Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Micro-Box Team Products > Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...)
Old 10-01-2009, 03:02   #76 (permalink)
Member: 640944
Sonork: 100.62393
Thanks Meter: 6,965
Originally Posted by fretburner View Post
I cant see SFR232 in the software and the cable to use is gone.It is very usefull to make unlocking a lot easier.
take the last update just use auto update on aio you will get on your computer last software than enjoy with microbox
Old 10-01-2009, 04:34   #77 (permalink)
parengBok's Avatar
Member: 696820
Sonork: 100.1684793
Thanks Meter: 269
very nice update...
making MICROBOX more convinient to use.......
gud work MICROBOX team...
Old 10-01-2009, 09:46   #78 (permalink)
ivanrommel's Avatar
Member: 144777
Sonork: 100.111515
Thanks Meter: 100
amaing update........
hope more surprice to come
Old 10-01-2009, 13:55   #79 (permalink)
Member: 275689
Thanks Meter: 64
Originally Posted by MB code View Post
Cable to use and tel on/off is not gone, you can still see it as HINT over button job,
move mouse over one button or inside jobs window and in short time HINT window will all this info will be visible!
B.R.
MB
I did this, put my mouse over the READ INFO and DIRECT UNLOCK button, and i left the mouse there, but no Hint or message came up, telling me which cable to use. I am using the version AIO 1.0.0.2. What am i doing wrong?
Old 10-01-2009, 13:58   #80 (permalink)
Member: 275689
Thanks Meter: 64
Ok, i got it now, i just realised that you have to use the MODEL SEARCH engine, to type your model and search it and then only the Hint shows when u put your mouse over the READ INFO button.
Old 10-01-2009, 14:02   #81 (permalink)
Member: 275689
Thanks Meter: 64
Have you removed the IMEI REPAIR options for some phone, on this new AIO interface? Coz phones such as samsung m8800 and l810v dont have the IMEI REPAIR options on here, whereas the older Sam softwares do have IMEI REPAIR options. Can you please add these IMEI options to this AIO too. thnx.
Old 10-02-2009, 19:45   #82 (permalink)
Member: 1028392
Thanks Meter: 87
If you can please do the window resizeable! On my pc i get this view!
Thanks!
Old 10-03-2009, 10:11   #83 (permalink)
Member: 275689
Thanks Meter: 64
Thanks!
Try changing your Screen resolution on your computer, make your screen smaller and you might be able to see all of the software. If you using Win XP, then go to MY COMPUTER, CONTROL PANEL, APPEARANCE AND THEMES, DISPLAY, then the SETTING tab and from there, under "screen resolution" try moving the cursor across to make your screen smaller.
Hope it helps.
Old 10-03-2009, 12:45   #84 (permalink)
Member: 1028392
Thanks Meter: 87
Hope it helps.
Hi, I need to keep the resolution and i can't change it everytime i connect the box. (the pc MUST be restarted and all icon mess up).
The resizeable window is an easy and useful function to add in the code.
Old 10-03-2009, 15:18   #85 (permalink)
Member: 275689
Thanks Meter: 64
if you change your resolution, then it should stay that way, and it should not mess up your icons. maybe you need to change your grafix card. get a more powerful grafix card or download a newer version of software for your grafix card.
Old 10-03-2009, 21:33   #86 (permalink)
Member: 1028392
Thanks Meter: 87
thanks , can' tchange the vga in notebook.
I ask the development for the resizeable window , need to add only one line in the code.
Thanks !
Old 10-22-2009, 20:34   #87 (permalink)
Crazy Poster
Member: 905584
Thanks Meter: 16
if possible to unlock the sfr232
This is the error I have.
12:18:38> VERSION MICRO-BOX A.I.O. V1.0.0.8
12:18:38> SFR 232 UNLOCK: START!
12:18:38> PREPAIRING DATA: OK!
12:18:42> PRESS POWER: OK! DO NOT RELEASE POWER!
12:18:51> Sending preloader: OK! CAN RELEASE POWER!
12:18:54> SENDING LOADER: OK!
12:18:54> SET SPEED: OK!
12:18:54> Reading CPU ID: OK!
12:18:54> READING NOR FLASH INFO: OK!
12:18:54> READING NAND FLASH INFO: NOT AVAILABLE!
12:18:54> Detecting VERSION SIGNED BY: UNKNOWN VERSION!
12:18:57> READING VERSION FROM EEPROM: ERROR 1001!
12:18:57> READING IMEI: ERROR 1007!
12:18:58> SFR 232 UNLOCK:
Old 10-23-2009, 19:02   #88 (permalink)
bilm25's Avatar
Member: 78657
Thanks Meter: 71
MicroBoxALLinONE V1.0.0.8 CR FINAL why dont use cable model like old software
Old 12-28-2009, 16:50   #89 (permalink)
Member: 360580
hello.
i have the same problem with screen resolution,have tried what it says in above post,still no changeand you cannot extend boxes
thanxs
Old 12-29-2009, 11:24   #90 (permalink)
Member: 695543
Sonork: 100.1602536
Thanks Meter: 149
hi .thanx for update .but this is not much better gift.tell me where is vodafone model in this update.
JAF new update 1.98.64_fix is ready! gsmfun J.A.F. By Jafsupport.com 88 08-20-2010 07:41
Microbox for TUNISIAN unlockers, new stock is ready with new cables set, REALLY HOT!! midou01 Main Sales Section 0 10-08-2008 00:13
Nokia N95 Slideing Is Ready With multi mukesh_b Chinese Cocktail 0 10-25-2007 08:26
===are You Ready For Cyclone Update ??? Your Usb-smart Is Ready !!!=== OvidelGSM Main Sales Section 0 02-20-2006 17:31
Page generated in 0.28278 seconds with 11 queries
