Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Micro-Box Team Products > Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...)
Old 06-12-2011, 18:28   #1 (permalink)
Member: 1028392
Thanks Meter: 87
Cannot find libusb0.dll please reinstall. [Solved]
W7 64 Reinstalled many times. Rebooted. libusb0.dll copied to system32 folder Still getting this error. Please help!
Old 06-13-2011, 13:12   #2 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,080
Copy attached dll into your micro-box folder.
Old 06-13-2011, 18:07   #3 (permalink)
Member: 1028392
Thanks Meter: 87
Resolved but now "not found"
I've found this but not helped.
Go to device manager.
click on + with PORTS
Double click on AVL VT port
after installation with normal driver procedure, It will come under ports section.
1. Double click on allocated Port
2. Go to Drivers and select UPDATE driver. select YES THIS TIME ONLY
3. Choose "Install from List or specific Location". click NEXT
4. select "Don't search I will select the dirver to Install" and click NEXT
5. Now click on "SHOW COMPATIBLE DRIVER" and then Click "HAVE DISK"
6. NOW BROWSE to the folder where the orignaly drivers are present. Now  you will see MICROBOX under the models.. select and next next next
Old 06-14-2011, 10:08   #4 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,080
Reinstall Micro-Box Driver then as Computer Administrator!
WBR,
gsm9l
Old 06-14-2011, 18:33   #5 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,080
Did you solved your problem ?
WBR,
gsm9l
Old 06-30-2011, 22:44   #6 (permalink)
Member: 1028392
Thanks Meter: 87
WBR,
gsm9l
No. i'm still having problem on w7 64bit . i will try install the latest now..
Old 06-30-2011, 23:16   #7 (permalink)
Member: 1028392
Thanks Meter: 87
not working: not found
Old 07-01-2011, 01:14   #8 (permalink)
Member: 1028392
Thanks Meter: 87
done. resolved repeating all the steps again and again
Old 07-01-2011, 01:47   #9 (permalink)
Member: 1028392
Thanks Meter: 87
after reboot:
01:42:39 > BOX COMMUNICATION: ERROR!
01:42:43 > CONNECT TO BOX: START!
01:42:52 > SEARCHING FOR MICRO-BOX: FOUND!
01:42:55 > READING MICRO-BOX SN: OK!
01:42:57 > READING MICRO-BOX VERSIONS: ERROR 1001!
01:43:08 > RESETING MICRO-BOX: OK!
01:43:14 > SEARCHING FOR MICRO-BOX: FOUND!
01:43:17 > READING MICRO-BOX SN: OK!
01:43:20 > READING MICRO-BOX VERSIONS: ERROR 1001!
01:43:21 > MICRO-BOX SN: D177notpublic
01:43:21 > MICRO-BOX FW: ?
01:43:21 > BOOT VERSION: ?
01:43:21 > NAME:
01:43:21 > EMAIL:
01:43:21 > RESELLER:
01:43:21 > PHONE:
01:43:21 > WEBSITE:
01:43:21 > CONNECT TO BOX: END!
01:43:23 > BOX COMMUNICATION: ERROR!
How many hours need to spend more to get it work under w7 64bit?
OK DONE. replace .exe with latest.
Old 07-01-2011, 10:19   #10 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,080
I see you manage to solve it finaly, but realy sometime is good to take a look to release notes before starting to install, update etc. It was said before what to do to install corectly on different systems, also about update box what to do. Instead of spending many hours doing blindly work sometime is goot to read or ask support in proper mode.
Anytime you have problems or not only we are here to help you.
WBR,
gsm9l
The Following User Says Thank You to gsm9l For This Useful Post:
Old 11-04-2015, 23:39   #11 (permalink)
Member: 2398349
Thanks Meter: 58
huuuh!! thanks it worked for me very well
just extract the file to medusa folder and ur good!
Old 11-25-2015, 14:16   #12 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,576
Yes you are right, if have also installed Meduda Box, can use our "libusb0" for togheter, (our file is most recent), or just replace with other of Medusa for to have only one "libusb0" and any conflict.
NOTE: Our "libusb0" is Signed so more good for SO win 7 64 bit.
allumts
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 14:21
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 16:48
dk2win16.dll for nokia????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-15-1999 16:15
Page generated in 0.39065 seconds with 9 queries
