Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AdvanceUFS
Old 01-02-2008, 06:29   #1 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,064
Advance-Box Updates (AdvanceUFS and AdvanceBB5) V2.12 31--3-08
v1.15
>improved TP detection
>improved Phone detection
>added autocreate folder for LOGS, BACKUP, AUTOBACKUP, FULL PM and TP
>fixed some bugs
V1.14
>fixed hangup for some phones
>improved software performance
>enabled support for OTHER UFS firmware (2.7 + )
>improved autounlock trigger encryption
You can donwload it in our SUPPORT SITE
Best regards
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 01-06-2008, 10:06   #2 (permalink)
Member: 651945
v1.17
>added verification of bytes or size of backup
>enabled keypress to allow in learning mode
>other AD's enabled/activated to support some phone version
>added option to allow bypass automatic TP detection. (can be use for other phone if is too hard to detect TP)
>full factory reset fixed
>added selection for AD to be used.
>minor changes autounlock.ini
v1.16
>added READ FULL PM
>Added option for BAD IMEI
Best regards
note:
we will upload it later
Old 01-12-2008, 12:40   #3 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,256
v1.18
>>Auto update BB5.INI and Autounlock.ini (button only)
>>AdvanceUFS and AdvanceBB5 will use ONE software only..
>>added unlock triggers in BB5.INI and Autounlock.ini
>>added option to full factory reset
>>Personal ini added for your generated trigger from Learning Mode.
you can download in our SUPPORT SITE
Best Regards,
Old 01-14-2008, 16:02   #4 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,256
v1.19
>remove KP/FBUS option, software is now able to automate.
>save log corrected. (click event removed)
>updated unlock trigger (new phone/version added )
>added autoupdate for Advance Settings.ini
>added what’s new button
>support all version/chip for 5300/5300b/5200/5200b/6300/6300b/E61/E65/N73/N92/N77
>added new phone E61i
Download it in support site.
must press updates from time to time...
BTW, we already add 8600, 7373, 7370 and other phones in Autounlock.ini. You can unlock it using Learning Mode.
*for v1.18 error for AdvanceBB5 you need to put ufs2xx.dll is same directory.
Old 01-17-2008, 06:15   #5 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,256
AdvanceBox v2.00
January 17, 2008
>Update software and transfer server
>Improve online updates and with new exe notification after pressing what’s new button.
>Sounds added.
>Fix saving in Personal.ini triggers
>Added autounlock.ini for 8600 all versions
Download it in our support site.
Best regards,
ulymar
Old 01-17-2008, 17:57   #6 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,256
January 18, 2008
v2.01
>Update software
>Added option to on/off sound
>Added Filter in autounlock.ini
>Added trigger for RM-126 v4.25/4.28 pin 41(rap)
First in the World Support pin 41 TP.
Just press what's new button using v2.00 and download link will popup.
Best regards,
ulymar
Old 01-19-2008, 08:25   #7 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,256
January 19, 2008
v2.02
>update triggers autounlock.ini and bb5.ini
>Added Read/Write Product Profile
>Added Attempt option in autounlock.ini
>Fixed AD1 TP
Best Learning Mode settings
[Instance]
Try=16
Repetition=2
Jump=true
Filter=False
Attempt=3
Best regards and FEEL THE POWER of daily updates..
Old 01-25-2008, 15:01   #8 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,256
AdvanceBox Software Updates v2.03
January 25, 2008
>New software v2.03
>Write PM enabled
>Read Security code added
>Set to Default Security code added
>Improved Learning Mode Unlock
>Fix wav play
>Added new triggers
Just press What's new button.
Best Regards,
Advance-Box Team
The Following User Says Thank You to ulymar For This Useful Post:
Old 01-28-2008, 07:19   #9 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,256
AdvanceBox Updates v2.04
AdvanceBox v2.04
>Support No TP Unlock (Direct unlock without TP)for OLD BB5 (6630, 6680, 6681, N70, N90 and etc...).
>Improved software.
Note: Press update triggers, Advance settings.ini changed.
Best Regards,
ulymar
Old 02-11-2008, 11:14   #10 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,256
AdvanceBox v2.06
AdvanceBox v2.06
February 11, 2008
>New skinned software v2.06
>3/3, 10/10 Unlock supported for 6280 (v6.43) and N73 (4.0736.3.2.1)
Old 03-23-2008, 12:38   #11 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,256
March 23, 2008
>New software v2.11
>Changed gui
>Improved splock detection/reading
>Added phone for FBUS Counter Reset:
V 15.04 30-08-07 RM-188 (c) Nokia.
V 15.04 30-08-07 RM-260 (c) Nokia.
V 05.12 19-09-07 RM-216 (c) Nokia. (nfc)
V 05.43 30-03-07 RM-123 (c) Nokia spansion
V 05.43 30-03-07 RM-145 (c) Nokia spansion
V 05.50 14-08-07 RM-209 (c) Nokia.
>Added phone version supported checking
>Added Manual sending of PSW (keypress and fbus)
"JUST PRESS WHAT'S NEW BUTTON"
Best Regards,
ulymar
Old 03-30-2008, 17:35   #12 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,256
March 31, 2008
>Added TP Pictures (All phones)
>Added TAB for DCT4/+ (disabled) - UFS Interface (partial flashing supported)
>Enable Option for TELCEL UNLOCK (Need AdvanceBox TELCEL Adapter)
>Improve software
>Added button for FBUS Counter Reset supported phone
Press what's new button to download the latest software.
Best regards,
ulymar
The Following 2 Users Say Thank You to ulymar For This Useful Post:
Advance BOX update! it is TRUE or NOT? boy_muslim The Market Feed Back 122 02-11-2010 07:30
Advance box update is FREE for advance users.... .:GSM International:. Universalbox 30 11-16-2008 19:44
Advance-Box Updates V 2.16 Released- May 31, 2008 E90 Direct unlock via TP supported sharaz191 Service Products News & Updates 0 06-03-2008 09:04
Smart-Clip v3.08, S-Card v1.08 and SmartMoto v2.12 GSM_Support Smart-Clip 44 01-09-2007 03:21
3200 downgraded from 3.12 to 3.08,can turn on but no display Ran Nokia Digital Core Technology 4 ( DCT-4 ) 3 01-15-2004 11:46
Page generated in 0.44262 seconds with 8 queries
