10-04-2016, 13:49 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: everywhere
Member: 159105 Status: Offline Thanks Meter: 60 | i cant unlock vodafone 533 13:39:39 > Connecting to server: OK! 13:39:40 > Asking server for access: OK! 13:39:40 > Disconnecting from server: OK! 13:39:40 > USING: MICRO-BOX A.I.O. NEW V4.0.0.7 13:39:40 > MICRO-BOX SN: 41CC0FCD7CA1C5DE FW: 75/50 13:39:40 > PORT: MICRO-BOX - 115200 13:39:40 > Sagem VF533 READ UNLOCK CODE(S): START! 13:40:10 > Searching for phone: OK! 13:40:10 > Reading firmware info: OK! 13:40:10 > Reading hash table info: OK! 13:40:10 > Reading imei: OK! 13:40:11 > Reading model info: OK! 13:40:11 > MODEL: VF533 13:40:11 > IMEI: 358745030456030 13:40:11 > FIRMWARE: EVN,ZO: 190809 1029 13:40:11 > HASHTABLE: A62107 13:40:21 > Please disconnect phone from cable: OK! 13:40:21 > Please follow the next steps: 13:40:21 > 1. Power OFF phone 13:40:21 > 2. Remove battery from phone 13:40:21 > 3. Connect cable to phone 13:40:21 > 4. Put battery to phone 13:40:30 > Press power ON: OK! 13:40:30 > Reading cpu info: OK! 13:40:30 > CPU: LOCOSTO HS 13:40:39 > Sending loader: ERROR! [ SEND2 ] 13:40:39 > Sagem VF533 READ UNLOCK CODE(S): END! |
10-04-2016, 14:02 | #2 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Try other time with Single Sagem Sw, and do these steps carefully: Quote:
BR | |
10-04-2016, 15:52 | #3 (permalink) | |
Member: 159105 Status: Offline Thanks Meter: 60 | Quote:
15:50:31 > Connecting to server: OK! 15:50:41 > Asking server for access: OK! 15:50:41 > Disconnecting from server: OK! 15:50:41 > USING: MICRO-BOX A.I.O. NEW V4.0.0.7 15:50:41 > MICRO-BOX SN: 41CC0FCD7CA1C5DE FW: 75/50 15:50:41 > PORT: MICRO-BOX - 115200 15:50:41 > Sagem VF533 READ UNLOCK CODE(S): START! 15:50:53 > Searching for phone: OK! 15:50:53 > Reading firmware info: OK! 15:50:53 > Reading hash table info: OK! 15:50:53 > Reading imei: OK! 15:50:53 > Reading model info: OK! 15:50:54 > MODEL: VF533 15:50:54 > IMEI: 358745030456030 15:50:54 > FIRMWARE: EVN,ZO: 190809 1029 15:50:54 > HASHTABLE: A62107 15:50:57 > Please disconnect phone from cable: OK! 15:50:57 > Please follow the next steps: 15:50:57 > 1. Power OFF phone 15:50:57 > 2. Remove battery from phone 15:50:57 > 3. Connect cable to phone 15:50:57 > 4. Put battery to phone 15:51:25 > Press power ON: OK! 15:51:25 > Reading cpu info: OK! 15:51:25 > CPU: LOCOSTO HS 15:51:34 > Sending loader: ERROR! [ SEND2 ] 15:51:34 > Sagem VF533 READ UNLOCK CODE(S): END! | |
10-10-2016, 09:31 | #6 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Just aswered above about this issue, and not post all days, for our team is important help and solve Customer issue as soon possible...so please be pacient. Br |
11-26-2016, 17:03 | #11 (permalink) |
Member: 159105 Status: Offline Thanks Meter: 60 | in new version 4.0.1.0 u have bug i try to unlock alcatel 1010x with it and hi is tel me is unsupported and with old is working perfectly with new version 4.0.1.0 Alcatel IMEI:865450024216187 Dev Type:Phone ProviderId:1010X-2AM3DZ3 UNSUPPORTED PROVIDER ID 16:32:34 > Alcatel OT-1010X CALCULATE CODE(S): START! 16:32:34 > MODEL: Alcatel OT-1010X 16:32:34 > IMEI: 865450024216187 16:32:34 > PROVIDER: 2AM3DZ3 16:32:35 > Checking server 1: OK! 16:32:36 > Connecting to server: OK! 16:32:42 > Asking server for access: OK! 16:32:43 > Sending data to server: OK! 16:32:54 > Receiving data from server: OK! [ NOT_SUPPORTED ] 16:32:55 > Disconnecting from server: OK! 16:32:55 > Alcatel OT-1010X CALCULATE CODE(S): END! and this is with old version 4.0.0.8 16:58:18 > MODEL: Alcatel OT-1010X 16:58:18 > IMEI: 865450024216187 16:58:18 > PROVIDER: 2AM3DZ3 16:58:18 > NCK: 29878409-29 16:58:18 > NSCK: 13431857-57 16:58:18 > SPCK: 01842317-88 16:58:18 > CPCK/SIM: 13165828-02 16:58:18 > CCK: 01619495-93 16:58:18 > PCK: 21676917-64 16:58:18 > TYPE ###765*08# or *#*#3646633#*#* for enter in UNLOCK MENU! 16:58:18 > SELECT "UNLOCK PIN" or "UNLOCK CODE" and enter CODE! 16:58:18 > IF CODE NOT ACCEPTED PLEASE FULL RESET PHONE or CLEAR eMMC AND TRY AGAIN! 16:58:18 > FULL RESET: PHONE OFF, press [#]+[POWER] or [VOL UP]+[POWER]! 16:58:18 > CLEAR eMMC: PHONE OFF, press [VOL DOWN]+[POWER], select CLEAR EMMC, press [HOME]! 16:58:18 > Disconnecting from server: OK! 16:58:18 > Alcatel OT-1010X CALCULATE CODE(S): END! |
11-26-2016, 17:33 | #12 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, we haven't only 100 model of Alcatel, but our Box and Sw is Multibrand, it means that we cannot leave more of 2000 model of various Brand and Model for life. Is obvius that we remove some old model for replace with New model, for this we get always New Update, anyway BUG have from you Side, Loock what you say Not work: Are you understand that problem is from you side? Br allumts |
11-27-2016, 16:28 | #13 (permalink) |
Member: 159105 Status: Offline Thanks Meter: 60 | same probleme with battery full charged 16:23:44 > SYNC WITH SERVER: START! 16:23:44 > Reading ACTIVATIONS: OK! 16:23:45 > Checking server 1: OK! 16:23:46 > Connecting to server: OK! 16:23:49 > Asking server for access: OK! 16:23:50 > Getting activations from server: OK! 16:23:52 > Getting credit from server: OK! 16:23:54 > Getting support period from server: OK! 16:23:54 > MICRO-BOX INFO: 16:23:54 > SERIAL NUMBER: 41CC0FCD7CA1C5DE 16:23:54 > VERSION: 75 16:23:54 > BOOT VERSION: 50 16:23:54 > SUPPORT: 16:23:54 > VALID UNTIL: 2017-06-01 16:23:54 > ACTIVATIONS IN SERVER: 16:23:54 > ALCATEL: YES 16:23:54 > BLACKBERRY: YES 16:23:54 > HTC: YES 16:23:54 > LG: YES 16:23:54 > SAGEM: YES 16:23:54 > MEP0: NO 16:23:54 > 1_YEAR_FULL: NO 16:23:54 > ACTIVATIONS: 16:23:54 > ALCATEL: YES 16:23:54 > BLACKBERRY: YES 16:23:54 > HTC: YES 16:23:54 > LG: YES 16:23:54 > SAGEM: YES 16:23:55 > MEP0: NO 16:23:55 > 1_YEAR_FULL: NO 16:23:55 > CREDIT: 16:23:55 > USED: 10,00 16:23:55 > LIMIT: 10,00 16:23:55 > CREDIT SPECIAL: 16:23:55 > USED: 0 16:23:55 > LIMIT: 0 16:23:55 > Disconnecting from server: OK! 16:23:55 > SYNC WITH SERVER: END! 16:24:17 > Checking server 1: OK! 16:24:17 > Connecting to server: OK! 16:24:20 > Asking server for access: OK! 16:24:20 > Disconnecting from server: OK! 16:24:20 > USING: MICRO-BOX A.I.O. NEW V4.0.1.0 16:24:20 > MICRO-BOX SN: 41CC0FCD7CA1C5DE FW: 75/50 16:24:20 > PORT: COM8 - 115200 16:24:20 > Vodafone 533 READ UNLOCK CODE(S): START! 16:24:24 > Searching for phone: OK! 16:24:24 > Reading firmware info: OK! 16:24:24 > Reading hash table info: OK! 16:24:25 > Reading imei: OK! 16:24:25 > Reading model info: OK! 16:24:25 > MODEL: VF533 16:24:25 > IMEI: 358745030456030 16:24:25 > FIRMWARE: EVN,ZO: 190809 1029 16:24:25 > HASHTABLE: A62107 16:24:29 > Please disconnect phone from cable: OK! 16:24:29 > Please follow the next steps: 16:24:29 > 1. Power OFF phone 16:24:29 > 2. Remove battery from phone 16:24:29 > 3. Connect cable to phone 16:24:29 > 4. Put battery to phone 16:25:19 > Press power ON: OK! 16:25:19 > Reading cpu info: OK! 16:25:19 > CPU: LOCOSTO HS 16:25:28 > Sending loader: ERROR! [ SEND2 ] 16:25:28 > Vodafone 533 READ UNLOCK CODE(S): END! 16:25:34 > Checking server 1: OK! 16:25:35 > Connecting to server: OK! 16:25:36 > Asking server for access: OK! 16:25:36 > Disconnecting from server: OK! 16:25:37 > USING: MICRO-BOX A.I.O. NEW V4.0.1.0 16:25:37 > MICRO-BOX SN: 41CC0FCD7CA1C5DE FW: 75/50 16:25:37 > PORT: COM8 - 115200 16:25:37 > Vodafone 533 READ UNLOCK CODE(S): START! 16:25:55 > Searching for phone: OK! 16:25:55 > Reading firmware info: OK! 16:25:56 > Reading hash table info: OK! 16:25:56 > Reading imei: OK! 16:25:56 > Reading model info: OK! 16:25:56 > MODEL: VF533 16:25:56 > IMEI: 358745030456030 16:25:56 > FIRMWARE: EVN,ZO: 190809 1029 16:25:56 > HASHTABLE: A62107 16:26:00 > Please disconnect phone from cable: OK! 16:26:00 > Please follow the next steps: 16:26:00 > 1. Power OFF phone 16:26:00 > 2. Remove battery from phone 16:26:00 > 3. Connect cable to phone 16:26:00 > 4. Put battery to phone 16:26:52 > Press power ON: OK! 16:26:53 > Reading cpu info: OK! 16:26:53 > CPU: LOCOSTO HS 16:27:01 > Sending loader: ERROR! [ SEND2 ] 16:27:01 > Vodafone 533 READ UNLOCK CODE(S): END! |
11-28-2016, 14:45 | #14 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, Not post 2 problem in same thread. Our Sw get out only "Factory Code", if this phone have "Customizzed Fw" from operator or you, is normal that cannot "Read Codes"....get one try with "Direct Unlock" and post result BR |
