09-27-2011, 16:38 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: ghardimaou TUNISIA
Member: 864442 Status: Offline Thanks Meter: 49 | A.I.O. V2.0.3.2 ( s5230 ) [Solved] 11:17:59 > CALCULATING [BY SERVER] PLEASE WAIT: ERROR 1003!! 11:17:59 > DISCONNECTING FROM SERVER: OK! ok with A.I.O. V2.0.2.3 SAMSUNG S5230 READ CODES: START! 11:19:59 > READING MODEL: 11:19:59 > READING MODEL: OK! 11:19:59 > READING IMEI: 11:19:59 > READING IMEI: OK! 11:19:59 > READING VERSION: 11:19:59 > READING VERSION: OK! 11:19:59 > READING HARDWARE INFO: 11:20:00 > READING HARDWARE INFO: OK! 11:20:00 > READING EXTENDED INFO: 11:20:03 > READING EXTENDED INFO: OK! 11:20:03 > SWITCHING TO DOWNLOAD MODE: 11:20:04 > SWITCHING TO DOWNLOAD MODE: OK! 11:20:06 > READING FLASH ID: 11:20:06 > READING FLASH ID: OK! 11:20:06 > SETTING SPEED TO 115200: 11:20:06 > SETTING SPEED TO 115200: OK! 11:20:06 > MODEL: GT-S5230N 11:20:06 > IMEI: 357136031514426 11:20:06 > COUNTRY CODE: FTM 11:20:06 > VERSION: SS_21331_Platform_SW_Release_SI1.3.10_V5.0 11:20:06 > FIRMWARE: S5230NBVKA1 11:20:06 > HARDWARE: MP0.400 11:20:06 > MSL ADDRESS: R2EB766556 11:20:06 > PHONE SN: 76200001250810 11:20:06 > BT ADDR: 00 07 AB 6A F4 44 11:20:07 > DATE: 2011-10-11 11:20:07 > MEMORY ID: ECBA 11:20:07 > K522H1HACA(S5230N) 11:20:07 > READING DATA: 11:20:10 > READING DATA: OK! 11:21:34 > CHECKING SERVER 1: 11:21:34 > CHECKING SERVER 1: OK! 11:21:34 > CONNECTING TO SERVER: 11:21:34 > CONNECTING TO SERVER: OK! 11:21:34 > ASKING SERVER FOR ACCESS: 11:21:35 > ASKING SERVER FOR ACCESS: ACCEPTED! 11:21:36 > SENDING DATA TO SERVER: 11:21:36 > SENDING DATA TO SERVER: OK! 11:21:36 > CALCULATING [BY SERVER] PLEASE WAIT: 11:21:45 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 11:21:46 > FREEZE CODE: 49790314 11:21:46 > NET CODE: 63962908 11:21:46 > SP CODE: 00000000 11:21:46 > CP CODE: 00000000 11:21:46 > SIM CODE: 00000000 11:21:46 > DISCONNECTING FROM SERVER: OK! |
09-27-2011, 16:47 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RO, Nasaud
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Nothing here You just lost the connection with the server / phone in unlocking procedure, and by coincidence you try an older version and now you didn't loose the connection. If this will happen again just retry. WBR, gsm9l |
09-27-2011, 16:50 | #3 (permalink) | |
Member: 864442 Status: Offline Thanks Meter: 49 | Quote:
I TRY AFTER READ CODE SAME PROBLEM | |
09-29-2011, 08:12 | #4 (permalink) |
Member: 864442 Status: Offline Thanks Meter: 49 | no solved same problem with s5750e A.I.O. V2.0.3.2 ok with VERSION MICRO-BOX A.I.O. V2.0.2.3 7:45:33 > SENDING DATA TO SERVER: 07:45:34 > SENDING DATA TO SERVER: OK! 07:45:34 > CALCULATING [BY SERVER] PLEASE WAIT: 07:45:43 > CALCULATING [BY SERVER] PLEASE WAIT: OK! 07:45:43 > FREEZE CODE: 07957285 07:45:43 > NET CODE: 36936095 07:45:43 > SP CODE: 00000000 07:45:43 > CP CODE: 00000000 07:45:43 > SIM CODE: 00000000 07:45:43 > DISCONNECTING FROM SERVER: OK! 07:45:43 > SAMSUNG S5750E READ CODES: END! |
09-29-2011, 08:53 | #5 (permalink) |
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Reinstall your application, Every time you have run for the first time a new AIO your firewall will ask you to make an exception for it - you missed it and it blocks your communication. WBR, gsm9l |
