Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AdvanceUFS
Old 05-25-2008, 20:20   #1 (permalink)
Member: 498524
5500 unlocking Advance box
Can anybody please help here and tell me what the problem are. Why does this phone not do the unlock. Very new with Advance box
Thanx
> MCU Sw : V 03.55 23-11-06 RM-86 (c) Nokia.
> IMEI : 351855017
> SP Version: SIMLOCK SERVER VERSION 63
> SP_F : 8000000000000000
> SP_P : 2343300000000000
> Provider : Orange;United Kingdom
> Counters : 0/3 , 9/10
> SP Lock Status : Locked
> Auto PM-308 Backup.......
> IMEI : 351855017809866
> Backup Already Created......
> Preparing To Unlock Phone
> No. of Unlock Trigger >>>> : 1
> Unlock Trigger set to : 1
> Unlock Try No. : 1
> Buffer size changed to 04 bytes ....
> Sending Unlock Trigger 1/4
> Sending Unlock Trigger 2/4
> Sending Unlock Trigger 3/4
> Sending Unlock Trigger 4/4
> Initializing TP...
>>>> Please connect TP........
> TP CONNECTED
> Unlocking
> Waiting for phone....
> Sending PSW......
> #PW+0123345678901234+7#
> SP Version:
> Unable to read SP Data..
> Try Failed..
> Unlock Try No. : 2
> Initializing TP...
> TP CONNECTED
> Unlocking
> Aborted . . . .
> Try Failed..
> Process Aborted
Old 05-31-2008, 15:53   #2 (permalink)
Advance-Box's Avatar
Member: 651945
@Warptech
Hi, use shorter POP Cable if possible because the one that came with
AdvanceBox package is sometimes too long for 3110, 3109c and 5500 phones.
Next thing is to check your TP Connection because on your LOGS:
This means that the connection is not stable and so the phone hangs and hangs
by giving you "Waiting for phone...." message. Only push the TP Pins halfway
and do not put too much force on the TP on the phone's PCB
Also, do not click the Abort Button because the you must let the software
go into Learning Mode just in case it cannot unlock it with the Direct Unlock (TP).
SO never click abort and wait for it to completely finish the procedure.
Check this link:
Big Bomb For Today 5500 Unlocked
This is the same version as your 5500 unlocked few months ago.
So assuming that you are following the correct TP for the 5500, you will
definitely unlock your phone.
B.R.
X-Shadow
Old 05-31-2008, 16:06   #3 (permalink)
Member: 498524
Thanx I will try everything you said and post the results
Thanx a lot
Old 05-31-2008, 17:56   #4 (permalink)
Member: 651945
@Warptech
You can also try the USB connection for the phone in the new 2.16 AdvanceBox
Software. It only works with old USB drivers for POP Cables so be sure not to
update your USB Drivers yet.
Also, don't forget to put the Black Alligator Clip near the RAP or Flash chip to you
could get ample grounding during unlocking.
B.R.
X-Shadow
Free Dct4++ Unlock,Advanced Box v2.13 Cracked ! jawad8305 UFS2 + UFS3-Tornadoflasher 0 05-01-2008 13:31
EMMA 2, DCT4 UNLOCK, Motorola P2K Advanced box,Uni BOX, etc BEST PRICES !! sixkiller666 Main Sales Section 0 07-29-2002 02:31
Page generated in 0.46599 seconds with 11 queries
