Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Micro-Box Team Products > Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...)
Old 02-16-2015, 12:07   #1 (permalink)
julvir's Avatar
Member: 3173
Sonork: 100.100
Thanks Meter: 16,887
Arrow 16 February 2015 - Micro-Box Samsung V1.0.1.8 - MICRO-BOX SAMSUNG UPDATE:
16 February 2015 - Micro-Box Samsung V1.0.1.8 - MICRO-BOX SAMSUNG UPDATE: ENABLE LANG ! REMOVE PATERN ! etc....
Added :
- REMOVE PATTERN
- PHONE CODE
- ENABLE ADB
( Without USB DEBUG ENABLE !! )
by MODEM and/or UART for ALL SAMSUNG ANDROID MODELS!
Generic solution, possible to not work for some models!
Added :
- ACTIVATE ALL LANGUAGES
for ALL SAMSUNG ANDROID MODELS! (require rooted phone)
PLEASE TAKE IT FROM MICRO-BOX SUPPORT or from ALTERNATIVE DOWNLOAD LINK(s):
http://rombase.net/support_microbox/....1.8_FINAL.rar
#1 CHECK IT HERE =>#1 SUPPORT WITH VIDEO TUTORIALS !!!
#1 CHECK IT HERE =>#1 REALTIME update of SUPPORTED MODELS list ! INCLUDED VIDEO LINKS !
MICRO BOX V2.0 THE BEST MULTI PLATFORM UNLOCKING TOOL ! - MICRO-BOX FULL ACTIVATED
julvir
The Following 16 Users Say Thank You to julvir For This Useful Post:
Old 02-16-2015, 14:02   #2 (permalink)
dr.danielman's Avatar
Member: 356508
Thanks Meter: 126
grat
great update.
can you tell me how to enable all language?
thx
br
The Following User Says Thank You to dr.danielman For This Useful Post:
Old 02-16-2015, 14:56   #3 (permalink)
MB code's Avatar
Member: 6321
Thanks Meter: 1,664
Just select model and for connection mode select Android Debug Mode and u will see button enabled
b.r.
Old 02-16-2015, 15:06   #4 (permalink)
Member: 356508
Thanks Meter: 126
thx
b.r.
thy 4 reply but 4 new models like N910F i do not have option 4 android debug only uart-factory
thx
br
Old 02-16-2015, 15:14   #5 (permalink)
MB code's Avatar
Member: 6321
Thanks Meter: 1,664
ok, will add for this to but for the moment you can select SM-N910L, this have android debug mode and it's ok to try select like this
Old 02-17-2015, 06:37   #6 (permalink)
Member: 455684
Thanks Meter: 79
sir how can i purchase this box and wat is the price of this box with
all activation...im from delhi
Old 02-17-2015, 09:45   #7 (permalink)
cykada's Avatar
Member: 42387
Sonork: 1573735
Thanks Meter: 391
Pattern lock for S6310N, button even not available. Fake update.
Old 02-17-2015, 10:14   #8 (permalink)
julvir's Avatar
Member: 3173
Sonork: 100.100
Fake unlocker ... you can read post just before ? .. you have to select port MODEM
julvir
Old 02-17-2015, 11:13   #9 (permalink)
ak72342's Avatar
Member: 823250
Sonork: 100.1587800
Thanks Meter: 187
Great update.....what about google account?????
Old 02-17-2015, 11:40   #10 (permalink)
cykada's Avatar
Member: 42387
Sonork: 1573735
Thanks Meter: 391
julvir
Julvir, no offence, I unlocks a long time, than you write your software.
Old 02-17-2015, 12:06   #11 (permalink)
julvir's Avatar
Member: 3173
Sonork: 100.100
Arrow
I dont think you unlock before us to write software but is no point to speak about it ..
about software , i will also add inside button PATTERN this fonction
but you can make 2 way :
1 - ENABLE ADB - and then use button PATTERN
2 - PHONE CODE button , to remove it
Old 02-17-2015, 13:36   #12 (permalink)
cykada's Avatar
Member: 42387
Sonork: 1573735
Thanks Meter: 391
THX, but still not working, enabling adb not successfull :
14:29:44 > Samsung S6310N ENABLE ADB: START!
14:29:44 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED!
14:29:49 > Searching for phone: OK!
14:29:51 > Reading BUILD INFO: OK!
14:29:51 > Reading BRAND: OK!
14:29:56 > Reading MODEL: OK!
14:30:00 > Reading VERSIONS: OK!
14:30:00 > Reading IMEI: OK!
14:30:01 > Reading BLUETOOTH INFO: ERROR!
14:30:01 > Reading MSL INFO: ERROR!
14:30:01 > BRAND: SAMSUNG ELECTRONICS CORPORATION
14:30:01 > MODEL: GT-S6310N
14:30:01 > IMEI: 359043054686529
14:30:01 > VERSION: S6310NXXAMK1/S6310NIDEAMK1/S6310NXXAMK1/S6310NXXAMK1
14:30:01 > S6310NXXAMK1/S6310NXXAMK1/S6310NIDEAMK1
14:30:01 > PHONE SN: RF1DB0XQL8X
14:30:02 > CONNECTION: AT,MTP
14:30:31 > Enabling ADB: OK!
14:30:32 > Samsung S6310N ENABLE ADB: END!
Old 02-17-2015, 13:42   #13 (permalink)
cykada's Avatar
Member: 42387
Sonork: 1573735
Thanks Meter: 391
and 2-nd :
14:39:00 > Samsung S6310N DISABLE SECURITY: START!
14:39:00 > PLEASE "WAKE UP" PHONE IF IT'S IN STANDBY OR WILL NOT BE DETECTED!
14:39:04 > Searching for phone: OK!
14:39:07 > Reading BUILD INFO: OK!
14:39:07 > Reading BRAND: OK!
14:39:13 > Reading MODEL: OK!
14:39:20 > Reading VERSIONS: OK!
14:39:20 > Reading IMEI: OK!
14:39:21 > Reading BLUETOOTH INFO: ERROR!
14:39:21 > Reading MSL INFO: ERROR!
14:39:21 > BRAND: SAMSUNG ELECTRONICS CORPORATION
14:39:21 > MODEL: GT-S6310N
14:39:21 > IMEI: 359043054686529
14:39:21 > VERSION: S6310NXXAMK1/S6310NIDEAMK1/S6310NXXAMK1/S6310NXXAMK1
14:39:21 > AT+DEVCONINFO+DEVCONINFO: MN(GT-S6310N);BASE(GT-I9300);VER(S6310NXXAMK1/S6310NIDEAMK1/S6310NXXAMK1/S6310NXXAMK1);HIDVER(S6310NXXAMK1/S6310NIDEAMK1/S6310NXXAMK1/S6310NXXAMK1);MNC(06);MCC(260);PRD(GT2S6310ZWNIDE) ;SN(00000000000);IMEI(359043054686529);PN();CON(AT ,MTP);LOCK(DEVICE);LIMIT(FALSE);SDP(RUNTIME);HVID( DATA:196609,CACHE:262145,SYSTEM:327681)#OK#
14:39:21 > PHONE SN: 00000000000
14:39:21 > CONNECTION: AT,MTP
14:39:21 > Opening connection:
And SW hangs.
Old 02-18-2015, 09:28   #14 (permalink)
julvir's Avatar
Member: 3173
Sonork: 100.100
Ok , checking ... as i not have that models in hand
also possible to not work at all.
julvir
The Following User Says Thank You to julvir For This Useful Post:
Old 02-20-2015, 12:56   #15 (permalink)
Santiago LEE's Avatar
Member: 38642
Thanks Meter: 69
hi..
i try activate all language one i317m
09:49:19 > AT&T I317M ACTIVATE ALL LANGUAGES: START!
09:49:19 > Please power on phone and connect to usb in android debug mode!
09:49:19 > If phone ask to allow usb debuging please accept!
09:49:25 > KILLING ADB SERVER (IF RUNNING): OK!
09:49:30 > Searching for phone: OK!
09:49:47 > Reading info: OK!
09:49:50 > Checking root: OK! (ROOTED)
09:49:50 > BRAND: SAMSUNG
09:49:50 > MODEL: SGH-I317M
09:49:50 > T0LTECAN / T0LTEVL
09:49:50 > IMEI: 3565650xxxxxxxxx
09:49:50 > HWID: SMDK4X12-10
09:49:50 > BOOT LOADER: I317MVLUDNH2
09:49:50 > VERSION: ANDROID 4.4.2
09:49:50 > BUILD KOT49H / I317MVLUDNH2
09:49:50 > I317MVLUDNH2 / I317MOYADNH2 (PDA/CSC)
09:49:50 > FIRMWARE: T0LTEVL-USER / I317MVLUDNH2
09:49:50 > HARDWARE: NOT ACTI
09:49:50 > KERNEL: 3.0.31-1736364 (gcc 4.4.3)
09:49:50 > PHONE SN: 0000000000
09:49:50 > CPU TYPE: EXYNOS4 / ARMv7
09:49:50 > CARD ID: 02544D534133324711217B6ACE00DB00
09:50:01 > Writing data: OK!
09:50:10 > Restarting phone: OK!
09:50:10 > AT&T I317M ACTIVATE ALL LANGUAGES: END!
but not luck it..
any help .??
Page generated in 0.49667 seconds with 8 queries
