06-24-2008, 17:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Moon Age: 43
Member: 55717 Status: Offline Thanks Meter: 47 | Advance UFS - unlock only 5200, 6085 and 6125 I only unlock 5200, 6125, 6085, and only. The support is defective, few explanations, few details for new users. However I believe the loyalty of the ADV Team with its customers, and still I wait improvements in the information. But until the moment, I continue disappointed, with broken telephones, had to force testpoint without getting no positive result. |
06-24-2008, 17:36 | #2 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 46
Member: 88996 Status: Offline Thanks Meter: 86 | friend i think u need this http://rapidshare.com/files/81936315...final.rar.html http://rapidshare.com/files/81912764...final.rar.html |
06-25-2008, 04:59 | #4 (permalink) |
Member: 55717 Status: Offline Thanks Meter: 47 | @ sunnyboy Thanks but I have it. Readed 100000 times! @ GhosT2RocK Thanks, but not help me. For me not work! Not work small TP, small cable, nothing work. Work only for PCB testpoint. Flash IC testpoint never work. Advance is a good device, but I dont have lucky with this box. BR. |
06-25-2008, 10:40 | #5 (permalink) |
Banned Join Date: May 2008 Location: inside AdvanceBB5
Member: 768923 Status: Offline Sonork: (",)(",)(",) Thanks Meter: 110 | @JoAoOpAuLo Try With this and better use version 2.15 not 2.17 http://rapidshare.com/files/12465551...ox_20v2.15.rar PS : CLK tp pin must be horizontal not vertical |
06-25-2008, 11:38 | #6 (permalink) |
Member: 768923 Status: Offline Sonork: (",)(",)(",) Thanks Meter: 110 | I'm not a 3D designer but i'm try to do the best to help you check this it's may help you ( i was like u i never succed to unlock all supported bb5 only 5300/5200/6300 ) |
07-03-2008, 08:34 | #7 (permalink) |
Member: 55717 Status: Offline Thanks Meter: 47 | @ GhosT2RocK Thanks for your help, but NOT work for me! Work only in PCB testpoint. Rap and Samsung BGA never!!!! I will buy another tool, maybe more luck in MT. BR. |
07-03-2008, 08:48 | #8 (permalink) |
Product Manager Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 47
Member: 343670 Status: Offline Sonork: N/A Thanks Meter: 572 | U r true.u have to connect those point untill it finish and also if u flash the phone before unlock its quick.I also faced that problem from my begining now its ok.Do not sparking the points when connicting tp.and first touch black tp then connect yellow and wait...........thats it |
07-03-2008, 09:04 | #9 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @JoAoOpAuLo Please show logs of failed unlocking attempt with N73... If your AdvanceBox can unlock 5200, 6085 and other TP-ON-PCB type of phones, then there should be NO reason why it cannot unlocke stacked RAP+Samsung TP phones. Main problem with stacked RAP+FLASH phones is that the TP is really difficult and may sometimes lead to a dead phone because of too much pressure on the CLK small BGA Ball. Another problem is the Static Problem on the AdvanceBox TP Pins which are very very sensitive especially when you are working near a n.aked florescent light. But, you should also keep in mind that all N73 phones are using the same flash chip all over the world. It is not like 6300 which have SEC-ATB, ATD, Spansion, 8mm, 10mm... All stacked RAP+FLASH phones have the same FLASH CHIP! So if someone from Timbuktu can unlock N73, then it means that anyone in the world can unlock that same firmware version because the triggers only change if the flash chip changes. Since the flash chip are all the same, then the triggers should be all the same for a specific firmware version. So maybe before you go out and spend $$$ on another box, try one more time and post the logs here so I can tell you what might be wrong with your setup. As of now, AdvanceBox supports 34 firmware versions of the N73... This is more than twice the number of versions other tp unlocking box supports as of the moment... B.R. X-Shadow |
07-03-2008, 09:24 | #10 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Phils
Member: 331390 Status: Offline Thanks Meter: 434 | Quote:
BTW, there's no LUCK on BB5 Unlocking.. check your skills. | |
07-04-2008, 15:57 | #11 (permalink) |
Member: 55717 Status: Offline Thanks Meter: 47 | @ Advance-Box See the log: MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 9/10 Lock info : SP Lock Status : Locked Auto PM-308 Backup....... MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 Backup Already Created...... SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Preparing To Unlock Phone No. of Unlock Trigger >>>> : 2 Unlock Trigger set to : 1 Unlock Try No. : 1 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... >>> Please connect TP.. TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 10/10 Lock info : SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 2 Unlock Try No. : 1 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# Waiting for phone.... Waiting for phone.... MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 10/10 Lock info : SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 1 Unlock Try No. : 2 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... >>> Please connect TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 1/3 , 10/10 Lock info : SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 2 Unlock Try No. : 2 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... >>> Please connect TP.. TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 2/3 , 10/10 Lock info : SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 1 Unlock Try No. : 3 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 3/3 , 10/10 Lock info : SP Lock Status : Locked Restoring splock data... please wait..... Restore Done!.... Rebooting Mobile... wait for a while... Reboot Done! SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Try Failed.. Unlock Trigger set to : 2 Unlock Try No. : 3 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... >>> Please connect TP..... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 10/10 Lock info : SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 1 Unlock Try No. : 4 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 1/3 , 10/10 Lock info : SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 2 Unlock Try No. : 4 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 2/3 , 10/10 Lock info : SP Lock Status : Locked Try Failed.. Unlock Trigger set to : 1 Unlock Try No. : 5 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 3/3 , 10/10 Lock info : SP Lock Status : Locked Restoring splock data... please wait..... Restore Done!.... Rebooting Mobile... wait for a while... Reboot Done! SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Try Failed.. Unlock Trigger set to : 2 Unlock Try No. : 5 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 10/10 Lock info : SP Lock Status : Locked Try Failed.. Direct Unlock Failed .. Different flash chip/TP Not connected properly.. Set to Learning Mode..... Checking Learning Mode Settings.. MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Auto PM-308 Backup....... MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 Backup Already Created...... TP Connection (AD Selected) : AD8 Decrypting ............ Preparing To Unlock Phone ......... Entering Learning Mode..... MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Attempt No. : 0:0:1 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 1/3 , 10/10 Lock info : SP Lock Status : Locked Sending Unlock Algorithm...... Sending Unlock Algorithm...... Sending Unlock Algorithm...... MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 1/3 , 10/10 Lock info : SP Lock Status : Locked Important SP Data Not Found .... Not valid instance.. MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Attempt No. : 1:0:1 Initializing TP... >>> Please connect TP............ TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 2/3 , 10/10 Lock info : SP Lock Status : Locked Sending Unlock Algorithm...... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... Waiting for phone... MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 2/3 , 10/10 Lock info : SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... >>> Please connect TP.................. TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 3/3 , 10/10 Lock info : SP Lock Status : Locked Restoring splock data... please wait..... Restore Done!.... Rebooting Mobile... wait for a while... Reboot Done! SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... >>> Please connect TP.. TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 1/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 2/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 3/3 , 10/10 Lock info : SP Lock Status : Locked Restoring splock data... please wait..... Restore Done!.... Rebooting Mobile... wait for a while... Reboot Done! SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Attempt No. : 1:0:2 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 1/3 , 10/10 Lock info : SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 1/3 , 10/10 Lock info : SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... >>> Please connect TP. TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 2/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 3/3 , 10/10 Lock info : SP Lock Status : Locked Restoring splock data... please wait..... Restore Done!.... Rebooting Mobile... wait for a while... Reboot Done! SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... >>> Please connect TP. TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 1/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... >>> Please connect TP............ TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 2/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 3/3 , 10/10 Lock info : SP Lock Status : Locked Restoring splock data... please wait..... Restore Done!.... Rebooting Mobile... wait for a while... Reboot Done! SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Failed to Unlock Attempt No. : 1:1:1 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 10/10 Lock info : SP Lock Status : Locked Sending Unlock Algorithm...... MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 10/10 Lock info : SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... >>> Please connect TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 1/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 2/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 3/3 , 10/10 Lock info : SP Lock Status : Locked Restoring splock data... please wait..... Restore Done!.... Rebooting Mobile... wait for a while... Reboot Done! SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 1/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 2/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Attempt No. : 1:1:2 Initializing TP... TP CONNECTED Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 3/3 , 10/10 Lock info : SP Lock Status : Locked Restoring splock data... please wait..... Restore Done!.... Rebooting Mobile... wait for a while... Reboot Done! SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Sending Unlock Algorithm...... Sending Unlock Algorithm...... Sending Unlock Algorithm...... Sending Unlock Algorithm...... Sending Unlock Algorithm...... Sending Unlock Algorithm...... Sending Unlock Algorithm...... Sending Unlock Algorithm...... Sending Unlock Algorithm...... MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 9/10 Lock info : SP Lock Status : Locked Important SP Data Found ..... Validating SP Data.... SP Data qualified for unlocking... Preparing To Unlock phone ... Initializing TP... >>> Please connect TP.. TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 1/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Waiting for phone.... Waiting for phone.... Waiting for phone.... Waiting for phone.... Waiting for phone.... Waiting for phone.... Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 2/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 3/3 , 10/10 Lock info : SP Lock Status : Locked Restoring splock data... please wait..... Restore Done!.... Rebooting Mobile... wait for a while... Reboot Done! Aborted . . . . SP_F : 0000000000000000 SP_P : 2040400000000000 Lock info : Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Unlocking Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05wk47v34.1 05-10-06 RM-133 (c) Nokia. IMEI : 355506019160750 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 0000000000000000 SP_P : 2040400000000000 Provider : Vodafone / Libertel;Netherlands Counters : 0/3 , 10/10 Lock info : SP Lock Status : Locked Failed to Unlock Preparing To Unlock phone ... Initializing TP... TP CONNECTED Aborted . . . . Unlocking Failed to Unlock Condictions: Slow light, anti-static protection for PCB, Box, hands, all. Testpoint by Sagmaster Team - 100% OK in digital microscope. BR. Last edited by JoAoOpAuLo; 07-04-2008 at 16:02. |
07-04-2008, 17:25 | #13 (permalink) |
Member: 55717 Status: Offline Thanks Meter: 47 | Simple 5200 in same condiction. MCU Sw : V 05.00 27-04-07 RM-181 (c) Nokia. IMEI : 359839013931488 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 7240600086388183 Provider : Unknown Provider Counters : 0/3 , 0/10 Lock info : SP Lock Status : Locked Auto PM-308 Backup....... MCU Sw : V 05.00 27-04-07 RM-181 (c) Nokia. IMEI : 359839013931488 Backup Already Created...... SP_F : 8000000000000000 SP_P : 7240600086388183 Lock info : Preparing To Unlock Phone No. of Unlock Trigger >>>> : 5 Unlock Trigger set to : 1 Unlock Try No. : 1 Buffer size changed to 04 bytes .... Sending Unlock Trigger 1/4 Sending Unlock Trigger 2/4 Sending Unlock Trigger 3/4 Sending Unlock Trigger 4/4 Initializing TP... >>> Please connect TP.... TP CONNECTED Unlocking Waiting for phone.... Sending PSW...... #PW+0123345678901234+7# MCU Sw : V 05.00 27-04-07 RM-181 (c) Nokia. IMEI : 359839013931488 SP Version: SIMLOCK SERVER VERSION 63 SP_F : 8000000000000000 SP_P : 7240600086388183 Provider : Unknown Provider Counters : 0/3 , 0/10 Lock info : SP Lock Status : Not Locked Unlocking successfull....... Process Done! .... |
please Advance-BB5 and Advance-UFS update unlock | gsm-world | AdvanceUFS | 1 | 11-04-2009 22:03 |
unlock nokia 5200,6085, 6126 etc, what unlock cables to use??? | wagnei | JAF No Tp Unlocker by Cinek | 2 | 05-06-2009 09:50 |
Micro UFS Advance UFS and UFS-3 | dil_PAKISTANI | UFS2 + UFS3-Tornadoflasher | 2 | 01-20-2009 20:02 |
Advance-bb5 & Advance-ufs Advanced Test Point Only Here | chiragp | AdvanceUFS | 29 | 10-09-2008 16:37 |
New Advance UFS UNLOCK BB5 SET | turkgsmteam | HWK | 16 | 12-29-2007 18:57 |
