Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Micro-Box Team Products > Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...)
Old 09-14-2013, 18:10   #1 (permalink)
Member: 133351
Thanks Meter: 20
blackberry wrong codes [Answered]
Hi
i got some phones now when reading in from microbox , all reads ok
but the calculated codes returned are wrong and not accepted by the phone
this happens on new blackberry 9320 from digicel
SIMLOCK: MEP-14896-006
any suggestions?
Old 09-17-2013, 10:33   #2 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,102
Codes are correct, do you have codes imput left? Post the log.
WBR,
gsm9l
Old 09-17-2013, 16:43   #3 (permalink)
Member: 133351
Thanks Meter: 20
Hi thanks for the reply
i give the error wrong code entered
the codes are calculated but not accepted by the blackberry
i have the logs of the code being calculated , that is all ok , but when entering the mep2 code always wrong
and it begins to count down
wbr
Vishal
Old 09-17-2013, 16:45   #4 (permalink)
Member: 133351
Thanks Meter: 20
12:13:11 > SEARCHING FOR PHONE: OK!
12:13:12 > READING IMEI: OK!
12:13:12 > READING SECURITY DATA: OK!
12:13:12 > IMEI: 355571057874928
12:13:12 > SIMLOCK: MEP-14896-006
12:13:13 > CALCULATING: OK!
12:13:13 > IMEI: 355571057874928
12:13:13 > SIMLOCK: MEP-14896-006
12:13:14 > NCK CODE: 3571742748280943
12:13:14 > SPCK CODE: 1078461146614687
12:13:14 > SIM CODE: 2232358230135545
12:13:14 > SUBS CODE: 9952643051537637
12:13:14 > CP CODE: 2297611770558658
12:13:14 > HOW TO: Insert any sim card and power ON phone
12:13:14 > Turn off all wireless connections
12:13:14 > Go to Options/Advanced Options/SIM Card
12:13:15 > Press menu select for show keyboard (if needed)
12:13:15 > Type MEPPD or MEPD (will not see when type)
12:13:15 > Type MEP2 or MEPP2 (will not see when type)
12:13:15 > Enter corresponding mep code
12:13:15 > BLACKBERRY 9320 READ CODES: END!
Old 09-17-2013, 22:27   #5 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Now on market new BB 9320 that mep readed from phone is not correct and even code by PRD are not correct you should get 1 phone and check all tool that are on market can't calc good codes and this is not network problem but model problem 9320 from 2013 year only and I think all new models that will be relised in this year will be same.
Old 09-18-2013, 07:58   #6 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,102
Disable your WIFI and be sure you enter correct NCK in phone.
WBR,
gsm9l
Old 09-20-2013, 00:54   #7 (permalink)
Member: 133351
Thanks Meter: 20
ok i will try that
but wifi was enabled but not connected to any AP when i tried the codes
i do enter the correct code
mep2 = the first code that gets calculated , as far as i know
Old 09-20-2013, 12:22   #8 (permalink)
julvir's Avatar
Member: 3173
Sonork: 100.100
Thanks Meter: 17,098
YES he right, all 9320 from 2013 have that problem , they maybe change the mep algo ..
we will need one phone in hand to reverse it
Old 09-20-2013, 15:40   #9 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Phone cost 130 euro(new one from orange poland) + 40 euro courier in EU if interesing give me know by sonork or PW.
Same problem is in new BB 9900 from 08.2013 and newest but this model support lgtool direct unlock then not lots people write about this.
Old 09-20-2013, 22:43   #10 (permalink)
Member: 133351
Thanks Meter: 20
i hope you get a phone soon. Yes i also think the algo has been changed because the codes get calculated but not accepted
Old 11-13-2013, 00:19   #11 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
same here 9320 from wind canada try a view tools and all same wrong code, even online infinity wrong.
Page generated in 0.19122 seconds with 8 queries
