02-14-2008, 01:15 | #3 (permalink) | |
Freak Poster Join Date: Sep 2006 Age: 44
Member: 344661 Status: Offline Thanks Meter: 3 | Quote:
And, when I click in AdvanceBox software, the leds rx and tx of Nbox blink, the rj45 1:1 cable is ok... Maybe a special software or driver? Any idea?.... | |
02-14-2008, 03:33 | #4 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | The RJ-45 1:1 cable should be connected to the RJ-45 slot that is marked "UFS" and not to the RJ-45 slot that is marked "TP Cable". Did you follow this? Does the RED LED of the AdvanceUFS light up??? Do you have any messenger where we can talk directly? B.R. X-Shadow |
02-14-2008, 07:32 | #5 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | bro Quote:
try to clean the inner portion of rj45 socket with ipa if still ur advance ufs red light not glow u have to talk to ur reseller thanks | |
02-15-2008, 15:37 | #7 (permalink) |
Member: 344661 Status: Offline Thanks Meter: 3 | If in some time have same problem.. I used the ufstool. With the option "write firmware", "write eeprom", "write 93c46" and the original sn click "Fix & Update".... And now my nbox works with AdvanceUFS.. |
i still not use it apple not found and license not found | ABDULLAHI MUHD | FuriousGold | 2 | 06-16-2009 12:57 |
Wht if code not found and ur server yield unknown not found status | unlock trigger | HTC CODE WORLDWIDE | 1 | 02-04-2009 01:51 |
device not found and the ****,s reseller cheaters not respond | SANTOGSM | SagMaster Team OLD Products | 11 | 10-01-2004 12:19 |
