Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Micro-BoxTeam Products > Basic Micro-Box Software Support
Old 05-10-2012, 10:45   #1 (permalink)
Member: 1725224
Box not working after "Box Update" [Solved]
Hi,
i downloaded last version of microbox MicroBoxALLinONE V2.0.9.3 CR FINAL.
my box was working well and so on.
i wanted to update the box too and i clicked button "UPDATE BOX" (in Support and settings" section)
Here is log:
11:13:37 > READ BOX INFO: START!
11:13:39 > SEARCHING FOR MICRO-BOX: FOUND!
11:13:40 > READING MICRO-BOX SN: OK!
11:13:40 > READING MICRO-BOX VERSIONS: OK!
11:13:40 > MICRO-BOX SN: B57D96DFE4F8E108
11:13:40 > MICRO-BOX FW: 70
11:13:40 > BOOT VERSION: 50
11:13:40 > ALCATEL: NOT ACTIVATED!
11:13:40 > BLACKBERRY: NOT ACTIVATED!
11:13:40 > HTC: NOT ACTIVATED!
11:13:40 > LG: NOT ACTIVATED!
11:13:40 > SAGEM: NOT ACTIVATED!
11:13:40 > READ BOX INFO: END!
11:14:27 > READ BOX INFO: START!
11:14:29 > SEARCHING FOR MICRO-BOX: FOUND!
11:14:29 > READING MICRO-BOX SN: OK!
11:14:29 > READING MICRO-BOX VERSIONS: OK!
11:14:29 > MICRO-BOX SN: B57D96DFE4F8E108
11:14:29 > MICRO-BOX FW: 70
11:14:29 > BOOT VERSION: 50
11:14:29 > READ BOX INFO: END!
11:14:29 > UPDATE BOX: START!
11:14:29 > CHECKING SERVER 1: OK!
11:14:30 > CONNECTING TO SERVER: OK!
11:14:30 > ASKING SERVER FOR ACCESS: ACCEPTED!
11:14:31 > GETTING DATA FROM SERVER: OK!
11:14:31 > FLASHING APP: START!
11:14:32 > RESETING MICRO-BOX: OK!
11:14:42 > FLASHING: ERROR!
11:14:42 > FLASHING APP: END!
11:14:42 > DISCONNECTING FROM SERVER: OK!
11:14:47 > UPDATE BOX: END!
11:14:47 > READ BOX INFO: START!
11:15:29 > SEARCHING FOR MICRO-BOX: NOT FOUND!
11:15:48 > RESETING MICRO-BOX: OK!
11:15:59 > SEARCHING FOR MICRO-BOX: NOT FOUND!
11:15:59 > READ BOX INFO: END!
11:16:00 > BOX DISCONNECTED: ERROR!
11:16:20 > CONNECT TO BOX: START!
11:16:32 > SEARCHING FOR MICRO-BOX: NOT FOUND!
11:17:08 > CONNECT TO BOX: END!
11:17:09 > BOX DISCONNECTED: ERROR!
After that my box is no longer detected !!!
i tried changing usb port : win7 32b shows "Unknown device" and this one doesn'it appear in "Device Manager"
Help
What should i do ?
Regards
Old 05-10-2012, 12:22   #2 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Have you made Micro-Box Hardware modification correctly ?
Also try update with a lower version of Micro-Box AIO.
WBR,
gsm9l
Old 05-10-2012, 14:36   #3 (permalink)
Member: 1725224
WBR,
gsm9l
I have just installed last version and clicked "Update Box".
I have just tried on WinXP : drivers installed, box is recognized by os, but it doesn't appear in "Device Manager" so the box is still "not found" by softwares MicroBoxALLinONE and Updater.
Did i miss to do something ?
Old 05-10-2012, 14:44   #4 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
contact me on sonork for a team viewer sesion. Sonork: 100.1575777
WBR,
gsm9l
The Following User Says Thank You to gsm9l For This Useful Post:
Old 05-10-2012, 16:13   #5 (permalink)
Member: 1725224
Thank you very much.
Excellent support +++
my gpgdragon box not work after update firmware 1.59...Solved m.awais.as Dragon Box 11 12-30-2011 13:55
Page generated in 0.23744 seconds with 11 queries
