Cannot find libusb0.dll please reinstall. [Solved] W7 64 Reinstalled many times. Rebooted. libusb0.dll copied to system32 folder Still getting this error. Please help! |
1 Attachment(s) Copy attached dll into your micro-box folder. |
Resolved but now "not found" I've found this but not helped. :( Code: Go to device manager. |
Reinstall Micro-Box Driver then as Computer Administrator! WBR, gsm9l;) |
Did you solved your problem ? WBR, gsm9l;) |
done. resolved repeating all the steps again and again |
01:42:39 > BOX COMMUNICATION: ERROR! 01:42:43 > CONNECT TO BOX: START! 01:42:52 > SEARCHING FOR MICRO-BOX: FOUND! 01:42:55 > READING MICRO-BOX SN: OK! 01:42:57 > READING MICRO-BOX VERSIONS: ERROR 1001! 01:43:08 > RESETING MICRO-BOX: OK! 01:43:14 > SEARCHING FOR MICRO-BOX: FOUND! 01:43:17 > READING MICRO-BOX SN: OK! 01:43:20 > READING MICRO-BOX VERSIONS: ERROR 1001! 01:43:21 > MICRO-BOX SN: D177notpublic 01:43:21 > MICRO-BOX FW: ? 01:43:21 > BOOT VERSION: ? 01:43:21 > NAME: 01:43:21 > EMAIL: 01:43:21 > RESELLER: 01:43:21 > PHONE: 01:43:21 > WEBSITE: 01:43:21 > CONNECT TO BOX: END! 01:43:23 > BOX COMMUNICATION: ERROR! How many hours need to spend more to get it work under w7 64bit? :eek: OK DONE. replace .exe with latest. |
:) I see you manage to solve it finaly, but realy sometime is good to take a look to release notes before starting to install, update etc. It was said before what to do to install corectly on different systems, also about update box what to do. Instead of spending many hours doing blindly work sometime is goot to read or ask support in proper mode. Anytime you have problems or not only we are here to help you. WBR, gsm9l;) |
huuuh!! thanks it worked for me very well just extract the file to medusa folder and ur good! |
Yes you are right, if have also installed Meduda Box, can use our "libusb0" for togheter, (our file is most recent), or just replace with other of Medusa for to have only one "libusb0" and any conflict. NOTE: Our "libusb0" is Signed so more good for SO win 7 64 bit. BR allumts |
