12-29-2009, 12:14 | #1 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1176197 Status: Offline Thanks Meter: 0 | Spiderman connection problem This is the message I get if I try to read out the flash memory of a CECT i9 3G (or any other phone): >> [MTK] Open COM5 success! >> Press On/Off key please... (I press it and keep it pressed) >> [BROM] Cannot pass bootrom start command! >> Possibly target power up too early. >> [MTK] Close COM5 success! Note that exactly the same happens, with the exact same messages, if no phone is connected to the tool at all... Do you have an idea what the problem might be? The box behaves as if it did not see the phone I connect to it at all (whichever phone type I try the result is the same). Maybe a cable problem? Thanks! |
12-30-2009, 00:07 | #2 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Cardenas. Matanzas. Cuba
Member: 323671 Status: Offline Thanks Meter: 51 | Hello. Brother I have the same problem and not the cables because I have tested the three ports. If anyone knows of the solution, please postee it. Salu2 |
spiderman box problem ......... | gsm alok | SpiderMan | 5 | 03-17-2010 13:40 |
spiderman box problem pls. help | razib143 | SpiderMan | 2 | 12-08-2009 23:55 |
spiderman big problem...from 5......serece sereal no.... | Wasim007 | SpiderMan | 6 | 06-23-2009 08:11 |
plz help.spiderman format problem | graceful2 | SpiderMan | 1 | 02-15-2009 02:57 |
L6 not connected problem, is it a USB Driver problem? | astra12 | Motorola P2k | 0 | 11-15-2006 15:59 |
