11-29-2014, 11:39 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Spain, Barcelona Age: 46
Member: 124648 Status: Offline Thanks Meter: 21 | How to make factory unlock with MicroBox (black box version) [Answered] I put *#7284# then the software is seraching but nothing happends. I have to try i9300 and i9505 The box the cable With this two items are possible or it's impossible to unlock nothing? |
11-29-2014, 17:00 | #4 (permalink) | ||
Member: 124648 Status: Offline Thanks Meter: 21 | I don't understand nothing.... Now I unlocked 2 phones Quote:
12-02-2014, 20:57 | #5 (permalink) |
Member: 124648 Status: Offline Thanks Meter: 21 | Hello again, is possible that only reading codes from phone may cause any damage to the phone? Because now the phone isn't registered on network. Shows conditional access and ends the call. I tested on 3 networs from 3 different operators. The problematic phone is the i9505. thanks. |
12-03-2014, 01:03 | #6 (permalink) |
Member: 124648 Status: Offline Thanks Meter: 21 | Anybody can help me? Conditional call fowarding active (##002# ##062# ##067# NOT WORKING) Maybe bad unlock? The microbox calculated 16:52:32 > MASTER CODE: 57137359 16:52:32 > NET CODE: 03947417 how can I do to input the master code? Before the unlock process, when insert SIMCARD from another company ask for net code, now after type the net code (shows correct) and restart. If I try to unlock direct with factory unlock, cost credits? because the server should to know that this phone was made before? |
12-03-2014, 09:43 | #7 (permalink) |
No Life Poster Join Date: Jan 2001 Location: StarSystem
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | Hello sorry for late replay : 1 - You can use our micro-box as COMPORT - 99% of time is working without problem, if not , then you can use FTDI serial box 2 - your I9505 you can try direct unlock without lose more credits some time phones need one factory reset ( by cable you can also make it ) BR julvir |
12-03-2014, 19:26 | #11 (permalink) |
Member: 124648 Status: Offline Thanks Meter: 21 | Hello, I make the all process again with Factory direct unlock. I reset to factory defaults with microbox and then wipe and format. Only work with original operator. I flashed with PHE 4 files and nothing news. Just only work with the original operator. So what can we do? |
12-03-2014, 21:02 | #12 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: RO, Nasaud
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Quote:
WBR, gsm9l | |
12-04-2014, 00:01 | #13 (permalink) | ||
Member: 124648 Status: Offline Thanks Meter: 21 | LOG from the first day READ CODES FACTORY Quote:
Why cannot read entire imei? only 14 digits. Thanks and wait for the reply | ||
12-04-2014, 00:32 | #14 (permalink) |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Does your phone ask for codes when you put unaccepted sim? If yes enter 00000000 and forgot about IMEI the software read what is needed, last digit is generated from first 14th digits. WBR, gsm9l |
12-04-2014, 00:56 | #15 (permalink) |
Member: 124648 Status: Offline Thanks Meter: 21 | The phone the first time as I write before ask for NET CODE and first time entered 03947417 and accepted and network lock clear (but I have the problem that only can make calls with original company) with others can't make calls and receive. |
