04-25-2008, 06:41 | #1 (permalink) |
Junior Member Join Date: Jul 2005 Location: Montreal, Canada Age: 37
Member: 159528 Status: Offline Thanks Meter: 0 | dead nokia 6300b help i folllowed the procedures, read phone then sp unlock then when it asked me to connect tp i was connecting but it still asked me to so i clicked abort then disconnected the red positive wire and reconnect it and now when i try to read phone it just wont connect . when i power on the phone i only see the blue lights on the side turn on and thats it so if anyone can help me thanks |
04-26-2008, 08:59 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @yusuf96 Do you have any Flasher Box with you? like: JAF UFS UB MT etc... Also, Please reassemble the phone and put back LCD. Then power the phone using regular battery and tell me what it says on the LCD screen. Please post your logs with AdvanceBox as well. B.R. X-Shadow |
04-27-2008, 08:06 | #3 (permalink) |
Member: 159528 Status: Offline Thanks Meter: 0 | i have a twister sarasoft box i put back thephone together and when i turn on the phone , the screen doesnt turn on i only see the blue light on the side that stays on for a few seconds, i check the screen on a nother phone and it works fine |
05-21-2008, 04:01 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @yusuf96 Hi... Try to flash the phone using your Twister Box and post the logs here. There are 2 kinds of "bricks" for your 6300. There is a "software brick" which means your PM 308 is messed up or any part of the firmware is messed up. The second one is a "hardware brick" which means that the TP Pads on the phone's PCB is messed up. You can fix both, but you need to try to flash the phone first and post the logs here so that I can determine which type of "brick" does your 6300 suffer from. Basically, when it is just a software brick you can flash the phone without getting any error messages such as "Flash ID error... no compatible loader...". If you do get some error messages in before the flashing starts, then it is a hardware brick. If you get error messages at the END of the Flashing such as "Phone not found" etc... just try to put REAL battery on the phone to see if you get "Phone Start-up failed contact retailer" error message. If you get this error message, then you have a software brick with bad PM 308. So please tell me which type of brick is it ;-) B.R. X-Shadow |
05-25-2008, 06:53 | #6 (permalink) |
Member: 159528 Status: Offline Thanks Meter: 0 | hi thanks for the reply do you know where i can find the file so that i can flash the phone. i unlocked a few models now of 6300b and 6126 with no problem, do you why this happened. yesterday i got a 6126 from at&T i tried to unlock it and kept going for a while trying to unlock the phone in learning mode, i have the log but the file is too big to upload, and now the phone is dead also. so now i have 2 dead phones please help |
05-31-2008, 15:44 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @yusuf96 Usually it dies because TP pads on the phone's PCB is damaged by pushing the TP Pins for a very long time. It is very easy to fix as well. Just put some soldering flux on the TP pads on the PCB and then use soldering iron to rebuild the TP pads and make it shiny again. Then clean off the excess flux with acetone or any other PCB contact cleaner you have. Then inspect your work under a microscope to see if the TP pads are no longer shorting to the GROUND that surounds it. You can get flash files from JAF support etc... B.R. X-Shadow |
dead nokia 6120c help | morturip2005 | Nokia Hardware & Hardware Repair | 4 | 07-12-2009 14:00 |
how to flash a dead nokia 6280? help pls | marbd1212 | Nokia Base Band 5 ( BB-5 ) | 1 | 07-03-2008 00:03 |
Dead Nokia 5210 Help | ADAMRYANREST | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-25-2002 19:09 |
