Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Micro-BoxTeam Products > Basic Micro-Box Software Support
Old 02-24-2011, 23:05   #31 (permalink)
Member: 72951
Originally Posted by qwerthj View Post
Thanks for this update, working good
02:47:50 > DELL STREAK READ CODES:                    	 START!
02:47:50 > KILLING ADB SERVER (IF RUNNING):
02:47:50 > KILLING ADB SERVER (IF RUNNING):        	 OK!
02:47:50 > SEARCHING FOR PHONE:
02:47:50 > SEARCHING FOR PHONE:                          	 OK!
02:47:51 > READING INFO:
02:47:51 > READING INFO:                                          	 OK!
02:47:51 > 	MODEL:               	 Dell Streak / streak
02:47:51 > 	VERSION:            	 2.2 / FRF91
02:47:51 > 	FIRMWARE:         	 streak-user / GAUSB1A130500-EU
02:47:52 > 	KERNEL:              	 2.6.32.9-perf (gcc 4.4.0)
02:47:52 > 	CPU TYPE:          	 QSD8K / ARMv7
02:47:52 > CHECKING ROOT:
02:47:57 > CHECKING ROOT:                                      	 ERROR!
02:47:57 > RUNNING TEMP ROOT:
02:48:34 > RUNNING TEMP ROOT:                               	 OK!
02:48:34 > SEARCHING FOR PHONE:
02:48:34 > SEARCHING FOR PHONE:                          	 OK!
02:48:35 > CHECKING ROOT:
02:48:37 > CHECKING ROOT:                                      	 OK!
02:48:37 > BOOTING PHONE IN SECURE MODE:
02:48:39 > BOOTING PHONE IN SECURE MODE:         	 OK!
02:48:41 > SEARCHING PHONE:
02:49:21 > SEARCHING PHONE:                                  	 OK!
02:49:21 > READING IMEI:
02:49:21 > READING IMEI:                                            	 OK!
02:49:21 > READING DATA:                                        	 OK!
02:49:21 > 	MODEL:               	 Dell Streak / streak
02:49:21 > 	IMEI:                     	 3540000301xxxxx
02:49:21 > 	VERSION:            	 2.2 / FRF91
02:49:21 > 	FIRMWARE:         	 streak-user / GAUSB1A130500-EU
02:49:21 > 	KERNEL:              	 2.6.32.9-perf (gcc 4.4.0)
02:49:21 > 	CPU TYPE:          	 QSD8K / ARMv7
02:49:21 > 	NCK CODE:         	 02521598
02:49:21 > DELL STREAK READ CODES:                    	 END!
I noticed your Streak has 2.2 Froyo and you have successfully unlocked it. I am trying to unlock mine but it only has 1.6 Donut. There is no official 2.2 release in my country for this device. This raises two questions. Does this mean that Micro Box cannot unlock version 1.6? Second question.....When you went to read codes and it asked you for the Dell Streak drivers, did you point it to the Micro Secure Driver and was successful? Because it does not work for me and you seem to be the only one posting a successful Streak unlock here so far. Please help. Thank you sir.
Old 02-25-2011, 05:48   #32 (permalink)
rudidar's Avatar
Member: 354893
Sonork: 100.1579833
Originally Posted by julvir View Post
hello micro box team. if u want to give update then u will give update daily,but also need to give good support to us.all people facing dell usd driver,but u people nt responze. so can u pls fixed this problem for dell.?
thnx
Old 02-25-2011, 10:36   #33 (permalink)
Member: 1428485
Sonork: 100.1596801
Unhappy Dell streak drivers needes
hi i am getting same problem as most of people getting. when we follow all the procedure then after microbox run temp root. the phone start asking for dell streak drivers but these drivers can't b found from any drivers available from support.
Can please somebody will post drivers for Dell Streak. So i can unlock my dell phone.
this is the error i am getting at end when i can't find the drivers
10:13:44 > VERSION MICRO-BOX A.I.O. V1.0.8.3
10:13:44 > DELL STREAK READ CODES: START!
10:13:44 > KILLING ADB SERVER (IF RUNNING): OK!
10:15:07 > SEARCHING FOR PHONE: OK!
10:15:08 > READING INFO: OK!
10:15:08 > MODEL: Dell Streak / qsd8250_surf
10:15:08 > VERSION: 1.6 / Donut
10:15:08 > FIRMWARE: qsd8250_surf-user
10:15:08 > KERNEL: 2.6.29-perf (gcc 4.2.1)
10:15:08 > CPU TYPE: ARMv7
10:15:13 > CHECKING ROOT: ERROR!
10:15:49 > RUNNING TEMP ROOT: OK!
10:17:49 > SEARCHING FOR PHONE: ERROR!(TIMEOUT)
10:17:50 > PLEASE RESTART PHONE AND TRY AGAIN!
10:17:50 > DELL STREAK READ CODES: END!
10:26:20 > VERSION MICRO-BOX A.I.O. V1.0.8.3
10:26:20 > DELL STREAK READ CODES: START!
10:26:20 > KILLING ADB SERVER (IF RUNNING): OK!
10:26:25 > SEARCHING FOR PHONE: OK!
10:26:26 > READING INFO: OK!
10:26:26 > MODEL: Dell Streak / qsd8250_surf
10:26:26 > VERSION: 1.6 / Donut
10:26:26 > FIRMWARE: qsd8250_surf-user / GAUSB1A110421-EU
10:26:26 > KERNEL: 2.6.29-perf (gcc 4.2.1)
10:26:26 > CPU TYPE: ARMv7
10:26:32 > CHECKING ROOT: ERROR!
10:27:07 > RUNNING TEMP ROOT: OK!
10:29:07 > SEARCHING FOR PHONE: ERROR!(TIMEOUT)
10:29:08 > PLEASE RESTART PHONE AND TRY AGAIN!
10:29:08 > DELL STREAK READ CODES: END!
Thank you
Old 02-25-2011, 17:14   #34 (permalink)
Member: 898376
Sonork: ----
yes not working the driver. when it asks for second driver
yes11:56:54 > DELL STREAK READ CODES: START!
11:56:54 > KILLING ADB SERVER (IF RUNNING): OK!
11:56:54 > SEARCHING FOR PHONE: OK!
11:56:56 > READING INFO: OK!
11:56:56 > MODEL: Dell Streak / qsd8250_surf
11:56:56 > VERSION: 1.6 / Donut
11:56:56 > FIRMWARE: qsd8250_surf-user / GAUSB1A111732-US
11:56:56 > KERNEL: 2.6.29-perf (gcc 4.2.1)
11:56:56 > CPU TYPE: ARMv7
11:57:01 > CHECKING ROOT: ERROR!
11:57:37 > RUNNING TEMP ROOT: OK!
11:59:38 > SEARCHING FOR PHONE: ERROR!(TIMEOUT)
11:59:38 > PLEASE RESTART PHONE AND TRY AGAIN!
11:59:38 > DELL STREAK READ CODES: END!
12:01:03 > VERSION MICRO-BOX A.I.O. V1.0.8.3
12:01:03 > DELL STREAK READ CODES: START!
12:01:03 > KILLING ADB SERVER (IF RUNNING): OK!
12:03:03 > SEARCHING FOR PHONE: ERROR!(TIMEOUT)
12:03:04 > DELL STREAK READ CODES: END!
12:12:05 > VERSION MICRO-BOX A.I.O. V1.0.8.3
12:12:05 > DELL STREAK READ CODES: START!
12:12:06 > KILLING ADB SERVER (IF RUNNING): OK!
12:12:06 > SEARCHING FOR PHONE: OK!
12:12:07 > READING INFO: OK!
12:12:07 > MODEL: Dell Streak / qsd8250_surf
12:12:07 > VERSION: 1.6 / Donut
12:12:07 > FIRMWARE: qsd8250_surf-user / GAUSB1A111732-US
12:12:07 > KERNEL: 2.6.29-perf (gcc 4.2.1)
12:12:07 > CPU TYPE: ARMv7
12:12:13 > CHECKING ROOT: ERROR!
12:12:55 > RUNNING TEMP ROOT: OK!
12:12:55 > SEARCHING FOR PHONE:
Old 02-26-2011, 12:24   #35 (permalink)
Member: 58924
Sonork: 1583810
Eplosif update no credit like other BOUUUM
thanks microbox team.
Best forever
BR!
Old 02-27-2011, 18:15   #36 (permalink)
Member: 1441285
wow, this is great update by micro-box team...
its time to say bye bye logs unlock.. now its time for free unlock..
do i need any activation for use this update ??
BR,
XploreUnlock.com
Old 02-28-2011, 07:53   #37 (permalink)
sonitex's Avatar
Member: 229056
Old 02-28-2011, 07:55   #38 (permalink)
sonitex's Avatar
Member: 229056
Manual :
- 1. With PHONE ON go to SETTINGS>APPLICATIONS>DEVELOPMENT and select USB debugging.
- 2. Put not accepted simcard in phone, connect phone to pc and install last ANDROID DRIVERS (FORCED) from support.
- 3. Press READ CODES, after 30 sec will be asked to install new drivers, please use last MICROBOX-SECURE PORT DRIVERS from support.
please read care fully
Old 02-28-2011, 07:57   #39 (permalink)
sonitex's Avatar
Member: 229056
if you face sam error please uninstall driver and reinstall driver all ok if after that you have still same problem plz try to another pc or window
Old 02-28-2011, 21:27   #40 (permalink)
Member: 72951
Thank you for your response but I can see by your log it is firmware version 2.2 Froyo. In my country this version is not yet supported. Phone is sold still with version 1.6 Donut. So my question is still unanswered.....can micro box unlock version 1.6?
Thanks
Old 03-06-2011, 22:07   #41 (permalink)
qwerthj's Avatar
Member: 22902
-Download repairtool from here: Downloads | Streakdroid
-Try flash with it.
-If not working download this: http://streakdroid.com/downloads/djs...treakflash.zip
-Now flash the phone with repairtool again.
If all is ok, your phone have froyo firmware.
WBR
qwerthj
The Following User Says Thank You to qwerthj For This Useful Post:
Old 03-07-2011, 11:50   #42 (permalink)
Member: 129486
Hello micro team can you clear 1.6 is supported? also not working with me.
17:09:03 > VERSION MICRO-BOX A.I.O. V1.0.8.4
17:09:03 > DELL STREAK READ CODES: START!
17:09:03 > KILLING ADB SERVER (IF RUNNING): OK!
17:09:03 > SEARCHING FOR PHONE: OK!
17:09:04 > READING INFO: OK!
17:09:04 > MODEL: Dell Streak / qsd8250_surf
17:09:04 > VERSION: 1.6 / Donut
17:09:05 > FIRMWARE: qsd8250_surf-user / GAUSB1A110421-EU
17:09:05 > KERNEL: 2.6.29-perf (gcc 4.2.1)
17:09:05 > CPU TYPE: ARMv7
17:09:10 > CHECKING ROOT: ERROR!
17:09:46 > RUNNING TEMP ROOT: OK!
17:11:46 > SEARCHING FOR PHONE: ERROR!(TIMEOUT)
17:11:46 > PLEASE RESTART PHONE AND TRY AGAIN!
17:11:46 > DELL STREAK READ CODES: END!
Old 03-11-2011, 11:25   #43 (permalink)
babyelephantt's Avatar
Member: 240665
Anybody tested this?
-Try flash with it.
WBR
qwerthj
Please has anyone tested this solution posted in here? Thanks in advance
Old 03-11-2011, 19:08   #44 (permalink)
qwerthj's Avatar
Member: 22902
Just check my previous post This phone was bricked (hang on boot logo), repaired by this flashes, after unlocked with microbox
WBR
qwerthj
The Following 2 Users Say Thank You to qwerthj For This Useful Post:
Old 03-12-2011, 08:43   #45 (permalink)
Member: 240665
Will do that
WBR
qwerthj
I will do that and give u feedback.
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 10 03-11-2013 15:27
PIN1/PIN2 CODE Jon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 12-26-2012 03:40
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 05-10-2012 14:14
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-16-2011 09:59
Page generated in 0.40917 seconds with 11 queries
