ALCATEL OT-708 UNLOCK how do i enter nck???[ANSWERED & SOLVED] i have just got the nck code for this alc but when wrong card is inserted all it says invalid sim then goes into the main screen how do i find the nck input screen?? regards stemo |
For new Alcatels phone code just press *#power and ok to format after that you can enter code and post result |
but i take it you dont know what a ot-708 looks like?? |
Insert Valid Sim Card In To Phone When Phone Ask Enter Code Put There Code |
I have solved it. the wrong network sim i was putting in was dead and this is why it showed invalid sim i put a wrong working sim and it bought up the nck code screen ;) |
Thanks for you understanding .Keep it up! Quote:
Vodafone 541 simcard locked i HAVE GOT A VODAFONE 541 SAMA AS ALCATEL OT708 I HAVE READ THE NCK CODE BUT WHEN I TRY TO PUT IN A WRONG VALID SIMCARD IT DOES'NT GIVE ME AN OPTION OF ENTERING NCK CODE INSTEAD TELLS ME SIMCARD LOCKED. WHAT COULD BE WRONG WITH THE PHONE??? DOES IT HAS A SOLUTION:confused::confused::confused::confused::c onfused: |
Try one of these options Quote:
Model : Method Generic 1 - Switch ON your phone without SIM Card, 2 - Then compose : *#0000*CODE#, 3 - To finish compose : *#0001*CODE#. Model : 531 & 535 1 - Switch ON your phone without SIM Card, 2 - Press * and without release compose 787292, 3 - A new menu "Unlock Network" will appear, then select "YES", 4 - Enter the Code we send to you. Model : All other Alcatel 1 - Switch on your phone with a not allowed SIM Card, 2 - When the message "Enter Network Key" appear enter the Code we send to you Model : Method Generic 1 - Switch ON your phone without SIM Card, 2 - Then compose : *#0000*CODE#, 3 - To finish compose : *#0001*CODE#. Model : 531 & 535 1 - Switch ON your phone without SIM Card, 2 - Press * and without release compose 787292, 3 - A new menu "Unlock Network" will appear, then select "YES", 4 - Enter the Code we send to you. Model : All other Alcatel 1 - Switch on your phone with a not allowed SIM Card, 2 - When the message "Enter Network Key" appear enter the Code we send to you Hope this helps you |
how to enter network unlock codes please how to enter network unlock codes into alcatel ot 708 help n give asolution |
Phone should ask for code when you insert an unsupported sim. WBR, gsm9l;) |
Unlocking alcatel ot 918 Hey finally i got it and done with infinity go to infinity shell and open it select the and run after click on sp unlock, connect the phone com port cable and power it manually |
