01-16-2010, 19:46 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Bangladesh Age: 42
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | Huawei E22o Modem unlock problem with Micro box. But everytime it shows error. Modem imei is 358192010633660. Need help. Hope product supporter ill help me on this issue. |
01-16-2010, 21:14 | #2 (permalink) |
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | Just Now i have solved my problem with another way. My modem is unlock now. many many thanks to SeeJay. I share it for u. hope this instructions ill help u. Plug your modem to the computer and run the E220 Updater. Wait till it detects your modem and then press the "Cancel" button. yes! Cancel it! This is just to make it easier for the "real tool" to identify the modem. [IMG]http://2.bp.********.com/_1p_XL5baLts/SZayBlGTmiI/AAAAAAAAABQ/tO_SX19yqgU/s400/e220Update.JPG[/IMG] Now open the QC BQS Analyzer and click on Hardware forensics menu, select Use Com/USB Port [IMG]http://1.bp.********.com/_1p_XL5baLts/SZa1HIngIDI/AAAAAAAAABg/1J_NmRkj4aA/s400/QCMob-1.JPG[/IMG] Now the "QC Com Diag" window should be open. Most of the time your modem and com port is automatically selected on the Serial Com port drop down list. If not you'll have to select it manually. And then click on the "Send Cmd" button and wait till the message "Successfully sent command" appears on the bottom right. [IMG]http://1.bp.********.com/_1p_XL5baLts/SZa5vdxP8cI/AAAAAAAAABo/9F20lZRaPUA/s400/QCMob-2.JPG[/IMG] |
The Following User Says Thank You to sanjoychy For This Useful Post: |
01-16-2010, 21:17 | #3 (permalink) |
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | Now Select " Read EFS" from the Diag Functions drop down menu and Click the "Lets go" button. When it asks, enter the file name e220.bin and save it. A message saying "Successfully read EFS" should appear. [IMG]http://4.bp.********.com/_1p_XL5baLts/SZa9Chr5HII/AAAAAAAAABw/JxxrnZe12bw/s400/QCMob-3.JPG[/IMG] Now its time to do some hex reading Open the e220.bin file from your Hex Editor. And search for the ASCII string Sd, (including the comma) or Search for the for the Hex string 53 64 2c After few random characters you'll see a clean 8 digit code. Believe me, it's easily recognizable and guess what! thats our Unlock code [IMG]http://2.bp.********.com/_1p_XL5baLts/SZbJGQYkbmI/AAAAAAAAAB4/t4dy9o1D2Uk/s400/Hex.JPG[/IMG]Once you've found the unlock key all you have to do is enter it on the CardLock Unlock utility and click "OK" And your modem is... Unlocked!!! Plz download the soft from below location http://www.4shared.com/file/19876816...0_Unlock_.html |
The Following 2 Users Say Thank You to sanjoychy For This Useful Post: |
01-17-2010, 06:31 | #4 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | HI, Thankx for this step by Step Info mostly For modem Unlock ..Simply Connect If CD Comes with it Install Drivers only ... And it can be FOund easily by Device manager others ETC i unlocked many ..I thing the process u Describe is one of the Rare Case.. thankx for INFO Again |
05-07-2010, 02:10 | #5 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: UK
Member: 362955 Status: Offline Thanks Meter: 61 | Quote:
Hi, Where is QC BQS Analyzer software. Thanks | |
Huawei E220 USB MODEM UNLOCK PROBLEM | alfox | FuriousGold | 7 | 08-15-2011 22:28 |
Huawei HSDPA Modems unlocker | TUR@N ALAM | CDMA Modems , Routers , Aircard | 7 | 10-24-2010 08:05 |
Huawei k3765 modem unlock report | Proxy | Z3X-Team Products | 2 | 10-07-2010 12:09 |
Huawei E272 Modem Unlock | roxrox | FuriousGold | 1 | 01-04-2010 12:33 |
huawei e160 modem firmware problem | laggyluk | KULANKENDI Server | 1 | 02-17-2009 17:09 |
