Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AdvanceUFS
Old 12-22-2007, 06:45   #1 (permalink)
Fast Unlocking's Avatar
Member: 94675
Sonork: 100.8888 QQ3161545070
Thanks Meter: 97,265
Learning Mode Explained...
First of all, the AdvaceBB5 Stand-Alone Box still needs Test Points in order
to unlock the phone. This BOX is NOT FBUS UNLOCKING...
Now you may ask, "What makes this new BB5 TP Unlocker so SPECIAL????"
The answer is "Learning Mode..."
What is Learning Mode??? Please Read On,,,,
Learning Mode is the procedure when the AdvanceBB5 Box tries to figure
out the correct TP Triggers that it will use for unlocking the phone. This
procedure is semi-brute-force in Nature, but it is guaranteed that this
procedure will NEVER KILL any BB5 phone.
Usually with other BB5 Unlocker Boxes in the market, the Product
Supporters still need to buy TEST PHONES so that they can add more
phones in their support list. If the product suppporters cannot get test
phones, then they cannot add the support...
In the current market, there are more than 100 types of BB5 phones. Also,
let us not forget that each phone type might use a different Flash Chip
depending on the Location of the Factory it was manufactured in. Lastly,
each phone type may have atleast 5 different Firmware versions as well.
If you try to compute it, it is 100(phone types) x 4(flash chip type) x 5
(firmware versions) = 2,000 different phones out there!
It would be very very expensive for Product Supporters to support 2000
different phones by themselves, and so the team behind the AdvanceBB5
and AdvanceUFS project formulated an entirely different approach when it
came to supporting these 2,000 different phones. We no longer need test
phones! We made a Learning Mode Function inside the box so that the end-
user will be able to add new phones by himself and without ever sending us
a single Test Phone!
So basically Learning Mode enables the AdvanceBB5 Box to support more
phones without ever waiting for Product Supporters to update the
supported phone list... The END-USER of this BOX can MAKE THE SUPPORT
all by themselves...
B.R.
Please note that the Team Behind this project will still regulate the supported phones in
Learning Mode because careful anaylisis of the phone firmware still needs to be done prior
to declaring the phone fit for the Learning Mode.
Old 12-22-2007, 19:50   #2 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
What if soft don't reconize algorithm in phone and destroy phone , what are the risk of using advance ufs ???
And if this soft supose to support new hardware bb5 phones , then why in the list of supported phones are not present phones like n95 8gb , 6120 ...
Old 12-22-2007, 23:27   #3 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
Can u post here somme screen shots ??
Old 12-23-2007, 03:26   #4 (permalink)
Member: 94675
this software has been tested by me where even if u put the wrong test point it won t damage the phone. and there is no risk in using advance ufs what so even it is just an addon for ufs users.
br
Old 12-23-2007, 08:35   #5 (permalink)
Member: 438080
Thanks Meter: 55
wow... an easy to use bb5 unlocker...
Old 12-24-2007, 09:28   #6 (permalink)
Registered User
Member: 153549
Thanks Meter: 13
i wanna know if in learning mode, how you sure that we cannot kill the phone?. knowing that it is not yet support so we will experiment it in your box and software to unlock it..it is too risky that i, ' beginner' and little knowledge in unlocking will do a part to explore to unlock the phone...
Old 12-24-2007, 09:51   #7 (permalink)
Member: 656001
Thanks Meter: 4
man did you saw the supported models in support area all of them, i extracted it using learning mode .. KILLING PHONES!! are hardware and software side is very PROFESSIONAL and we will make our customers comfortable even in TESTPOINT were using AD0... and if you want to step up your skills do an experiment but DONT 4 GET FIRST AID "Practice Makes You Perfect"
REGARDS,
www.advance-box.com
Old 02-12-2008, 05:00   #8 (permalink)
Member: 654769
hi advance box good box , I've a qustion if the TP its estrictly how the show the picture . if I put TP by example in wrong point the microp
is there no risk....?
Old 02-12-2008, 08:03   #9 (permalink)
Member: 94675
hi, their shoudn t be any problems but make sure you don t damage the TP thats all.
br
Fast Unlocking
Feel The Power
BB5 Box with Auto Learning Mode BB5box.org BB5BOX 135 02-07-2008 18:26
V-Spec Learning MODE Linkz J.A.F. V-SPEC 9 01-08-2008 20:16
BB5 Box with Auto Learning Mode RRRRR MT-BOX 6 12-26-2007 20:08
Learning Mode supported models as of now Fast Unlocking AdvanceUFS 0 12-21-2007 23:00
Page generated in 0.20035 seconds with 9 queries
