Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AdvanceUFS
Old 09-23-2008, 07:27   #1 (permalink)
Member: 153596
pls help to unlock 6233
hai i am facing problem for unlocking 6233:
SP Lock Status : Locked
Auto PM-308 Backup.......
MCU Sw : V 04.91 25-09-06 RM-145 (c) Nokia
IMEI : 356293010169523
Backup Already Created......
SP_F : 8000000000000000
SP_P : 2342000000000000
Lock info :
Preparing To Unlock Phone
No. of Unlock Trigger >>>> : 3
Unlock Trigger set to : 1
Unlock Try No. : 1
Buffer size changed to 04 bytes ....
Sending Unlock Trigger 1/4
Sending Unlock Trigger 2/4
Sending Unlock Trigger 3/4
Sending Unlock Trigger 4/4
Initializing TP...
>>> Please connect TP............
TP CONNECTED
Unlocking
Sending PSW......
#PW+0123345678901234+7#
SP Version: SIMLOCK SERVER VERSION 63
Provider : Hutchinson 3G (3);United Kingdom
Counters : 3/3 , 5/10
Lock info :
Try Failed..
Unlock Trigger set to : 2
Unlock Try No. : 1
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 3/3 , 6/10
Lock info :
Try Failed..
Unlock Trigger set to : 3
Unlock Try No. : 1
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 3/3 , 7/10
Lock info :
Try Failed..
Unlock Try No. : 2
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 3/3 , 8/10
Lock info :
Try Failed..
Unlock Try No. : 2
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 3/3 , 9/10
Lock info :
Try Failed..
Unlock Try No. : 2
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 3/3 , 10/10
Lock info :
Restoring splock data... please wait.....
Restore Done!....
Rebooting Mobile... wait for a while...
Reboot Done!
Lock info :
Try Failed..
Unlock Try No. : 3
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 3/3 , 1/10
Lock info :
Try Failed..
Unlock Try No. : 3
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 3/3 , 2/10
Lock info :
Try Failed..
Unlock Try No. : 3
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 3/3 , 3/10
Lock info :
Try Failed..
Unlock Try No. : 4
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters : 3/3 , 4/10
Lock info :
Try Failed..
Unlock Try No. : 4
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Lock info :
Try Failed..
Unlock Try No. : 4
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Lock info :
Try Failed..
Unlock Try No. : 5
Initializing TP...
>>> Please connect TP..
TP CONNECTED
Unlocking
Sending PSW......
Lock info :
Try Failed..
Unlock Try No. : 5
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Lock info :
Try Failed..
Unlock Try No. : 5
Initializing TP...
TP CONNECTED
Aborted . . . .
Unlocking
Try Failed..
Direct Unlock Failed ..
Different flash chip/TP Not connected properly..
Set to Learning Mode.....
Operation Cancelled
pls help
Old 09-25-2008, 01:43   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Hi, did you use this TP Connection:
CLK = 17 counts from the LEFT (BLACK)
AD0 = 27 counts from the RIGH (YELLOW)
GND = Metallic Railing near the RAP (BLACK ALLIGATOR CLIP)
Please check this post:
http://forum.gsmhosting.com/vbb/showthread.php?t=598822
Then click "Show TP"
B.R.
X-Shadow
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 09-29-2008, 09:24   #3 (permalink)
Member: 153596
cannot open the files
Old 09-30-2008, 02:14   #4 (permalink)
Member: 651945
You can only view the files using AdvanceBox software... Click "Show TP" check box in BB5 Tab...
B.R.
X-Shadow
Old 10-03-2008, 08:47   #5 (permalink)
Member: 153596
well the phone goes waiting for phone when the tp is correct. which version should i use. now i am using v2.23
Old 10-03-2008, 09:53   #6 (permalink)
Member: 153596
tp connected.....Waiting for phone....
Old 10-03-2008, 21:08   #7 (permalink)
Member: 651945
@bharath
Just remove red battery connector,, then put it back,, then power up the phone again...
B.R.
X-Shadow
pls help to unlock 6233 bharath Nokia Base Band 5 ( BB-5 ) 0 09-23-2008 03:06
Sharp GX20 Pls Help To Unlock? jameslym Sharp 1 06-27-2005 19:41
Pls help to unlock Motorola V70 fctommy Phone Unlocking Codes & Maps 0 10-17-2003 06:55
Pls help to unlock my MW3026 Load-A-Game ossada Phone Unlocking Codes & Maps 3 08-23-2003 14:23
pls help to unlock MW 3026 cale Infineon C16X M51 & ARM7 M52 BASED 0 09-14-2002 20:56
Page generated in 0.29567 seconds with 11 queries
