Take A Look Reading Only READING ONLY RESULT http://i106.photobucket.com/albums/m.../RASKALBB5.jpg GOOD JOB http://i106.photobucket.com/albums/m...ADVANCEBB5.jpg HMMMMM |
Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v39_30-11-06_RM-133_(c)_Nokia. IMEI: XXXXXXXX Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reading PM Field 308 Subfield 1 with length 8192 bytes NOT WORKING |
Trying To Unlock This Version Not Working So Where Is The Auto Learning Mode??????????????????????????????????? |
hey its N76 NAND FLASH THERE IS NO SIMLOCK SERVER..... Its a new phone from nokia with new security.. we only support NOR flash chip |
bugs fix ...... n76 is NAND flash...we are still working on it. regards, |
contact us |
upgrade but i buy this product for autolearning features but did not work im not new user of bb5 from uid and bb5 raskal ..... to many n73 i unlock before the problem is some phones need to upgrade or downgrage when this advance-bb5 born ... im so happy to used it but..why ? this n73 unsupported version did work on autolearning mode :(:( |
@ronskiton_ron N76 cannot be unlocked using DK's theory because it is using NAND flash and the firmware is compressed (Zlib) and it is only uncompressed in the RAM prior to execution. In short,,, it will be like unlocking a DCT4 phone using a DCT3 clip. It is not compatible with TP unlocking as of the moment. Please tell me what exactly was your problem with the N73? RE: "Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v39_30-11-06_RM-133_(c)_Nokia. IMEI: XXXXXXXX Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reading PM Field 308 Subfield 1 with length 8192 bytes NOT WORKING" That is a readout using another software and not AdvanceUFS software... Also, you do not need to connect the Battery GND and the Alligator GND to the phone. This connections are optional and you can choose not to use them and rely only on the GND in the POP port. All our 20++ test phones here were unlocked using only the GND in the POP Port Only... We only put the additional two GNDs as a backup... V_05wk47v39 <--- if this is the current version of your N73, then I think it is a Japanese Firmware and I do not have access to Japanese firmwares as of the moment as they are very rare to come by. My suggestion would be that you should upgrade that N73 with the latest firmware version so that it you can use direct unlock function. There is no danger in upgrading, and I am sure you will unlock the phone after you do the upgrade. Also,,, for the TP Pins,,, BLACK is CLK... YELLOW is ADX B.R. |
yes this already unlock by bb5 raskal thanks for fast reply next time im using your advance-bb5 to another model of phones i hope ........ im gona succesfully unlock bb5 phone using advance bb55 ......again thanks .:D |
