Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AdvanceUFS
Old 01-11-2008, 12:44   #1 (permalink)
X-Shadow's Avatar
Member: 871
The Truth About Learning Mode Part II
Hi,
Some important user reported that He failed in Learning Mode trying to
unlock 6300 5.52 with SEC-ATD and SEC-ATB flash chips. After reading his
post, I asked my Team to send me some 6300 with SEC-ATD and SEC-ATB
Flash chips. When the phone arrived, this is what happend...
Attempt No. 1:
Phone = 6300 5.52 with SEC-ATD
Auto Unlocker.ini Settings:
[Instance]
TRY=4
repetition=3
Jump=false
Result: FAILURE ;-(((
Attempt No. 2:
[Instance]
TRY=16
repetition=1
Jump=false
Result: SUCCESS!!! ;-))))
Resulting Trigger: 100503450E0406F9F5EEBE31
Since I wanted to be sure, I tried Learning Mode for the third time with
slightly different settings...
Attempt No. 3:
[Instance]
TRY=16
repetition=1
Jump=true
Result: SUCCESS!!! ;-)))) (and it took less time as well...)
Resulting Trigger: 020507FF0E18F8F9F9D22035
Now we have 2 triggers for 6300 5.52 SEC-ATD!!!
Check the attached Log files on this post too see the complete process
of both Attempt No. 2 and Attempt No. 3...
What does this tell us??? Simple.... Learning Mode Works no doubt about it ;-)
But this is not where the story ends... today one of my Team member sent
me 2 6300 phones and this time the Flash Chip was SEC-ATB and Spansion.
Since I had some free time on my hands because there are not much people
complaining about our product... I flashed all phones one-by-one from
version 4.20 upto 5.52 and tried to unlock each and every variant using
Learning Mode.
With my current settings for Auto Unlocker.ini set at:
[Instance]
TRY=16
repetition=1
Jump=true
It did not fail even a single time!!!
Sometimes the Learning Mode finishes in less than 10 seconds and I had
to repeat the process again just to be extra sure that it finished the
process correctly... ;-) And so in the end, I had many many triggers for
unlocking the same version and flash chip!!!
The entire process of flashing each of the 3 phones took me more than
10 hours using 2 laptops... The following firmware versions were used:
4.20
4.70
4.71
5.00
5.50
5.52
All three flash chips did well and I could not even notice the difference
between the three... All where very easy to unlock!
So as of this moment, AdvanceBB5 and AdvanceUFS supports all firmware
versions of 6300 and all 3 flash chips as well!!!
(Spansion, SEC-ATB, SEC-ATD)...
Here are the triggers by the way...
[RM-217-0]
Model=6300
V 04.20 05-12-06 RM-217 (c) Nokia.=021011FF454AF80403D820EF,0811071D4A18FE05F9 CA56F5,0E0E053B3B0E0402F7F3FCC3
V 04.70 24-01-07 RM-217 (c) Nokia.=07041118094AFDF803D8652F,07041118094AFDF803 D8252F,03041104094AF9F803D8212F,020503FF0E04F8F9F5 8E9031
V 04.71 28-02-07 RM-217 (c) Nokia.=070509180E22FDF9FBD37537,070509180E22FDF9FB D33537,030509040E22F9F9FBD33137,020409FF0922F8F8FB F23027,02050BFF0E2CF8F9FDAE9039
V 05.00 27-04-07 RM-217 (c) Nokia.=0F030D40043605F7FFD7FD1B,0E04053B090E04F8F7 F5FC23
V 05.50 14-08-07 RM-217 (c) Nokia.=0F030540040E05F7F7D7FD13,09050B220E2CFFF9FD CED739
V 05.52 09-11-07 RM-217 (c) Nokia.=100503450E0406F9F5EEBE31,020507FF0E18F8F9F9 D22035,020507FF0E18F8F9F9D20035,020507FF0E18F8F9F9 920035
(Please remove the spaces in between the hex bytes... just it case the triggers appear to get posted in a wrong manner...)
I hope you guys appreciate my 10-hours of flashing ;-)
So as of this moment, you will DON'T NEED LEARNING MODE FOR ANY
6300 phone....(for the time being...)
But what if Nokiya releases a new firmware version???
Well, since I already have these test phones here... then I guess the
right thing to do is to upgrade the phones again and do Learning Mode for
you guys ;-). But of course, you can also do it yourselves after we update
the Auto Unlocker.ini and include that new version in your Learning Mode
settings...
My Best Settings for Auto Unlocker.ini:
[Instance]
TRY=16
repetition=1
Jump=true
Don't forget to try and look at my Log Files attached so that you will see
the difference...
Best Regards,
X-Shadow
Attempt No.2
MCU Sw  :  V 05.52 09-11-07 RM-217 (c) Nokia.
IMEI    :  359544014903383
SP Version:  SIMLOCK SERVER VERSION 63
SP_F      :  0000000000000000
SP_P      :  5150200000000000
Provider  :  Globe Telecom;Philippines
Counters  :  0/3  ,  7/10
SP Lock Status :  Locked
Phone/Version is not currently in BB5.ini, Switching to Learning Mode...
Checking config file...
Backup Already Created......
TP Connection (AD Selected) : AD0
Decrypting ............
Preparing To Unlock Phone .........
Entering Learning Mode.....
Waiting for phone....
Attempt No. : 0:0:1
Initialzing TP....
TP CONNECTED
Sending PSW......
#PW+0123345678901234+7#
Counters  :  0/3  ,  8/10
Sending Unlock Algorithm......
Important SP Data Found .....
Validating SP Data....
SP Data qualified for unlocking...
Preparing To Unlock phone ...
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Counters  :  0/3  ,  9/10
Failed to Unlock
Attempt No. : 0:1:1
Initialzing TP....
TP CONNECTED
Sending PSW......
Counters  :  0/3  ,  10/10
Restoring... please wait.....
Please wait.. phone rebooting
Restore Done!
Counters  :  0/3  ,  0/10
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Failed to Unlock
Attempt No. : 0:2:1
Initialzing TP....
TP CONNECTED
Sending PSW......
Counters  :  0/3  ,  1/10
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Failed to Unlock
Attempt No. : 0:3:1
Initialzing TP....
TP CONNECTED
Sending PSW......
Counters  :  0/3  ,  2/10
SP Data NOT qualified for unlocking...
Attempt No. : 0:4:1
Initialzing TP....
TP CONNECTED
Sending PSW......
Counters  :  0/3  ,  3/10
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Failed to Unlock
Attempt No. : 0:5:1
Initialzing TP....
TP CONNECTED
Sending PSW......
Counters  :  0/3  ,  4/10
Attempt No. : 0:6:1
Initialzing TP....
TP CONNECTED
Sending PSW......
Counters  :  0/3  ,  5/10
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
SP Lock Status :  Not Locked
Unlocking success
Phone Not Locked
Operation successfull...
Attempt No. 3
Attempt No. : 0:0:1
Initialzing TP....
>>> Please connect TP...................
TP CONNECTED
Sending PSW......
Initializing TP...
TP CONNECTED
Unlocking
Sending PSW......
Unlocking success
Phone Not Locked
The truth about AdvanceBOX and so called "auto-learning" mode BB5box.org BB5BOX 65 01-27-2008 12:46
Dont Tell The Truth About Dejan Or The Thread Gets Deleted TDXI Board, Server and Login Problems/Support 34 05-29-2005 08:38
The Truth about Griffin! alert-editor Griffin 21 02-10-2005 18:25
What´s the truth about Motorola codes? hellomoto Phone Unlocking Codes & Maps 0 12-15-2003 12:52
Page generated in 0.24354 seconds with 11 queries
