Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AdvanceUFS
Old 01-23-2008, 10:33   #1 (permalink)
Member: 262429
Thanks Meter: 123
Please wait reading 308 data
MCU Sw : V 05.00 27-04-07 RM-217 (c) Nokia.
IMEI : 358051015***xx
SP Version: SIMLOCK SERVER VERSION 63
SP_F : 8000000000000000
SP_P : 2343000000000000
Provider : T-Mobile-One 2 One;United Kingdom
Counters : 0/3 , 0/10
SP Lock Status : Locked
IMEI : 358051015204085
Backup created not valid... please try again...
Old 01-23-2008, 11:20   #2 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,364
If you are using advanceUFS please insert charger in your box and try again.
Best regards,
ulymar
Old 01-23-2008, 11:41   #3 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 602
@saf470
This is a safety feature made by ulymar so that the incorrect/corrupted PM 308
cannot be written accidentally to a good phone. If you write a bad backup of
PM 308 which is imcomplete, your phone will suffer white screen contact retailer...
Rest assured, AdvanceBox will not save bad/corrupted PM 308 backups caused by
improper readings of the FBUS connection.
You can try to read again, or you can try to connect external power as ulymar suggested.
These improper readings are caused by instability of the communication line between the
phone and the box. The problem can be as simple as a power shortage, or as complicated
as hardware problems on the phone PCB.
Please try again and post if the problem persists.
Best Regards,
Old 01-26-2008, 05:33   #4 (permalink)
Member: 262429
Thanks Meter: 123
Thx 4 Reply,
When I Insert Charger And Attach To Usb, First Time Worked,
And Second Time Same Error,after That.
Disconnect The Ufs After Attach That Works,
How To Solve It.
Z710 please wait hang misal SETool2 5 04-01-2010 07:10
Not Ready, Please Wait For Prepare Data! veta SCDR II 0 11-22-2007 13:21
Please Wait For Prepare Data basim SCDR II 4 02-03-2007 22:28
Msg: Not Ready, Please Wait For Prepare Data! llcoolr SagMaster Team OLD Products 7 12-18-2006 10:39
please wait please wait with Z520 what can i do mr Zulae gsm4libya SonyEricsson (USB-Smart) 1 03-24-2006 13:59
Page generated in 0.17472 seconds with 9 queries
