01-19-2008, 01:06 | #1 (permalink) |
Insane Poster Join Date: Oct 2005 Location: netherlands Age: 61
Member: 187801 Status: Offline Thanks Meter: 6 | e227 not read codes i try modfy kabel to go deeper no working . 1 kabel is now whit broken connector. is it possibel for alcatel new vle to choose unibox in the program ? because work now only whit micro-box port. sorry for bad englisch i must wait for better kabels from micro-box |
01-19-2008, 01:21 | #3 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 640944 Status: Offline Sonork: 100.62393 Thanks Meter: 6,965 | 1- Upgrade Your box with updater software last firmware must be 60 2- connect your phone with cable E256 if cable cannot enter cut little the plastic of your cable for can enter easy 3- select new vle click on read code after when software say press on you just push power button of you phone and when software detect release button and wait end of procedure 4- if the phone power on mean cable not make good connection with phone so make your best for you do the best as you can 5-you need remove battery and put back if you was press the button power from the phone and no communication with the phone 6- sorry for all customer for not givecable new vle E207/ E101 This cable was not exist we are making this cable now wait few days cable will be avaible from ressellers of micro box Last edited by samigsm78; 01-19-2008 at 01:31. |
Problem with Z170. Multiclient are down? Not read codes and not make anything | Grupo MovilFree | KULANKENDI Server | 4 | 03-31-2008 11:40 |
E250 do not unlock direct and do not read codes | market_3b2002 | UST Pro II | 9 | 02-06-2008 08:14 |
FG BOX can not read codes from blackberry | karikari | FuriousGold | 5 | 09-06-2007 15:46 |
Z300 can not read code with new arm 2.3 | bestncheap | MT-BOX | 8 | 05-18-2007 18:14 |
Could not Read Codes on T610 | thcoms | SonyEricsson (USB-Smart) | 0 | 12-03-2005 21:07 |
