03-07-2013, 11:29 | #1 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Gsm college
Member: 1610262 Status: Offline Sonork: 100.1608508 Thanks Meter: 44 | How to unlock my210x sagem [Answered] i need the unlocking procedure of my210x how to make cable and which one is rx and which one is tx and do i need to use usb cable too plz tell me step by step how to unlock thnx in advanced |
03-07-2013, 12:58 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RO, Nasaud
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Here is pinout you have to solder on the board: Micro-Box use Universal Pinout so: Pin Signal Description 1 +5V Switchable 5V Flash Supply 2 TX output, data to phone 3 RX input, data from phone 4 CTS output, data to phone 5 RTS input, data from phone 6 M/C-BUS bi-directional 1 wire bus 7,8 GND Green, After you make all connection, power on the phone, connect it to Micro-Box RJ45, then read codes. WBR, gsm9l |
03-07-2013, 13:29 | #4 (permalink) |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | You need a cable with RJ45 socket in Micro-Box, at port select Micro-Box and the other part of cable must be only wires ... nothing else and connect needed wires on the board as described. WBR, gsm9l |
