Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan
Old 11-30-2008, 21:39   #1 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
*spider-man flash files and pinouts "request here"*
dear friends,
in order to make it easier to find your
needed flash files or pinout .
please post here your request
but kindly read this post first before you ask for
somthing.
http://forum.gsmhosting.com/vbb/showthread.php?t=632072
thank you
...........shehab.........
The Following 109 Users Say Thank You to gsm2start For This Useful Post:
Old 12-02-2008, 06:42   #2 (permalink)
Member: 289011
sssir i want sigmatel s4 pinouts verrrrrrrrrrrrrrrrrrrrrrrrrrrrrrry urgent pls
The Following 6 Users Say Thank You to punithan For This Useful Post:
Old 12-02-2008, 13:14   #3 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
this phone pinouts are marked on the main board
open it and check
good luck
................shehab..................
The Following 9 Users Say Thank You to gsm2start For This Useful Post:
Old 12-03-2008, 06:09   #4 (permalink)
Member: 289011
open it and check
good luck
Thanks..................
Punithan
The Following 2 Users Say Thank You to punithan For This Useful Post:
Old 12-03-2008, 08:43   #5 (permalink)
meisam's Avatar
Member: 115172
I need ZTC A823 pinout plz,it's standing phone.
The Following 4 Users Say Thank You to meisam For This Useful Post:
Old 12-03-2008, 12:19   #6 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
what is the connector type
and send pic of the phone if possible
thank you...........
...................shehab..................
The Following 3 Users Say Thank You to gsm2start For This Useful Post:
Old 12-03-2008, 14:11   #7 (permalink)
Member: 159105
n99i
i need this flash files in support i find only mtk 6226
Timer: _2008_12_3_13_47_40>> Press ON/OFF key please
Timer: _2008_12_3_13_47_40>> [INFO] Keep press before done (must)!!!
Timer: _2008_12_3_13_47_40>> [MEAT] ConnectWithTarget ...
success!Timer: _2008_12_3_13_47_46>> [INFO] bbchip_hw_code:6225
Timer: _2008_12_3_13_47_46>> [INFO] bbchip_hw_ver:8A03
Timer: _2008_12_3_13_47_46>> [INFO] bbchip_hw_name:
MT6225_S00Timer: _2008_12_3_13_47_46>> [META] Reset NVRAM to factory default setting ...
Timer: _2008_12_3_13_47_49>> [META] phone_key:1122
Timer: _2008_12_3_13_47_49>> [META] Exit the META mode
Timer: _2008_12_3_13_47_49>> [MTK] Close COM21 success!
Timer: _2008_12_3_13_47_54>> [MTK] Open COM21 success!
Timer: _2008_12_3_13_47_54>> Press ON/OFF key please...
Timer: _2008_12_3_13_47_56>> Target's hw_ver :0x8A03
Timer: _2008_12_3_13_47_56>> Target's hw_code :0x6225
Timer: _2008_12_3_13_47_56>> Target's sw_ver :0x8A00
Timer: _2008_12_3_13_47_56>> Target's CPU UID :00065603
Timer: _2008_12_3_13_47_58>> Get correct bootloader for target...
Timer: _2008_12_3_13_47_58>> MTK_AllInOne_DA_v3.0808.00.00
Timer: _2008_12_3_13_47_58>> You can relase ON/OFF key!
Timer: _2008_12_3_13_47_58>> [DA] loading the 1st bootloader...
SuccessTimer: _2008_12_3_13_48_6>> [DA] loading the 2nd bootloader...
SuccessTimer: _2008_12_3_13_48_19>> [BROM] start to test UART link...
Timer: _2008_12_3_13_48_19>> Waiting the bootloader initilize...
Timer: _2008_12_3_13_48_24>> [COM] Success to set baudrate!
Timer: _2008_12_3_13_48_24>> [DA] Bootloader running now,OK
Timer: _2008_12_3_13_48_24>> [DA] Project ID:
E880_XZY1DMCF13.01.2Timer: _2008_12_3_13_48_24>> [DA] Auto Format Info:
Timer: _2008_12_3_13_48_24>> [DA] StartBaseAddr[0xE00000] size[0x1FF000]
Timer: _2008_12_3_13_48_24>> [DA] ROM version:
MTK_ROMINFO_v04Timer: _2008_12_3_13_48_24>> [DA] BIN File:
E880_XZY1DMCF13_E880_GPRS_MT6225_S00.01_2.BINTimer : _2008_12_3_13_48_24>> [MTK] Close COM21
The Following 9 Users Say Thank You to elgato For This Useful Post:
Old 12-03-2008, 17:38   #8 (permalink)
Member: 889383
sir, i have ztc c2000. i can't found these pin out and flash file.
thanks before
The Following User Says Thank You to dj_funky For This Useful Post:
Old 12-03-2008, 20:54   #9 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
try this one and please inform me the result
http://rapidshare.com/files/16996057...2.BIN.bin.html
good luck
The Following 4 Users Say Thank You to gsm2start For This Useful Post:
Old 12-04-2008, 02:06   #10 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
thanks before
here it flash file of c2000
http://rapidshare.com/files/170033298/c2000.rar.html
regards
......................shehab...................... ...
The Following 5 Users Say Thank You to gsm2start For This Useful Post:
Old 12-04-2008, 11:46   #11 (permalink)
Member: 162536
Daxian x780 flash file
I urgently need DAXIAN X780 FLASH FILE.
Thanks.
rangeric
Old 12-04-2008, 12:41   #12 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
Thanks.
rangeric
will you please post the name of the flash file and as much info as possible
about this phone
thank you
Old 12-06-2008, 14:00   #13 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Rominfo_boway25_gemini_pcb01_gprs_mt6225_s00.s4_to shiba_etfihap_v030.bin
sigmatel s4 ...itried all version idont found this verssion....if iam flashing similar file...set....is mirror screen
The Following User Says Thank You to akhil_bbsr For This Useful Post:
Old 12-06-2008, 16:23   #14 (permalink)
az cells's Avatar
Member: 115516
need flash file Bluetooth C003 "E553_Y7ARTF3_E553_GPRS_MT6226_S01.V22_01_1"
The Following User Says Thank You to az cells For This Useful Post:
Old 12-06-2008, 17:31   #15 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
try this one
http://rapidshare.com/files/170863745/S4_sigmatel_6225_Flas_samsung.rar.html
please confirm with result
good luck
BR,
The Following 7 Users Say Thank You to gsm2start For This Useful Post:
All mobiles flash files and pm file and all china pinout and all hardwere solution RIZWANJAT Nokia Hardware & Hardware-Repair Area 4 10-01-2010 10:59
Tracvision flash file and pinout plz az_liton Chinese Miracle & PinFinder 14 10-30-2008 23:44
Spider Man BOX file flash GSMONNITIN SpiderMan 7 09-14-2008 16:40
need c2000 flash file and pinout nader06 Chinese Models & Cloned Phones 2 08-10-2008 03:43
How about Chinese dual Simcard phones flash files and pinouts? polifon Chinese Miracle & PinFinder 7 11-10-2007 17:49
Page generated in 4.86327 seconds with 12 queries
