: 100.1580092 Thanks Meter: 905 | Quote:
its drivers fault try to reinstall the box drivers, | |
02-22-2009, 14:36 | #7 (permalink) |
Member: 239081 Status: Offline Thanks Meter: 253 | i wes instal box driver..and iwes format & instal drive c:windows xp, xp1 xp2 xp3 but problem stil same...if i plug spiderman box on my computer via chipset,result is unknown device not spiderman box usb..on here steep i wes succes instal but may steep is usles couse usb is unknown.. but if i conec in intel chipset device is result spiderman-box-usb_2007 & my spiderman box can run normaly..i think spiderman box team must buy mainbord for test my problem..couse iwes try on 7via configuration in my post computer & report is same.. i use intel pentium 4 506 socket 775 lga petiu 4 cpu 2.66 BUS SPEED manufacture PCCHIPS p53g bios america megatrend inc chipset : via p4m900 southbridge : via vt2837s sensor : winbond w83627dhg |
What's next model you are looking for update in Spiderman BoX ??? | bhama_shah | SpiderMan | 9 | 01-08-2011 07:04 |
ALAFATEL H5A is not supporting in spiderman box please add | azad4u | SpiderMan | 3 | 01-11-2010 04:32 |
How to format D66 anycool in spiderman box? | Mecaniko | Chinese Cocktail | 1 | 04-19-2009 11:20 |
big problem in spiderman box | mogrem.soft | SpiderMan | 6 | 12-13-2008 16:32 |
master help amycool chinese phone cannot boot in spiderman box | dhie2424 | SpiderMan | 2 | 10-25-2008 07:11 |
