Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Micro-Box Team Products > Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...)
Old 05-29-2009, 10:11   #1 (permalink)
Service4Gsm.de's Avatar
Member: 811992
Sonork: 100.1584257
Thanks Meter: 162
I have problems with UNLOCK of Sagem my421z!
VERSION MICRO-BOX SAGEM V1.0.2.6
SAGEM MY421Z UNLOCK: START!
CONNECTING TO SERVER: OK!
ASKING SERVER FOR ACCESS: ACCEPTED!
GETTING CREDIT DATA FROM SERVER: OK!
CREDIT USED: 20
CREDIT LIMIT: 40
SEARCHING FOR PHONE: NOT FOUND!
SAGEM MY421Z UNLOCK: END!
Old 05-29-2009, 11:11   #2 (permalink)
yasminato's Avatar
Member: 558412
Thanks Meter: 117
SEARCHING FOR PHONE: NOT FOUND!: this is yur prb . so check cable and phone should be on
Old 05-29-2009, 13:36   #3 (permalink)
Member: 772283
Thanks Meter: 4
phone should be on
Old 05-29-2009, 13:40   #4 (permalink)
Member: 772283
Thanks Meter: 4
START TIME: 14:51:13
VERSION MICRO-BOX SAGEM V1.0.2.5
SAGEM MY421Z READ CODES: START!
CREDIT USED: 5
CREDIT LIMIT: 20
SEARCHING FOR PHONE: FOUND!
READING FIRMWARE INFO: OK!
READING HASH TABLE INFO: OK!
READING IMEI: OK!
READING MODEL INFO: OK!
PRESS POWER: OK!
READING CPU INFO: OK!
SENDING LOADER: ERROR 1002!
SAGEM MY421Z READ CODES: END!
what is problem?
Old 05-29-2009, 15:00   #5 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
CREDIT USED: 5
CREDIT LIMIT: 20
READING IMEI: OK!
PRESS POWER: OK!
what is problem?
plz use speed 115200 and for 421z phone 100% tested plz take lock her :
http://www.micro-box.com/tutorials.php
Old 05-29-2009, 21:34   #6 (permalink)
Member: 811992
Sonork: 100.1584257
Thanks Meter: 162
The customer did not have that mobile phone worn therefore went that not however nevertheless to thanks! It does not last badly whom with was that is indicated on on or out! With some that indicated however with many models not!
Old 05-29-2009, 23:12   #7 (permalink)
Member: 672823
Thanks Meter: 6
SEARCHING FOR PHONE: NOT FOUND!: this is yur prb . so check cable and phone should be on :
that its not your problem its problem to fac version
Old 06-10-2009, 06:44   #8 (permalink)
sakabeloha's Avatar
Member: 32403
Thanks Meter: 139
Version micro-box sagem v1.0.2.6
sagem mye77 read codes: Start!
Connecting to server: Ok!
Asking server for access: Accepted!
Getting credit data from server: Ok!
Credit used: 2
credit limit: 11
searching for phone: Found!
Reading firmware info: Ok!
Reading hash table info: Ok!
Reading imei: Ok!
Reading model info: Ok!
Press power: Ok!
Reading cpu info: Ok!
Sending loader: Error 1002!
Sagem mye77 read codes: End!
Old 06-25-2009, 17:47   #9 (permalink)
LABOSSEF's Avatar
Member: 183958
Sonork: 719191000d
Thanks Meter: 523
and me same problem searching for phone not found what is probleme i tink it is not problem cable i have a good cable i unlocked many phone with this
Old 06-25-2009, 18:05   #10 (permalink)
HT Elektronika's Avatar
Member: 13159
Thanks Meter: 14
you have new cpu II. open phone and check cpu.
Old 06-26-2009, 11:53   #11 (permalink)
LABOSSEF's Avatar
Member: 183958
Sonork: 719191000d
Thanks Meter: 523
yes sir it is true new cpu2 but phone is unlocked with other box
Old 06-27-2009, 07:40   #12 (permalink)
.::Skylinks::.'s Avatar
Member: 300354
Sonork: 100.1577485
Thanks Meter: 760
No Box Can Unlock MCU version II With Simple Cable...
have prob with unlocking of KP-500. morya VygisToolbox 4 04-30-2009 12:10
I have problem with download of pspgsm johansel FuriousGold 0 10-23-2007 16:30
i have problem with unlock 5200 end 5300 with mt-pro nio MT-BOX 1 09-17-2007 22:39
i have problem with unlock w850 cid 52 after 48 hours plz help ub team rajabrotherscom Universalbox 7 07-03-2007 12:02
i have problem with unlock k608i i try with version 7.10 gsm4libya Cruiser Suite 9 12-12-2005 10:23
Page generated in 0.24862 seconds with 9 queries
