12-14-2010, 11:12 | #1 (permalink) |
Freak Poster Join Date: Aug 2004
Member: 78088 Status: Offline Thanks Meter: 4 | Htc desire urgent help Can anyone tell me how i can sort this out please??? Thanks in advance |
12-14-2010, 15:18 | #3 (permalink) |
Junior Member Join Date: Oct 2010 Location: wolverhampton
Member: 1428485 Status: Offline Sonork: 100.1596801 Thanks Meter: 1 | I successfully flashed mine desire with following rom, if u want u can try this. RapidShare AG, Cham, Switzerland Thank you |
12-14-2010, 17:46 | #5 (permalink) |
Member: 1428485 Status: Offline Sonork: 100.1596801 Thanks Meter: 1 | Steps: copy the rom zip file in memory card and insert into phone. Take out battery and insert again. Hold vol Down button and press power button. phone will boot in recovery mode. select recovery, now phone will reboot in recovery. select install zip from sd card, then select zip file to install. Select the rom file from the list of files in the card. make sure the phone is charged properly. It will take some time.; after it's finished reboot the phone. Phone should work fine. good luck |
12-16-2010, 10:34 | #9 (permalink) |
Member: 1428485 Status: Offline Sonork: 100.1596801 Thanks Meter: 1 | try to get an original rom from htc and than install that rom with same procedure. if u can't find from htc then google it and keep on try until u can't find the compatible rom for your phone. Thats what i did when i had same problem. |
12-20-2010, 13:59 | #10 (permalink) |
Member: 78088 Status: Offline Thanks Meter: 4 | After many wasted hours I found a little piece of software that sorted my problem out in 20mins. It was a gold card creator. Used the prog to make the cad in 30 secs added the required rom. Booted to hboot and rom installed and all working fine. I used a code to unlock as it was safer and 100 times easier. Thanks for all the pointers guys. Got there in the end..... If anyone want the gold card prog pm me. |
The Following User Says Thank You to mobilewiz For This Useful Post: |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
