Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AdvanceUFS
Old 12-29-2007, 09:21   #1 (permalink)
Member: 305311
Take A Look Reading Only
READING ONLY
RESULT
GOOD JOB
HMMMMM
Old 12-29-2007, 09:26   #2 (permalink)
Member: 305311
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-133
Version: V_05wk47v39_30-11-06_RM-133_(c)_Nokia.
IMEI: XXXXXXXX
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Reading PM Field 308 Subfield 1 with length 8192 bytes
NOT WORKING
Old 12-29-2007, 09:30   #3 (permalink)
Member: 305311
Trying To Unlock This Version Not Working So Where Is The Auto Learning Mode???????????????????????????????????
Old 12-29-2007, 10:08   #4 (permalink)
lemor's Avatar
Member: 38562
hey its N76 NAND FLASH THERE IS NO SIMLOCK SERVER.....
Its a new phone from nokia with new security.. we only support NOR flash chip
Old 12-29-2007, 11:38   #5 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
bugs fix ......
n76 is NAND flash...we are still working on it.
regards,
Old 12-29-2007, 12:18   #6 (permalink)
Member: 654948
Type: RM-133
IMEI: XXXXXXXX
NOT WORKING
hi CHECK FIRST if your version is available in autounlock.ini if not
contact us
Old 12-29-2007, 12:26   #7 (permalink)
Member: 305311
contact us
im trying 10x autolearning but dont work ..... i know this version need to
upgrade but i buy this product for autolearning features but did not work
im not new user of bb5 from uid and bb5 raskal ..... to many n73 i unlock
before the problem is some phones need to upgrade or downgrage when
this advance-bb5 born ... im so happy to used it but..why ? this n73
unsupported version did work on autolearning mode
Old 12-29-2007, 12:27   #8 (permalink)
X-Shadow's Avatar
Member: 871
@ronskiton_ron
N76 cannot be unlocked using DK's theory because it is using NAND flash and
the firmware is compressed (Zlib) and it is only uncompressed in the RAM prior
to execution. In short,,, it will be like unlocking a DCT4 phone using a DCT3 clip.
It is not compatible with TP unlocking as of the moment.
Please tell me what exactly was your problem with the N73?
RE:
"Searching for phone ...
Type: RM-133
IMEI: XXXXXXXX
NOT WORKING"
That is a readout using another software and not AdvanceUFS software...
Also, you do not need to connect the Battery GND and the Alligator GND to
the phone. This connections are optional and you can choose not to use
them and rely only on the GND in the POP port. All our 20++ test phones here
were unlocked using only the GND in the POP Port Only... We only put the
additional two GNDs as a backup...
V_05wk47v39 <--- if this is the current version of your N73, then I think it is
a Japanese Firmware and I do not have access to Japanese firmwares as of the
moment as they are very rare to come by. My suggestion would be that you
should upgrade that N73 with the latest firmware version so that it you can
use direct unlock function.
There is no danger in upgrading, and I am sure you will unlock the phone after
you do the upgrade.
Also,,, for the TP Pins,,, BLACK is CLK... YELLOW is ADX
B.R.
Old 12-29-2007, 12:37   #9 (permalink)
Member: 305311
Originally Posted by X-Shadow View Post
@ronskiton_ron
RE:
Type: RM-133
IMEI: XXXXXXXX
NOT WORKING"
you do the upgrade.
B.R.
yes this already unlock by bb5 raskal
thanks for fast reply next time im using your advance-bb5 to another
model of phones i hope ........ im gona succesfully unlock bb5 phone using
advance bb55 ......again thanks .
New Look New design Just Take a look !!! sunnyc GSM Mobile Links 0 06-20-2007 20:14
D500 problems - take a look i am sure i am not the only one who has it cellularman SWIFT Platform 10 07-27-2005 22:08
Faid calculator [B-phreaks] cracked take a look mobilemafia Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 18 01-18-2002 08:28
Take a look, new site and forums... etones GSM Mobile Links 4 09-18-2000 07:08
New Forums, New Sites, take a look... etones GSM Mobile Links 0 09-17-2000 21:41
Page generated in 0.37196 seconds with 11 queries
