Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Micro-Box Team Products > Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...)
Old 02-14-2009, 21:22   #1 (permalink)
Member: 894650
Thanks Meter: 11
unlock samsung c260 ?[ANSWERED & SOLVED]
how can I unlock samsung c260 with microbox ?
is that pin out unlock ?
pls help me
Old 02-15-2009, 01:08   #2 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
use cable for unlock this phone same as universal or ustpro or spt all use same pinout as microbox
Old 02-15-2009, 11:11   #3 (permalink)
Member: 894650
Thanks Meter: 11
I tried but it is not worked.
can u give the methode for that pls ?
best regards
Old 02-15-2009, 11:56   #4 (permalink)
.::Skylinks::.'s Avatar
Member: 300354
Sonork: 100.1577485
Thanks Meter: 760
best regards
Hello,
Can you Explain Here What error you are Getting? So we can Help you Step Furture..
Old 02-15-2009, 12:24   #5 (permalink)
Member: 894650
Thanks Meter: 11
how must I connect the cable to phone ? with battery or not ? is that pinout system ? pls help me.
best regards
Old 02-15-2009, 12:43   #6 (permalink)
Member: 300354
Sonork: 100.1577485
Thanks Meter: 760
best regards
If you have used Proper cable then you don,t need to use External Power Supply or Battery...
Old 02-15-2009, 12:51   #7 (permalink)
Member: 894650
Thanks Meter: 11
is that pinout system ? I got only cable like pinout .
Old 02-15-2009, 12:56   #8 (permalink)
Member: 300354
Sonork: 100.1577485
Thanks Meter: 760
If phone wont poweron with cable then you can provide external voltage to poweron the phone..
Old 02-15-2009, 12:57   #9 (permalink)
Member: 894650
Thanks Meter: 11
pls can u help me ?
Old 02-15-2009, 12:58   #10 (permalink)
Momo_Gsm's Avatar
Member: 755709
Sonork: 100.1592000 Momo...
Thanks Meter: 6,635
you dont need Battery just plug cable and press power on shortly no hard with this. AND IF YOU WANNA SOLDER IT WILL BE EASY WITH THIS .
Old 02-15-2009, 15:00   #11 (permalink)
Member: 894650
Thanks Meter: 11
I tried azs explained but there is no result.
pls help me
Old 02-15-2009, 15:29   #12 (permalink)
Member: 894650
Thanks Meter: 11
pls help me
I trird as you explained but not worked.
SAMSUNG C260 UNLOCK: START!
ACTIVATING TEST MODE: ERROR!
SAMSUNG C260 UNLOCK: END!
pls help me
Old 02-16-2009, 13:24   #13 (permalink)
Member: 300354
Sonork: 100.1577485
Thanks Meter: 760
That is Cable Problem... Make Sure You are Connecting Properly.
Either PHone is Powering on with That cable? Phone should be On for that operation
Old 02-17-2009, 12:20   #14 (permalink)
Member: 894650
Thanks Meter: 11
thank you for your reply.
normaly to connect the cable to phone, I must remove the batteray.
so how can I on the phone ?
how can I provide external voltage to power on the phone ?
pls can u help me ?
Old 02-17-2009, 13:10   #15 (permalink)
free1600's Avatar
Member: 467911
Thanks Meter: 351
what other box you have because I don't have Micro-Box and don't know to explain procedure with
but if you have cable com or beter look to picture and you understand for build the cable
now you can build your cable you need to know the pinouts for your box where
is your vpp tx rx gnd for rj45 and build it; you don't need battery to phone when you feed with vpp!!
br,
free1600
Samsung B3310[ANSWERED & SOLVED] boyette Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2 04-16-2010 15:59
Samsung S3650[ANSWERED & SOLVED] danrachita Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 10 03-31-2010 10:45
unlock KU 580 ?[ANSWERED & SOLVED] dance2009 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 5 03-15-2010 18:05
Samsung E2120[ANSWERED & SOLVED] whereruuk Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 7 03-05-2010 13:15
unlock sfr112 noir[ANSWERED & SOLVED] yasser07 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 1 01-22-2010 16:47
Page generated in 0.23797 seconds with 10 queries
