Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AdvanceUFS
Old 02-12-2008, 12:31   #1 (permalink)
Swazi_Gsm's Avatar
Member: 317494
Sonork: 1000.1984
nokia 6280 V 03.81 can't unlock - (Problem Solved Feb-25-2008)
nokia 6280 cant unlock hire is log file
MCU Sw : V 03.81 09-05-06 RM-78 (c) Nokia
IMEI : 352264012830234
SP Version: SIMLOCK SERVER VERSION 62
SP_F : 8000000000000006
SP_P : 2341500000000000
Provider : Vodafone;United Kingdom
Counters : 0/3 , 0/10
SP Lock Status : Locked
Backup Already Created......
Preparing To Unlock Phone
No. of Unlock Trigger >>>> : 4
Unlock Trigger set to : 1
Unlock Try No. : 1
Buffer size changed to 04 bytes ....
Sending Unlock Trigger 1/4
Sending Unlock Trigger 2/4
Sending Unlock Trigger 3/4
Sending Unlock Trigger 4/4
Initializing TP...
>>> Please connect TP..........................
TP CONNECTED
Unlocking
Sending PSW......
#PW+0123345678901234+7#
Counters : 0/3 , 1/10
Try Failed..
Unlock Trigger set to : 2
Unlock Try No. : 1
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 0/3 , 2/10
Try Failed..
Unlock Trigger set to : 3
Unlock Try No. : 1
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 0/3 , 3/10
Try Failed..
Unlock Trigger set to : 4
Unlock Try No. : 1
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 0/3 , 4/10
Try Failed..
Unlock Try No. : 2
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 0/3 , 5/10
Try Failed..
Unlock Try No. : 2
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 0/3 , 6/10
Try Failed..
Unlock Try No. : 2
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 0/3 , 7/10
Try Failed..
Unlock Try No. : 2
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 0/3 , 8/10
Try Failed..
Unlock Try No. : 3
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 0/3 , 9/10
Try Failed..
Unlock Try No. : 3
Initializing TP...
>>> Please connect TP..
TP CONNECTED
Unlocking
Sending PSW......
Counters : 0/3 , 10/10
Try Failed..
Unlock Try No. : 3
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 1/3 , 10/10
Try Failed..
Unlock Try No. : 3
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 2/3 , 10/10
Try Failed..
Unlock Try No. : 4
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 3/3 , 10/10
Restoring... please wait.....
Please wait.. phone rebooting
Restore Done!
Try Failed..
Unlock Try No. : 4
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 4
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 4
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 5
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 5
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 5
Initializing TP...
Aborted . . . .
Process Aborted
then i flash with lattest V 6.43 but still same problem
now what shoud do??????
Old 02-12-2008, 12:43   #2 (permalink)
Swazi_Gsm's Avatar
Member: 317494
Sonork: 1000.1984
i reset counter 0/3 and 0/10 and try unlock with pin 17 and 24 ---------and pin 17 and 27 still same problem???????????
Old 02-12-2008, 22:24   #3 (permalink)
X-Shadow's Avatar
Member: 871
@javidzone
Only use
PIN 17 - CLK - Black TP
PIN 27 - AD0 - Yellow TP
Do not use PIN 24 - AD1
Check if software reports "TP Connected" even
if you do not connect the TP. If this happens, you
need to disconnect the AdvanceUFS from the UFS
box, then reconnect to try again.
Other possible problems:
USB pop cable for phone is too long...
Replace with shorter USB pop cable.
Improper TP connection...
Place TP pin on the corner and not on the
middle of the TP lines on the RAP.
Please also try to show learning mode logs so
we can better assess your problem.
B.R.
X-Shadow
properly
Old 02-24-2008, 07:50   #4 (permalink)
misal's Avatar
Member: 185854
Unlock Try No. : 1
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 1
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 1
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 1
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 2
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 2
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 2
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 2
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 3
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 3
Initializing TP...
>>> Please connect TP..
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 3
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 3
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 4
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Restore Done!
Try Failed..
Unlock Try No. : 4
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 4
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 4
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 5
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 5
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Try Failed..
Unlock Try No. : 5
Initializing TP...
Aborted . . . .
Process Aborted
i think flash your mobile 6.43 version then unlock press
and one tuch unlock
Old 02-25-2008, 07:25   #5 (permalink)
Member: 88996
just unlock one 6280 v3.81 with advanceufs v2.7
IMEI : 351900012017212
Please wait reading 308 data
C:\Documents and Settings\JeffREY\Desktop\AdvanceBox\Autobackup\V 03.81 09-05-06 RM-78 (c) Nokia_351900012017212.pm
Unlock Try No. : 1
Initializing TP...
>>> Please connect TP..
TP CONNECTED
Unlocking
Sending PSW......
SP Lock Status : Not Locked
Unlocking successfull.......
Process Done! ....
only 2sec for this unlock
Old 02-25-2008, 11:40   #6 (permalink)
Swazi_Gsm's Avatar
Member: 317494
Sonork: 1000.1984
i unlok this phone bro have nice day.now my phone completly work thanks to all member who give me reply
The Following User Says Thank You to Swazi_Gsm For This Useful Post:
nokia 5610 unlock problems [SOLVED] craig0069 Cyclonebox 4 03-23-2010 09:58
3110c bug issue Problem Solved Feb. 20, 2010 Frenzy_2020 Advance-Box 18 02-20-2010 12:40
Req,unlock Huawei C2801 Feb 13 2008 eSWe Various CDMA/TDMA Cell Phones 1 09-17-2008 13:46
help to unlock n73 - (Problem Solved Feb-25-2008) tejasr AdvanceUFS 4 02-28-2008 06:53
Nokia 6280 Firmware 3.81 keguevara Nokia Base Band 5 ( BB-5 ) 6 07-17-2006 02:26
Page generated in 0.35846 seconds with 11 queries
