09-09-2009, 12:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 14047 Status: Offline Thanks Meter: 166 | big problem installing driver for this box!!!! |
09-09-2009, 17:28 | #2 (permalink) |
Freak Poster Join Date: Mar 2004 Location: U.K www.PhoneandIT.com
Member: 59991 Status: Offline Thanks Meter: 40 | read this please http://forum.gsmhosting.com/vbb/showthread.php?t=484958 As windows take this driver as unsigned, so you have to install it manually.. Go to device manager. click on + with PORTS Double click on AVL VT port after installation with normal driver procedure, It will come under ports section. 1. Double click on allocated Port 2. Go to Drivers and select UPDATE driver. select YES THIS TIME ONLY 3. Choose "Install from List or specific Location". click NEXT 4. select "Don't search I will select the dirver to Install" and click NEXT 5. Now click on "SHOW COMPATIBLE DRIVER" and then Click "HAVE DISK" 6. NOW BROWSE to the folder where the orignaly drivers are present. Now you will see MICROBOX under the models.. select and next next next also turn off any firewalls, and use direct USB port.. do not use any USB HUBS etc.. |
problem installing driver for hauwei u3300 | zeeshan tayyab | FuriousGold | 7 | 10-09-2010 22:03 |
problem instaling driver with N-box with hwk | sameenshah123 | HWK | 1 | 03-02-2009 11:52 |
Need vista drivers for this box! support??? | ReyTech | PolarBox 3 | 1 | 02-27-2008 13:36 |
Pls check this Error messages i have recieved during installing drivers for MPX200 ! | AE177 | UniMoto | 4 | 08-04-2004 18:38 |
