09-26-2008, 15:32 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: SL3;HTC DesireHD DIRECT UNLOCk Age: 44
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | help for unlok my330v Connecting to server: Ok! Asking server for access: Accepted! Getting credit data from server: Ok! Credit used: 13 credit limit: 25 searching for phone: Found! Reading firmware info: Ok! Reading hash table info: Ok! Reading imei: Ok! Reading model info: Ok! Press power: Ok! Reading cpu info: Ok! Loading certificate: Ok! loading application: Error 1002! sagem my332v read codes: End! |
09-26-2008, 18:00 | #2 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | use prolific cable , will solve your problem and when soft ask you to remove battery and put it again and press power on , do it after 6% on soft |
09-27-2008, 06:55 | #5 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | yes there is no such phone from sagem available phones are my300x, my301x, my302x, my300c @adelgsm can u post phone pic here or link for this phone? |
09-27-2008, 07:43 | #6 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Pakistan Age: 36
Member: 300354 Status: Offline Sonork: 100.1577485 Thanks Meter: 760 | If Phone Detects then sure it,s supported... There is Some Communication problem you have to use prolific cable to avoid these errors... On RJ-45 you,ll get some problems.. |
09-27-2008, 14:40 | #7 (permalink) |
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | I am sure it is sagem my 330v swisscom phone info MODEL : VF526 IMEI : 35973xxxxxxxxxxx FIRMW. : EVN,HP: 190808 1015 HT. : 012205 CPU : LOCOSTO HS pliz help |
09-27-2008, 15:34 | #9 (permalink) |
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | same problem SAGEM VDF526 READ CODES: START! CONNECTING TO SERVER: OK! ASKING SERVER FOR ACCESS: ACCEPTED! GETTING CREDIT DATA FROM SERVER: OK! CREDIT USED: 13 CREDIT LIMIT: 25 SEARCHING FOR PHONE: FOUND! READING FIRMWARE INFO: OK! READING HASH TABLE INFO: OK! READING IMEI: OK! READING MODEL INFO: OK! PRESS POWER: OK! READING CPU INFO: OK! LOADING CERTIFICATE: OK! LOADING APPLICATION: ERROR 1002! SAGEM VDF526 READ CODES: END! |
09-28-2008, 06:25 | #11 (permalink) | |
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | Quote:
The Following User Says Thank You to shahzaadbutt For This Useful Post: |
09-28-2008, 12:45 | #12 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Tunisia Age: 43
Member: 40632 Status: Offline Sonork: 98231 Thanks Meter: 1,658 | Quote:
The Following User Says Thank You to midou01 For This Useful Post: |
11-27-2008, 09:40 | #13 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Midle of the Earth
Member: 575851 Status: Offline Thanks Meter: 544 | Quote:
http://forum.gsmhosting.com/vbb/show...ghlight=my330v | |
help for unlok 9500 | adelgsm | BlackBerry (RIM) | 3 | 02-11-2009 23:03 |
i need help for unloking se j132 | BIJOU8420 | SETool2 | 1 | 01-24-2009 20:25 |
help help for unlok v630i cid 49 | adelgsm | SETool2 | 5 | 06-22-2008 07:53 |
help for unloking of lg 8120 | saily | Cruiser Suite | 0 | 06-15-2005 06:19 |
