Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SpiderMan
Old 06-19-2011, 04:18   #31 (permalink)
Member: 1014586
Thanks Meter: 16
yes..
when i install 3.0 test2 system hangs mostly, if it works then very slow but old 2.70 works perfect.
need. any solution pls
The Following 3 Users Say Thank You to pakalio For This Useful Post:
Old 06-19-2011, 04:21   #32 (permalink)
Member: 440401
Thanks Meter: 14
nice update atlast......good job bro....
Old 06-19-2011, 05:09   #33 (permalink)
shybet's Avatar
Member: 492380
Thanks Meter: 184
Originally Posted by pakalio View Post
yes..
Try to disable your antivirus, or add spiderman to your antivirus exclusion list.
The Following User Says Thank You to shybet For This Useful Post:
Old 06-19-2011, 08:04   #34 (permalink)
Member: 750874
Thanks Meter: 20
Antivirus is disable but no solution
Old 06-19-2011, 08:43   #35 (permalink)
^^^JUMPER^^^'s Avatar
Member: 1513644
Thanks Meter: 51
Jack is back , test ver working fine touch calibration operation is improved .
Tested on Micromax Gravity .
regards
jumper
Old 06-19-2011, 09:21   #36 (permalink)
Member: 236743
Thanks Meter: 113
SPREADRUM CPU usb not recognize
[QUOTE=ch mobiles;7442004]This Is Just Driver Problem.
Chk USB Drivers.
B,R. [/QUOT
no this is spidermanbox hardware problem .
Old 06-19-2011, 09:26   #37 (permalink)
ch mobiles's Avatar
Member: 748029
Sonork: 100.1603742
Thanks Meter: 1,822
Originally Posted by ton1x View Post
my laptop restart when install this update. it restart when install "spider.sys"
pls help...
Restore Your System & Install Drivers Again.
B,R.
The Following User Says Thank You to ch mobiles For This Useful Post:
Old 06-19-2011, 12:02   #38 (permalink)
ton1x's Avatar
Member: 258858
Thanks Meter: 96
B,R.
i did, but same result, laptop restart.
spiderman 2.70 works perfect. please fix it.
Br,
-SERAF CELL-
The Following User Says Thank You to ton1x For This Useful Post:
Old 06-19-2011, 15:03   #39 (permalink)
ch mobiles's Avatar
Member: 748029
Sonork: 100.1603742
Thanks Meter: 1,822
Br,
-SERAF CELL-
Go To System Properties > Device Manager.
Uninstall Yellow Components In Ports & Universal Serial Bus.
Install Spiderman Drivers.All Will Be Ok.
B,R.
Old 06-19-2011, 20:14   #40 (permalink)
mogrem.soft's Avatar
Member: 914426
Sonork: 01017474627
Thanks Meter: 235
Thanks Mr Jack,We Waiting More....................
Old 06-20-2011, 02:30   #41 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
Spiderman Box, still on Test mode Guys, please be patience, new features are going to be release
This test mode are very important because, spiderman is going to be a more Stronger Box, so please put here all bugs you find on program...
Old 06-20-2011, 11:22   #42 (permalink)
Member: 637177
Sonork: 100.103098
Thanks Meter: 8,663
Originally Posted by xiaoyud View Post
Don't support LG KF510 Read Flash~~~
Timer: _2011_6_18_14_34_4>> [LG] Open COM3 success!
Timer: _2011_6_18_14_34_4>> Connect phone and press Power ON!
Timer: _2011_6_18_14_34_9>> Sending PreBoot...
Timer: _2011_6_18_14_34_10>> PreBoot running success!
Timer: _2011_6_18_14_34_10>> Sending Main Boot...
Timer: _2011_6_18_14_34_23>> Main Boot running success!
Timer: _2011_6_18_14_34_24>> FlashDevCode1:0x0000
Timer: _2011_6_18_14_34_24>> FlashDevCode2:0x0000
Timer: _2011_6_18_14_34_24>> NAND flash found: unknow type!
Timer: _2011_6_18_14_34_24>> Boot running ok!
Timer: _2011_6_18_14_34_32>> Read commport fail!---LG_INF1
Timer: _2011_6_18_14_34_32>> Send certificate fail!
Timer: _2011_6_18_14_34_32>> [LG] Close COM3 success!
i have test one phone it is ok. will check another phone.
Old 06-20-2011, 12:07   #43 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
Originally Posted by jack-china View Post
This also need box hardware update. check update this funtion .wait to finish.
Button "Online_Update_Box" not active, what may be?
Old 06-20-2011, 12:12   #44 (permalink)
Danish Shafiq's Avatar
Member: 1118710
Sonork: 100.1604414
Thanks Meter: 4,970
No Need Update Spider Man Box u can use latest version of spider man without Updating ur box..
The Following User Says Thank You to Danish Shafiq For This Useful Post:
Old 06-20-2011, 12:21   #45 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
jack-china write "This also need box hardware update. check update this funtion .wait to finish."
for finding pinout MStar
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
winlock 1.0 Aldrin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 01-25-2000 04:49
Universal SP Unlocker 4.0 - home page !!! bp.bonus GSM Mobile Links 0 01-22-2000 22:31
download Datasuite 3.0 zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 10-31-1999 01:35
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 15:48
Page generated in 0.30996 seconds with 11 queries
