Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AdvanceUFS
Old 05-14-2008, 02:09   #1 (permalink)
JaY'Treze's Avatar
Member: 771856
Sonork: 100.1582636
Thanks Meter: 793
TRY AND TESTED Dct4+ DIRECTUNLOCK
TRY AND TESTED Dct4+ DIRECT UNLOCK
MCU Sw  :  V 05.22 31-01-08 RM-340 (c) Nokia
IMEI    :  353122021805879
SLConf : 5150300000000000
SLProf : 800000000001000B
SLVar  : 00553531220218058700
SLAux  : 000B5555
Start unlocking operation....
Check : unlock file...
RM340v522_part1.bin
  >> unlock file found..
Booting ...
UPP: 3162
Boot File : C:\ADVANCE BOX\2.15\Flash\u3_2nd.fia
Supported Hardware ID :  [3040,2292,3162,]
Sending Bootloader ...
FlashID: 00EC2208
ExtBUSC: 7EAD 1AB6 BE1B E20B 587D E46B EEDB 1465
Algo File : C:\ADVANCE BOX\2.15\Flash\u3_amd.fia
Supported Hardware ID :  3040,2292,3162,
Sending Algorithm...
MSID: 84373C1CDDC747AD581480C683
DecodedMSID: 2C40BAE90005CF0DA8000000
EncodedFAID: 36FFCB44B4B108C54B9ACC5D
FAID OK..
Erase Flash Area:
   >> : 01000000-0101FFFF
   >> : 01080000-0109FFFF
Erase Flash Done!
Writing flash data.. please wait...
Write flash done!
Permanent data restore...
Permanent data restore done!...
Please wait....
Sending Unlock Command....
  >>Verifying AdvanceBox availability..
  >>Box verified OK...
  >>Please wait while calculating splock data..
  >>Unlock command sent!
Check : original file...
RM340v522_part2.bin
  >> orignal  file found..
Booting ...
UPP: 3162
FlashID: 00EC2208
FAID OK..
Erase Flash Area:
   >> : 01000000-0101FFFF
   >> : 01080000-0109FFFF
Erase Flash Done!
Write flash done!
Reading phone status...
SLConf : 0010100000000000
SLProf : 000000000001000B
SLAux  : 000B5555
Process Done!..
The Following 2 Users Say Thank You to JaY'Treze For This Useful Post:
Old 05-14-2008, 02:47   #2 (permalink)
dino3711's Avatar
Member: 324702
Thanks Meter: 42
can you plz upload the software......plz....
The Following User Says Thank You to dino3711 For This Useful Post:
Old 05-14-2008, 02:57   #3 (permalink)
sam3578's Avatar
Member: 540170
Thanks Meter: 101
try to check this link sir....
CLICK ME
The Following User Says Thank You to sam3578 For This Useful Post:
Old 05-14-2008, 02:57   #4 (permalink)
Euan's Avatar
Member: 492345
Sonork: 100.1594007
Thanks Meter: 161
if you have AdvanceBox just click "whats new" on support then download the latest version of Advance and Feel the Power...
Old 05-14-2008, 06:38   #5 (permalink)
Member: 498524
Thanks Meter: 19
I tried sevral times but does not do the update
Old 05-14-2008, 07:34   #6 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@Warptech
Just go to the support section of www.advance-box.com
you will find:
2.14
2.14a
2.15
Download 2.15 (about 38mb), extact to new folder and you are good to go...
B.R.
X-Shadow
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 05-14-2008, 15:59   #7 (permalink)
Member: 498524
Thanks Meter: 19
Originally Posted by Advance-Box View Post
@Warptech
you will find:
2.14
2.14a
2.15
B.R.
X-Shadow
Thanx for uploading 2.15 but I got it from another site and I did whats new and it also downloaded the file again although I have 2.15. I also manage to get dct4+ to work so everything is going well now.
Thanx for all the help I got from the Advance team and X-Shadow.
Support are very good thanx to a good team-keep it up
Old 07-02-2008, 07:25   #8 (permalink)
Member: 803622
Thanks Meter: 41
Could some one please tell me, how do you use the DCT4++ software. which box do you use. I have advanceUFS.
please explain abit detail about using the DCT4+ free software
Old 07-03-2008, 05:54   #9 (permalink)
Member: 651945
@dmobile1
If you are using AdvanceUFS, you need 2 UFS Boxes...
On the first UFS Box you connect the AdvanceUFS.
On the second UFS Box you connect the DCT4+ phone.
Then you Run the EXE when both UFS Boxes are connected to the PC.
B.R.
X-Shadow
Old 01-07-2009, 05:31   #10 (permalink)
Member: 798811
Sonork: astrong
Thanks Meter: 16
so gr8 u 4 give d' solution when use 2 ufs & advance..........
for waiting update..............
Old 01-12-2009, 18:40   #11 (permalink)
adi sukmono's Avatar
Member: 695310
Thanks Meter: 144
what..using 2 box?...its nt good for yours busines sir,,,cause nt simple
Old 01-12-2009, 18:43   #12 (permalink)
arybraga's Avatar
Member: 837940
Sonork: 83906941
Thanks Meter: 48
what..using 2 box??????
Old 01-15-2009, 14:20   #13 (permalink)
andy_jpn's Avatar
Member: 248942
Sonork: 100.1590361
Thanks Meter: 455
@arvbraga
yes you need 2 ufs box
1 for connect advance ufs
1 for connect phone
this is very simple
Old 02-28-2009, 04:05   #14 (permalink)
Member: 803622
Thanks Meter: 41
Originally Posted by andy_jpn View Post
@arvbraga
1 for connect phone
this is very simple
is that connect them all in series
first ufs to usb
second advance ufs to ufs box
third ufs box to advance ufs
is this how you connect them
100 free DCT4 RPL for Testing dct4 RPL Server. faizanbhatti94 Nokia Digital Core Technology 4 ( DCT-4 ) 82 03-16-2010 19:05
Test Box , Try and see spider-man Samsung Flashers, Software, Firmware. 2 02-08-2008 00:02
Tested DCT4 hex for free! Download and don't forget to rete me :-) uu1dx Nokia Digital Core Technology 4 ( DCT-4 ) 158 03-11-2007 04:09
Corrupted MMC, please try and test Uvedovle Hardware Repair by brands 14 09-09-2005 09:16
TRY and TRY !!not find the solution for unlock 3027 dreba Phone Unlocking Codes & Maps 1 02-20-2003 00:34
Page generated in 0.29038 seconds with 10 queries
