Advanced ufs not found hi, i am new user of this box,i conected advance ufs but showing box not found.i used clone ufs3 and orginal usf3 .ple help me:eek: |
@indian Try To Uninsall Ur Drivers By Safe Mode Pc And Agian Try To Use Latest Ufs Drivers Hope U Solve Thanks |
Hi, Thanks for fast support but i tried that but not luck.still have same problem. |
@.::Indian::. are you sure that The RJ45 is connected besides of UCP? |
yes sir,i conected rj45 properly |
@.::Indian::. Your connection to the RJ-45 might be reversed. Check if the RED LED light up when you connect the AdvanceUFS to your UFS box. If the RED LED lights up, then your connections are ok... If the RED LED light up and your AdvanceUFS is still not detected, then the Problem is with your UFS box. Your UFS box should be fully functional and activated that is you can use it with old Sarasoft Programs. If your UFS is not fully functional, then the AdvanceBox software cannot talk to the AdvanceUFS Adapter. Try running old UFS softwares and see if your UFS is ok or not. B.R. X-Shadow |
sir,red light is ok,also my ufs3 is working with old sw( clone ufs3).ok i will check with new ufshwk slim . thx for fast support |
Ver. 2.14 Quote:
ame problem Quote:
hi i have the same problem but it was working good so next day said box not found i love use my box and i don't know why happen this b4 a long time using my box.....:confused::confused: help to solve it this .......:confused::confused: thnxx |
I have the same problem I have the same problem with my box. I read all post about put the ufs2xx.dll in system32, and with the .exe, but muy box dont run with 2.17. Only work with 1.8(beta) and not detect de phones¡¡ Please, helpp¡¡¡ Thanks... |
u need hub with adapter to 110v |
