Galaxy S 2 Unlock??? Help [Solved] How to unlock I9100 with microbox?? I need correct ADB drivers. Please add a download link for drivers for I9100 I have installed Kies 2.0 but Device not found with debuging on. Please write down how to unlock I9100 Thanks |
Hi, Download original drivers (From samsung - KIES), restart your computer, connect your device and try again. WBR, gsm9l;) |
18:16:28 > SAMSUNG GALAXY S2 READ INFO: START! 18:16:29 > KILLING ADB SERVER (IF RUNNING): OK! 18:16:58 > SEARCHING FOR PHONE: OK! 18:17:00 > READING INFO: OK! 18:17:05 > CHECKING ROOT: NOT ROOTED! 18:17:05 > MODEL: GT-I9100 / GT-I9100 18:17:05 > IMEI: 3553xxxxxxxxxxxxxxxxxxx 18:17:05 > VERSION: 2.3.3 / GINGERBREAD 18:17:05 > FIRMWARE: GT-I9100-USER / I9100XXKDJ 18:17:05 > KERNEL: 2.6.35.7-I9100XWKE1-CL181974 (gcc 4.4.0) 18:17:05 > CPU TYPE: S5PC210 / ARMv7 18:17:06 > SAMSUNG GALAXY S2 READ INFO: END! 18:17:09 > VERSION MICRO-BOX A.I.O. V2.0.0.9 18:17:09 > SAMSUNG GALAXY S2 READ CODES: START! 18:17:09 > KILLING ADB SERVER (IF RUNNING): OK! 18:17:09 > SEARCHING FOR PHONE: OK! 18:17:10 > READING INFO: OK! 18:17:10 > MODEL: GT-I9100 / GT-I9100 18:17:10 > IMEI: 3553100xxxxxxxxxxxxx 18:17:10 > VERSION: 2.3.3 / GINGERBREAD 18:17:11 > FIRMWARE: GT-I9100-USER / I9100XXKDJ 18:17:11 > KERNEL: 2.6.35.7-I9100XWKE1-CL181974 (gcc 4.4.0) 18:17:11 > CPU TYPE: S5PC210 / ARMv7 18:17:16 > CHECKING ROOT: NOT ROOTED! 18:17:34 > RUNNING TEMP ROOT: OK! 18:17:35 > SEARCHING FOR PHONE: OK! 18:17:41 > CHECKING ROOT: NOT ROOTED! 18:17:41 > PLEASE RESTART PHONE AND TRY AGAIN! 18:17:41 > SAMSUNG GALAXY S2 READ CODES: END! try ten times but still same i think bugs in unlocking |
I've installed latest Kies 2.0 and put phone to debugging mode but System not recognized and not install drivers. Which drivers do I need?? Thanks. |
dixx please post your log WBR, gsm9l;) |
LOG cannot show you any info. Stuck on searching for phone. PHONE NOT FOUND. Device manager show 2 device with missing drivers when I connect phone with usb debugging mode. Kies 2.0 installed. |
how it's recognized in device manager ? WBR, gsm9l;) |
will it work on 2.3.3 with out any sort of already rooted one already patched and other things |
Yes it will work, we're working on it. But for the moment you don't need to patch anything for 2.3.3 only you need to have root already done. WBR, gsm9l;) |
the besy way to unlock galaxy s 2 is via app called "galaxy s 2 unlock sim". from andriod market i have already unlocked couple of pieces its totally safe.as like galaxy s the galaxy s 2 unlock code is also stored in phone.this app will read the code.just put wrong simcard in phone and enter unlocking code...cheers |
Using Micro-Box it's best way to unlock it, so why do you need to buy other things like this simcard. WBR, gsm9l;) |
i have same problem every time soft say PLEASE RESTART PHONE AND TRY AGAIN! how can i unlock it with microbox SAMSUNG I9100 READ CODES: START! 13:35:22 > KILLING ADB SERVER (IF RUNNING): OK! 13:35:22 > SEARCHING FOR PHONE: OK! 13:35:23 > READING INFO: OK! 13:35:23 > MODEL: GT-I9100 / GT-I9100 13:35:23 > IMEI: 35531004080xxxx 13:35:23 > VERSION: 2.3.3 / GINGERBREAD 13:35:23 > FIRMWARE: GT-I9100-USER / I9100BOKD1 13:35:23 > KERNEL: 2.6.35.7-I9100BOKE1-CL176674 (gcc 4.4.0) 13:35:23 > CPU TYPE: S5PC210 / ARMv7 13:35:28 > CHECKING ROOT: NOT ROOTED! 13:35:46 > RUNNING TEMP ROOT: OK! 13:35:46 > SEARCHING FOR PHONE: OK! 13:35:52 > CHECKING ROOT: NOT ROOTED! 13:35:52 > PLEASE RESTART PHONE AND TRY AGAIN! 13:35:52 > SAMSUNG I9100 READ CODES: END! thanks |
You have 2.3.3 version for this you have to root the phone first then Read codes process will work. WBR, gsm9l;) |
thanks how can i root this phone |
can you tell me the procedure to Root the phone thanks |
