04-02-2008, 17:18 | #16 (permalink) |
No Life Poster Join Date: Jul 2001 Location: PT
Member: 5550 Status: Offline Thanks Meter: 18 | i just dont know what to do more! :S should i keep pressed power on button? |
04-02-2008, 21:08 | #17 (permalink) |
Member: 5550 Status: Offline Thanks Meter: 18 | tried to in a desktop... nothing! :S one strange thing... and i've updated trigers... list of supported versions [RM-159-0]//N95 V 06wk41v18.4 13-03-07 RM-159 (c) Nokia V 06wk41v23.4 17-04-07 RM-159 (c) Nokia V 06wk41v31 05-06-07 RM-159 (c) Nokia V 06wk41v43.1 15-10-07 RM-159 (c) Nokia V 06wk41v50.2 28-01-08 RM-159 (c) Nokia V 06wk41v43.3 04-01-08 RM-159 (c) Nokia ------------------------------- MCU Sw : V 06wk41v50.2 28-01-08 RM-159 (c) Nokia IMEI : 3589*********x SP Version: SIMLOCK SERVER SP_F : 0000000000000000 SP_P : ***xx00000000000 Provider : ****** Counters : 0/3 , 7/10 SP Lock Status : Locked Auto PM-308 Backup....... MCU Sw : V 06wk41v50.2 28-01-08 RM-159 (c) Nokia IMEI : 3589*********xx Backup Already Created...... Phone/Version is not currently in BB5.ini, Switching to Learning Mode... Checking config file... |
04-02-2008, 22:31 | #19 (permalink) |
Member: 5550 Status: Offline Thanks Meter: 18 | no doesnt work ... i have an ufs with this info: UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF UFS_USB V2.6 (c) SarasSoft 2005., S/n: 9728 AdvanceBox Connected cant i unlock because my ufs??? |
04-03-2008, 07:44 | #21 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @UnlockerPT Click "Abort" then click "Read Phone"... if the phone cannot be detected, then it means it has shut down. The reason for shutting down maybe one of the following: (Arrange According to likelyhood) 1. Insufficient mA going into the VBATT ---> Solution = use external charger 2. Great force was exerted on the TP pins causing the phone to "hang". ---> Solution = just press the TP Pins halfway from it's maximum limit. 3. Phone has been accidentally grounded. ---. Solution = put back the phone inside it's original plastic casing. Then with the phone facing upwards, you can still access the TP points even if the PCB is already inside the plastic casing. I would suggest that after powering the phone, wait for 10 seconds before clicking any buttons in the software. Ten seconds is enough to test if the mA on the VBATT is enough or not. If the phone cannot be detected after 10 seconds, then it should be just power problem. We have tested AdvnceUFS on UFS firmware 2.6, 2.7 and 2.8 and they are all compatible. I would strongly suggest that you upgrade your N95 to the latest version first so that unlocking will be faster. (Many people claimed that the easiet version to unlock using advancebox is always the latest firmware version of any phone.) Let's chat on messenger if you still have problems with this phone B.R. X-Shadow |
i cant unlock n95 with TP | marekkaf | NoooX Box | 1 | 06-06-2009 21:31 |
Cant unlock N95 RM159 error PM Section not changed | saajith | Universalbox | 1 | 04-25-2009 09:34 |
Cant unlock N95-GB | yousha | Universalbox | 10 | 11-19-2008 18:15 |
i cant unlock n95 Mt Team help Me | -KimoAlex- | MT-BOX | 7 | 11-14-2007 10:40 |
Cant unlock n95 | tito millo | BB5BOX | 2 | 11-08-2007 22:07 |
