06-10-2011, 07:19 | #16 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RO, Nasaud
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | @mophat @all having this problem As a temporary solution if you're having this problem please upgrade your firmware until the bug is solved. WBR, gsm9l |
06-10-2011, 09:00 | #17 (permalink) | |
Freak Poster Join Date: Jul 2006 Location: lusaka
Member: 320108 Status: Offline Thanks Meter: 18 | Quote:
which firmware do we upgrade phone or box 09:50:18 > VERSION MICRO-BOX A.I.O. V2.0.1.5 09:50:18 > SAMSUNG T959 READ CODES: START! 09:50:18 > KILLING ADB SERVER (IF RUNNING): OK! 09:50:18 > SEARCHING FOR PHONE: OK! 09:50:19 > READING INFO: OK! 09:50:19 > MODEL: SGH-T959 / SGH-T959 09:50:19 > IMEI: 351801043182175 09:50:19 > VERSION: 2.1-UPDATE1 / ECLAIR 09:50:19 > FIRMWARE: SGH-T959-USER / T959UVJE8 09:50:19 > KERNEL: 2.6.29 (gcc 4.3.1) 09:50:19 > CPU TYPE: S5PC110 / ARMv7 09:50:26 > CHECKING ROOT: OK! 09:50:44 > READING DATA: OK! 09:50:45 > CHECKING SERVER 1: OK! 09:50:45 > CONNECTING TO SERVER: OK! 09:50:47 > ASKING SERVER FOR ACCESS: ACCEPTED! 09:50:49 > SENDING DATA TO SERVER: OK! 09:50:55 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 09:50:55 > CODES NOT FOUND! 09:50:55 > DISCONNECTING FROM SERVER: OK! 09:50:56 > SAMSUNG T959 READ CODES: END! | |
06-10-2011, 09:13 | #18 (permalink) |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | 2.2.1 or even 2.3.3 but for this you need to patch and root the phone by yourself - it's not hard if you chose this I will give you instructions if you don't find in forum. WBR, gsm9l |
06-14-2011, 21:50 | #20 (permalink) |
No Life Poster Join Date: Feb 2006 Location: campioni del mondo
Member: 235881 Status: Offline Thanks Meter: 221 | thanks tested and worked unlock i9003 MODEL: GT-I9003 / GT-I9003 13:34:53 > IMEI: 3549490 13:34:53 > VERSION: 2.2.1 / FROYO 13:34:53 > FIRMWARE: GT-I9003-USER / I9003XXKB1 13:34:53 > KERNEL: 2.6.32.9 (gcc 4.4.0) 13:34:53 > CPU TYPE: OMAP3 / ARMv7 13:34:53 > CHECKING ROOT: 13:34:58 > CHECKING ROOT: NOT ROOTED! 13:34:59 > RUNNING TEMP ROOT: 13:35:18 > RUNNING TEMP ROOT: OK! 13:35:18 > SEARCHING FOR PHONE: 13:35:41 > SEARCHING FOR PHONE: OK! 13:35:42 > CHECKING ROOT: 13:35:44 > CHECKING ROOT: OK! 13:35:44 > READING DATA: 13:36:03 > READING DATA: OK! 13:36:04 > CHECKING SERVER 1: 13:36:04 > CHECKING SERVER 1: OK! 13:36:04 > CONNECTING TO SERVER: 13:36:04 > CONNECTING TO SERVER: OK! 13:36:04 > ASKING SERVER FOR ACCESS: 13:36:05 > ASKING SERVER FOR ACCESS: ACCEPTED! 13:36:05 > SENDING DATA TO SERVER: 13:36:06 > SENDING DATA TO SERVER: OK! 13:36:06 > CALCULATING [BY SERVER] PLEASE WAIT: 13:36:14 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 13:36:14 > FREEZE CODE: 00000000 13:36:14 > NET CODE: 28580648 13:36:14 > SP CODE: 00000000 13:36:14 > CP CODE: 00000000 13:36:14 > SIM CODE: 00000000 |
06-15-2011, 15:16 | #21 (permalink) |
Member: 320108 Status: Offline Thanks Meter: 18 | i still can get the codes can some one help how to do it 16:11:18 > VERSION MICRO-BOX A.I.O. V2.0.1.5 16:11:18 > SAMSUNG T959 READ CODES: START! 16:11:18 > KILLING ADB SERVER (IF RUNNING): OK! 16:11:18 > SEARCHING FOR PHONE: OK! 16:11:19 > READING INFO: OK! 16:11:19 > MODEL: SGH-T959 / SGH-T959 16:11:19 > IMEI: 351801043182175 16:11:19 > VERSION: 2.1-UPDATE1 / ECLAIR 16:11:19 > FIRMWARE: SGH-T959-USER / T959UVJE8 16:11:19 > KERNEL: 2.6.29 (gcc 4.3.1) 16:11:19 > CPU TYPE: S5PC110 / ARMv7 16:11:26 > CHECKING ROOT: OK! 16:11:44 > READING DATA: OK! 16:11:46 > CHECKING SERVER 1: OK! 16:11:46 > CONNECTING TO SERVER: OK! 16:11:48 > ASKING SERVER FOR ACCESS: ACCEPTED! 16:11:52 > SENDING DATA TO SERVER: OK! 16:11:55 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 16:11:55 > CODES NOT FOUND! 16:11:55 > DISCONNECTING FROM SERVER: OK! 16:11:56 > SAMSUNG T959 READ CODES: END! |
06-15-2011, 16:13 | #22 (permalink) | |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Quote:
WBR, gsm9l | |
06-16-2011, 10:03 | #23 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 35
Member: 185119 Status: Offline Thanks Meter: 91 | 16:59:07 > VERSION MICRO-BOX A.I.O. V2.0.1.5 16:59:07 > SAMSUNG I9000 JAPAN READ INFO: START! 16:59:07 > KILLING ADB SERVER (IF RUNNING): OK! 16:59:07 > SEARCHING FOR PHONE: OK! 16:59:08 > READING INFO: OK! 16:59:14 > CHECKING ROOT: NOT ROOTED! 16:59:14 > MODEL: SC-02B / SC-02B 16:59:14 > IMEI: 353975041811726 16:59:14 > VERSION: 2.2 / FROYO 16:59:14 > FIRMWARE: SC-02B-USER / SC02BOMJJ1 16:59:14 > KERNEL: 2.6.32.9 (gcc 4.4.1) 16:59:14 > CPU TYPE: S5PC110 / ARMv7 16:59:14 > SAMSUNG I9000 JAPAN READ INFO: END! 16:59:19 > VERSION MICRO-BOX A.I.O. V2.0.1.5 16:59:19 > SAMSUNG I9000 JAPAN READ CODES: START! 16:59:19 > KILLING ADB SERVER (IF RUNNING): OK! 16:59:19 > SEARCHING FOR PHONE: OK! 16:59:20 > READING INFO: OK! 16:59:21 > MODEL: SC-02B / SC-02B 16:59:21 > IMEI: 353975041811726 16:59:21 > VERSION: 2.2 / FROYO 16:59:21 > FIRMWARE: SC-02B-USER / SC02BOMJJ1 16:59:21 > KERNEL: 2.6.32.9 (gcc 4.4.1) 16:59:21 > CPU TYPE: S5PC110 / ARMv7 16:59:26 > CHECKING ROOT: NOT ROOTED! 16:59:48 > RUNNING TEMP ROOT: OK! 16:59:49 > SEARCHING FOR PHONE: OK! 16:59:55 > CHECKING ROOT: NOT ROOTED! 16:59:55 > PLEASE RESTART PHONE AND TRY AGAIN! 16:59:55 > SAMSUNG I9000 JAPAN READ CODES: END! i9000 japan plss help me on this one!!! |
06-16-2011, 10:09 | #24 (permalink) |
Member: 185119 Status: Offline Thanks Meter: 91 | 17:09:01 > SAMSUNG I9000 JAPAN READ CODES: START! 17:09:01 > KILLING ADB SERVER (IF RUNNING): OK! 17:09:01 > SEARCHING FOR PHONE: OK! 17:09:01 > READING INFO: OK! 17:09:02 > MODEL: SC-02B / SC-02B 17:09:02 > IMEI: 353975041811726 17:09:02 > VERSION: 2.2 / FROYO 17:09:02 > FIRMWARE: SC-02B-USER / SC02BOMJJ1 17:09:02 > KERNEL: 2.6.32.9 (gcc 4.4.1) 17:09:02 > CPU TYPE: S5PC110 / ARMv7 17:09:07 > CHECKING ROOT: NOT ROOTED! 17:09:21 > RUNNING TEMP ROOT: OK! 17:09:21 > SEARCHING FOR PHONE: OK! 17:09:23 > CHECKING ROOT: OK! 17:09:41 > READING DATA: OK! 17:09:41 > UNSUPPORTED DATA FOUND! SENDING DATA TO SERVER FOR DEVELOPMENT! 17:09:42 > CHECKING SERVER 1: OK! 17:09:42 > CONNECTING TO SERVER: OK! 17:09:46 > ASKING SERVER FOR ACCESS: ACCEPTED! 17:09:47 > SENDING DATA TO SERVER: OK! 17:09:47 > DISCONNECTING FROM SERVER: OK! 17:09:48 > READING DATA: ERROR 1009! 17:09:48 > SAMSUNG I9000 JAPAN READ CODES: END! i cant read codes.... |
06-16-2011, 10:26 | #25 (permalink) | |
WBR, gsm9l | |
06-17-2011, 14:13 | #26 (permalink) |
Member: 320108 Status: Offline Thanks Meter: 18 | hey finally got the code thanx microbox team 11:46:45 > SAMSUNG T959 READ CODES: END! 11:47:00 > VERSION MICRO-BOX A.I.O. V2.0.1.6 11:47:00 > SAMSUNG T959 READ CODES: START! 11:47:00 > KILLING ADB SERVER (IF RUNNING): OK! 11:47:00 > SEARCHING FOR PHONE: OK! 11:47:01 > READING INFO: OK! 11:47:01 > MODEL: SGH-T959 / SGH-T959 11:47:02 > IMEI: 351801043182175 11:47:02 > VERSION: 2.1-UPDATE1 / ECLAIR 11:47:02 > FIRMWARE: SGH-T959-USER / T959UVJE8 11:47:02 > KERNEL: 2.6.29 (gcc 4.3.1) 11:47:02 > CPU TYPE: S5PC110 / ARMv7 11:47:09 > CHECKING ROOT: OK! 11:47:28 > READING DATA: OK! 11:47:31 > CHECKING SERVER 1: OK! 11:47:31 > CONNECTING TO SERVER: OK! 11:47:33 > ASKING SERVER FOR ACCESS: ACCEPTED! 11:47:39 > SENDING DATA TO SERVER: OK! 11:47:42 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 11:47:42 > FREEZE CODE: 00000000 11:47:42 > NET CODE: 9xxxxxxx 11:47:42 > SP CODE: 00000000 11:47:42 > CP CODE: 00000000 11:47:42 > SIM CODE: 00000000 11:47:42 > DISCONNECTING FROM SERVER: OK! 11:47:43 > SAMSUNG T959 READ CODES: END! |
07-11-2011, 15:42 | #27 (permalink) |
Insane Poster Join Date: Oct 2007 Location: Sofia, Bulgaria Age: 39
Member: 607934 Status: Offline Thanks Meter: 6 | Problem T959 17:38:33 > VERSION MICRO-BOX A.I.O. V2.0.1.9 17:38:33 > SAMSUNG T959 READ CODES: START! 17:38:33 > KILLING ADB SERVER (IF RUNNING): OK! 17:38:33 > SEARCHING FOR PHONE: OK! 17:38:34 > READING INFO: OK! 17:38:34 > MODEL: SGH-T959V / SGH-T959V 17:38:34 > IMEI: 355299045693560 17:38:34 > VERSION: 2.2.1 / FROYO 17:38:34 > FIRMWARE: SGH-T959V-USER / T959VUVKB5 17:38:34 > KERNEL: 2.6.32.9 (gcc 4.4.1) 17:38:34 > CPU TYPE: S5PC110 / ARMv7 17:38:34 > CARD ID: 0353445355313647800D693A6B00B300 17:38:39 > CHECKING ROOT: NOT ROOTED! 17:38:52 > RUNNING TEMP ROOT: OK! 17:38:52 > SEARCHING FOR PHONE: OK! 17:38:53 > CHECKING ROOT: OK! 17:39:07 > READING DATA: ERROR 1005! 17:39:07 > SAMSUNG T959 READ CODES: END! |
07-12-2011, 10:23 | #29 (permalink) |
No Life Poster Join Date: May 2005 Location: MIND MAKING COMPANY Age: 44
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | 14:18:37 > VERSION MICRO-BOX A.I.O. V2.0.1.9 14:18:38 > SAMSUNG T959 READ CODES: START! 14:18:38 > KILLING ADB SERVER (IF RUNNING): OK! 14:19:24 > SEARCHING FOR PHONE: ABORTED! 14:19:25 > SAMSUNG T959 READ CODES: END! 14:19:27 > VERSION MICRO-BOX A.I.O. V2.0.1.9 14:19:27 > SAMSUNG T959 READ CODES: START! 14:19:27 > KILLING ADB SERVER (IF RUNNING): OK! 14:20:02 > SEARCHING FOR PHONE: OK! 14:20:03 > READING INFO: OK! 14:20:04 > MODEL: SGH-T959V / SGH-T959V 14:20:04 > IMEI: 3552990427XXXXX 14:20:04 > VERSION: 2.2.1 / FROYO 14:20:04 > FIRMWARE: SGH-T959V-USER / T959VUVKB5 14:20:04 > KERNEL: 2.6.32.9 (gcc 4.4.1) 14:20:04 > CPU TYPE: S5PC110 / ARMv7 14:20:10 > CHECKING ROOT: NOT ROOTED! 14:20:23 > RUNNING TEMP ROOT: OK! 14:20:25 > SEARCHING FOR PHONE: OK! 14:20:26 > CHECKING ROOT: OK! 14:20:40 > READING DATA: ERROR 1005! 14:20:40 > SAMSUNG T959 READ CODES: END! |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
