Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan
Old 02-01-2012, 22:08   #1 (permalink)
Member: 1717169
spiderman box drivers restart pc
i have a spiderman box and I can't install spaiderman v3.0, the pc restart when SPIDER_BOX_2007 it was installed...pls help me
The Following User Says Thank You to manuelorl87 For This Useful Post:
Old 02-02-2012, 04:33   #2 (permalink)
Member: 1400209
Sonork: 1980252378
there is a bug in spiderman 3.02 bro.just format ur pc then install sspiderman v3.0 only or v 2.7/.... it works perfect........
hope this metod will help you
Old 02-02-2012, 14:13   #3 (permalink)
ch mobiles's Avatar
Member: 748029
Sonork: 100.1603742
Remove All Drivers Related Spidemran.Install Again.I Suggest You To Use Version 2.70.It Will Work For Noraml Pc.Ver 3.0 & 3.2 Are Working On Duel Processors System.
B,R.
The Following User Says Thank You to ch mobiles For This Useful Post:
Old 02-02-2012, 14:38   #4 (permalink)
Member: 1717169
I try it both ways but I got the same result ... any other suggestion .....thanks a lot
Old 02-02-2012, 15:03   #5 (permalink)
ch mobiles's Avatar
Member: 748029
Sonork: 100.1603742
First Of All ,Remove All Drivers Then Install Drivers Go To Device Manager & install spiderman Drivers After That Open Spidemran Exe & Clcik At Bottom Driver Install.
All Will Be Ok If Problem Remain Contact Me Via Sonork.
B,R.
Old 02-02-2012, 15:22   #6 (permalink)
Member: 1717169
when spider-box-usb 2007 is installed restart the pc
Old 02-02-2012, 15:29   #7 (permalink)
ch mobiles's Avatar
Member: 748029
Sonork: 100.1603742
Did You Removed All Drivers Related Spiderman Before Installing New ??
B,R.
Old 02-02-2012, 15:37   #8 (permalink)
mounir0020's Avatar
Member: 512970
Sonork: 100.1584185
Hi update ur driver
- uninstall
- install new
If not solved ur pb
Can chsnge windaows to sp3
Old 02-02-2012, 20:18   #9 (permalink)
Member: 1717169
B,R.
before installing new I removed all drivers related spiderman
Old 02-02-2012, 20:21   #10 (permalink)
Member: 1717169
Originally Posted by mounir0020 View Post
Hi update ur driver
- uninstall
- install new
If not solved ur pb
I tray to install in sp2 and sp3...the same problem....thanks....another suggestion
Old 02-03-2012, 07:54   #11 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
B,R.
bro. i will be like to see you on mastertools as a product supporter, as now spiderman is a dead project...............
DES key Driver black Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-19-2012 05:32
FLASH BOX WANTED!!!!!! J Wanted Products 9 07-14-2012 20:42
i WANT TO BUY NOKIA BOX !!! Eric Wanted Products 8 02-14-2011 12:23
Need Wintesla6,3 DLL Drivers for 6150 whit crack please helpme Nikki Nikki Sixx Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-08-1999 10:41
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-28-1999 14:56
Page generated in 0.38085 seconds with 11 queries
