SIGMATEL S88 showing "NOT CALIBRATED" need help(Answered) Hello to all. Today I got a SIGMATEL S88 dead, After format set switch on but showing "NOT CALIBRATED" .Isthere any one who has eprom file for this set for Spiderman. It is urgent. |
Try to full flash d set with this Tested Ok File..... N.B:- Before Flash make backup... Sigmtel S88.bin |
Thanks for the file. File is working, but same problem. Any other solution |
"NOT CALIBRATED" is it screentouch problem or other If it's screentouch problem try to repair by press "screentouch caliber".... WBR..... |
try this 1) format in spiderman 2) change baudrate to lower 3) click touch screen caliberation in spider man ur set will be ok |
Thanks to all for help me. I have tryed all possible ways. touch screen caliberation does not solv this problem, only good vn file can help me . If you have any please post . |
Hello, 1 Read flash 2 Format Phone. 3 Repair Touch Celebration If Not Solve Then Must Check Hardware. B,R. ;) |
I ALREADY DONE ALL THE POSSIBLE WAYS. THIS IS NOT HEARDWARE FAULT , FAULT IS COMMING FROM NVFILE/EPROM FILE. INFINITY GIVES THOSE KINDS OF FAULTS SOLUTION THEN WHY NOT "SPIDERMAN" CHECK LINK http://forum.gsmhosting.com/vbb/5604699-post1.html |
Contact Me On Sonork. B,R. ;) |
I don't have " Sonork " . Can I connect you with yahoo ! Please provide me your yahoo id |
