09-06-2008, 16:05 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Tunisia
Member: 296895 Status: Offline Thanks Meter: 33 | why my advance ufs???????????? - (Problem Solved Sept-08-2008) so my advance ufs detect only phone with dku-2 connector. please if there is any solution, share it and thank you very much. nizoudj |
09-07-2008, 00:11 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @nizoudj The Problem should be the cable. Turn on the phone Normally. Try to connect small USB to phone then direct to your PC's USB Port. Then see if Phone is detected by your PC or not. If your PC does not Find the Phone, then your USB cable is damaged... If your PC Finds the Phone then Select USB Connection in AdvanceBox software and SP Unlock your Phone: You can also check your cable: B.R. X-Shadow Last edited by Advance-Box; 09-07-2008 at 03:23. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
Why delete my post insted of solve my problem. | Kiranmistry | Universalbox | 7 | 07-22-2009 22:03 |
Advance-bb5 & Advance-ufs Advanced Test Point Only Here | chiragp | AdvanceUFS | 29 | 10-09-2008 16:37 |
cant register my BOX!!!!!!!! ==> Problem Solve, Case CLosed! | sid_vicious | PadFinder box | 11 | 09-15-2008 08:23 |
