04-16-2011, 13:50 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RO, Nasaud
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Hi, 1. You need to use E210 Combo Cable 2. Phone ON 3. Install Samsung S3650 drivers 4. Select proper comport in lates Micro-Box AIO 5. Read codes Click on desired video from here for seeing how to: http://forum.gsmhosting.com/vbb/f447...ideos-1246834/ WBR, gsm9l |
04-16-2011, 13:54 | #4 (permalink) |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | The comport of your samsung S3650 not other comport ... let's say blackberry comport or anything else. ... see the video your phone it's in the video list ... you should see it will help you a lot to understand. WBR, gsm9l |
04-16-2011, 14:03 | #6 (permalink) |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | You must install the drivers first. http://org.downloadcenter.samsung.co....1.10064_2.exe Install this, Connect the phone then read codes. WBR, gsm9l |
04-17-2011, 05:25 | #10 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1171959 Status: Offline Thanks Meter: 6 | Version micro-box a.i.o v1.0.8.9 samsung s3650 read code start reading model ok reading imei ok reading version ok reading hardware info ok reading extended info ok switching to download mode error 1004 (wat..happend..for..this) |
04-17-2011, 10:30 | #11 (permalink) |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | your phone should be powered on then you select read codes - right? What happen with your phone when the software tells you switching to download mode ? Is it going to BOOTLOADER with yellow color on phone or just simple restart ? WBR, gsm9l |
04-17-2011, 10:36 | #12 (permalink) |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | You must see this video also: YouTube - Samsung S3650 Read Codes with Micro-Box - www.micro-box.com |
04-17-2011, 11:01 | #15 (permalink) |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | here you have the picture of cable, you must plug in all sockets, in phone, in box rj45 and in computer usb too. When the software tells you to switch the phone in download mode, if not enter just unplug the connector from phone, remove battery, connect the phone and then plug in the battery. Repeat this until will show bootloader on screen. This happens when the cable has some issues. As you see there are many S3650 Unlocked by Micro-Box without problem. WBR, gsm9l |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
