12-22-2017, 19:09 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: RABAT Age: 49
Member: 153848 Status: Offline Thanks Meter: 25 | loading data and modeles error [Answered] i have probleme with micro box when i open the programme i have 2 error the first is open data error and second open modeles error any one have any idea to fix this probleme thanks |
12-23-2017, 21:19 | #3 (permalink) |
Member: 153848 Status: Offline Thanks Meter: 25 | 21:18:47 > Loading data: ERROR! 21:18:54 > NEW VERSIONS FOUND IN SUPPORT: 21:18:54 > MB HTC PRO CABLE 2 SOFTWARE: v1.0.0.7 21:18:54 > MICRO-BOX Alcatel (single): v1.0.2.6 21:18:54 > MICRO-BOX BlackBerry (single): v1.0.0.3 21:18:54 > MICRO-BOX Dongle/Box Drivers: v1.3.0.0 21:18:54 > MICRO-BOX HTC (single): v1.0.0.6 21:18:54 > MICRO-BOX Huawei (single): v1.0.0.0 21:18:54 > MICRO-BOX Imei (single): v1.0.1.5 21:18:54 > MICRO-BOX MTK (single): v1.0.0.1 21:18:54 > MICRO-BOX Nokia (single): v1.0.0.1 21:18:54 > MICRO-BOX Samsung (single): v2.0.0.2 21:18:54 > MICRO-BOX SE FLASHER: v1.1.5.0 21:18:54 > Please press <CHECK FOR UPDATE> button for download new versions! 21:19:01 > Loading data: ERROR! 21:19:02 > Loading models: ERROR! |
12-24-2017, 15:58 | #4 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | - Use Last AIO version. - Ceck carefully you drivers istalled, need these: Quote:
- Press "SYNC WITH SERVER" button. Anyway, if not load Data and Models it's DRIVER ISSUE, try installing Manually, post result | |
The Following User Says Thank You to allumts For This Useful Post: |
12-24-2017, 17:13 | #6 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | From here and issue showed can be only DRIVERS problem. Try to installing MANUALLY these drivers V3 using Last AIO version...i'm sure you can solve by yourself. If not, when finish Christmas holyday we can try by TV. P.D. If have installed programs like "USB OVER NET" or any sharing port program, UNINSTALL these, reboot pc and ceck, Micro-Box NOT Allowed "USB SHARING PORT" program!!!! BR |
