Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AdvanceUFS
Old 01-03-2008, 15:18   #1 (permalink)
Cheater -Don't Deal with him-
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
N80 Rm-92 Unlocked In 15 Minutes Have A Look
HERE WE GO
MCU Sw  :  V 05wk33v33.1 22-06-06 RM-92 (c) Nokia.
IMEI    :  358361005600626
SP Version:  SIMLOCK SERVER VERSION 62
SP_F      :  0000000000000000
SP_P      :  2342000000000000
Provider  :  Hutchinson 3G (3);United Kingdom
Counters  :  3/3  ,  1/10
SP Lock Status :  Locked
Checking config file...
Backup Already Created......
TP Connection (Recommended) : AD8
Decrypting ............
Preparing To Unlock Phone .........
Entering Learning Mode.....
Attempt No. : 0:1:1
Initialzing TP....
TP CONNECTED
Sending PSW......
#PW+0123345678901234+7#
Sending Unlock Algorithm......
Counters  :  3/3  ,  6/10
Important SP Data Found .....
Validating SP Data....
SP Data qualified for unlocking...
Preparing To Unlock phone ...
TP CONNECTED
Unlocking
Sending PSW......
Sending PSW......
Counters  :  0/3  ,  0/10
SP Lock Status :  Not Locked
Unlocking success
Phone Not Locked
Operation successfull...
Old 01-03-2008, 17:54   #2 (permalink)
:: Micron ::'s Avatar
Member: 252289
Thanks Meter: 107
Good ..... But that what the program did .... better to show the way what u did with the TEST POINT .
Old 01-03-2008, 18:27   #3 (permalink)
Member: 91438
Good ..... ///////////////////////////
Old 01-04-2008, 09:49   #4 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 602
@chiragp
15 minutes for Learning Mode??? That is too long ;-(((
Or does 15 minutes include phone disassembly and removal or emicon epoxy?
B.R.
Old 01-04-2008, 10:27   #5 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
Originally Posted by X-Shadow View Post
@chiragp
B.R.
15 mints for all process
-phone disassembly
-removel of glued
-make a good tp
-and learningmode process in less then 10 sec only
all process in 15 mintes
Old 01-14-2008, 15:23   #6 (permalink)
Member: 185776
Thanks Meter: 73
-phone disassembly
-removel of glued
-make a good tp
Dear sir,
How to remove glue?pl explain sir.Sorry for disturb.
Old 01-14-2008, 15:45   #7 (permalink)
Member: 327951
Thanks Meter: 4
what is the safe way to removed emicon glue n80..???????
Old 01-16-2008, 19:29   #8 (permalink)
Member: 337837
Thanks Meter: 538
-phone disassembly
-removel of glued
-make a good tp
HOW COULD WE REMOVE GLUE SIR
Old 01-17-2008, 02:56   #9 (permalink)
Member: 185776
Thanks Meter: 73
Where is the test piont of N80 Rm 92.Please upload image.
Old 01-17-2008, 04:25   #10 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 602
The N80 testpoints are the same with N73 testpoints.
To remove the glue, you need emicon glue remover.
It is easy to remove the glue, we can post some videos
if you guys want to see how it is done.
B.R.
X-Shadow
Old 01-17-2008, 05:50   #11 (permalink)
Member: 72851
Thanks Meter: 28
Sir..
Pls share the video although i have my own way to solved that problem ...but maybe your hint will be better ....
Old 01-17-2008, 07:09   #12 (permalink)
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
bro
here u can find every models test point
http:///vbb/showthread.php?t=486720
n80 is same as n73
thanks
Old 01-19-2008, 22:52   #13 (permalink)
Axe Man's Avatar
Member: 221472
Thanks Meter: 8
Hello!
If you had uploaded this tutorial, it would be very nice. And by the way, where can I buy this glue remover, any links or something. Thanks in advance.
BR,
AxeMan
Old 01-19-2008, 23:08   #14 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
what else can be used to remove this emicon glue? any name of chemical please, tnx
N80 rm-92 Unlocked With UB GsmUniversal Universalbox 1 06-22-2009 15:35
Model=6300 Rm-217 Unlocked In 1 Minute chiragp AdvanceUFS 1 01-12-2008 15:11
E 65-1 Rm-208 Unlocked In 2 Minutes chiragp AdvanceUFS 4 01-01-2008 13:04
n80 rm-92 unlock proplem speed08 MT-BOX 4 12-31-2007 07:53
Finally N80 Glued One Unlocked In 10 Minutes chiragp MT-BOX 3 09-30-2007 12:44
Page generated in 0.35053 seconds with 9 queries
