01-08-2008, 04:48 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 42
Member: 72851 Status: Offline Thanks Meter: 28 | Will Advanced box will implement this option?? I found that some 6300(OTB) come with 10/10 counter... Will advanced box implement such feature like UID which could unlock such phone?? Seem like world RPL BB5 service are down or maybe forever even high level nokia service centre... BR |
01-08-2008, 05:00 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @gsm AD0, AD1, 2, 3, 4, 5 ... You can manually select which TP you want to use KP/FBUS - it means Keypress FBUS,,, it can use 0/3 code counter instead of 0/10 code counter thanks |
01-08-2008, 05:08 | #3 (permalink) |
Member: 72851 Status: Offline Thanks Meter: 28 | For example If we use up the 3 counter, I think the only way to restore is via rpl isn't it? As now the service are not reliable so is risky also...that y i hope this feature are implemented to solve this problem!! BR |
01-08-2008, 05:12 | #4 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | If your 6300(OTB) is has a 10/10 FBUS Counter, you can check if you still have some attempts left in your KeyPress 0/3. If there is still some attempts available, then you can unlock the phone by ticking "KP/FBUS". If your phone have 10/10 FBUS Counter and 3/3 KeyPress Counter, then you need to request RPL before you can unlock the phone. We can implement 10/10 3/3 unlock already, but we choose not to release it in respect to those people who are currently offering BB5 RPL Services. Best Regards, X-Shadow |
01-08-2008, 05:23 | #5 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
i cant understand the logic ??????? | |
01-08-2008, 05:30 | #6 (permalink) | |
Member: 72851 Status: Offline Thanks Meter: 28 | Quote:
I really respect your idea regarding not releasing it ... I hope sir can implement it ASAP if the BB5 RPL still down ... BR | |
01-08-2008, 18:04 | #8 (permalink) | |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,241 | Quote:
BR Feel The Power | |
01-09-2008, 02:46 | #9 (permalink) |
Member: 72851 Status: Offline Thanks Meter: 28 | HI, Seem like the BB5BOX already updated to solved such problem and I just received another 3 pcs 6300 with 10/10.. I do hope AdvancedBox Team Really consider it .. AdvancedBox are design with auto learning feature(the best part) and 10/10 will limit this feature and we unable to restore 3/3 back to 0/3 if we fail at 3 attempt. So at the end either return back to customer or lose $$$ on requesting BB5RPL ... There are 1 problem still buzz me if default 6300(OTB) is 10/10 will after writing rpl will it still the same?? Getting 1 rpl to test about it ... BR Last edited by Gsm-W; 01-09-2008 at 02:53. |
01-09-2008, 03:35 | #10 (permalink) | |
BR FEEL THE POWER | |
01-10-2008, 05:02 | #13 (permalink) |
Junior Member Join Date: Jun 2005 Age: 54
Member: 152735 Status: Offline Thanks Meter: 0 | Hello The main point here is this. can advance box unlock if counter is 3/3 and 10/10. this counter value has totally block unlock. via unlock codes. either via fbus (53 08) or keypad entry ( 53 04 ). regards |
01-10-2008, 05:48 | #14 (permalink) | |
BR FEEL THE POWER. | |
Advance bb5/ufs box support this Advance Turbo Flasher box plz need this info....team | somonahmed | Advance-Box | 8 | 05-08-2010 19:58 |
when Universal Team will add this option! | FADILALI | Universalbox | 6 | 09-14-2009 06:53 |
FuriouSTeaM please implement FORMAT option in the Maintenance Module | haxbox | FuriousGold | 16 | 02-24-2009 11:44 |
Implement this option and save Time | unlock trigger | Cruiser Suite | 5 | 11-05-2008 23:40 |
When Will This option Be Iplemented | unlock trigger | UST Pro II | 0 | 10-15-2008 21:47 |
