Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Micro-Box Team Products > Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...)
Old 01-21-2010, 13:55   #1 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
im have one litle problem with blackberry[ANSWERED & SOLVED]
im have activation for blackberry but im cant unlock blackberry 8700v
cant conect phone to soft
15:00:47 > VERSION MICRO-BOX A.I.O. V1.0.1.8
15:00:47 > BLACKBERRY 8700V READ CODES: START!
15:00:48 > CONNECTING TO SERVER: OK!
15:00:48 > ASKING SERVER FOR ACCESS: ACCEPTED!
15:00:49 > CHECKING HTC_BB ACTIVATION: OK!
15:00:49 > HTC_BB: ACTIVATED
15:02:49 > SEARCHING FOR PHONE: TIMEOUT!
15:02:49 > BLACKBERRY 8700V READ CODES: END!
15:02:50 > VERSION MICRO-BOX A.I.O. V1.0.1.8
15:02:50 > BLACKBERRY 8700V READ CODES: START!
15:02:50 > CONNECTING TO SERVER: OK!
15:02:51 > ASKING SERVER FOR ACCESS: ACCEPTED!
15:02:52 > CHECKING HTC_BB ACTIVATION: OK!
15:02:52 > HTC_BB: ACTIVATED
15:02:52 > SEARCHING FOR PHONE:
Old 01-21-2010, 14:08   #2 (permalink)
SOHAIL BASHARAT's Avatar
Member: 748880
Thanks Meter: 1,705
Mr@delchoni
install latest Desktop manager 5.0.1
make sure maybe your phone protect lock .Disable phone lock.
Old 01-21-2010, 14:19   #3 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
thanks for fast suport yes phone lock is activated but i cant see in menu disabled options
Old 01-21-2010, 14:24   #4 (permalink)
Member: 748880
Thanks Meter: 1,705
Give 10 times wrong code it reset and after reset it ask for new password give it new password.
Old 01-21-2010, 14:30   #5 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
im now pasword now is 123456789 but im cant disabled this services from phonemenu keypad locked can make disabled
need to deactivate this lock from phone menu but im cant find where is this in menu
Old 01-21-2010, 14:56   #6 (permalink)
Member: 748880
Thanks Meter: 1,705
go to option >>> security >>>>
click on menu now you have disable option click on and type your correct password.
done test phone now.
Old 01-21-2010, 15:48   #7 (permalink)
tito millo's Avatar
Member: 390642
Sonork: 100.1573430
Thanks Meter: 2,476
You need to deactivate IT Policy in order to disable the passwork in your phone.
U need to to the following steps in order to deactivate it.
-First download the attachment and paste it in C:\Progam files\Research In Motion\Blackberry.
-Make a full erase to your phone
-Then go to Start->Run and type regedit.
-Navigate to HKEY_Current_Users\Software\Research In Motion\Blackberry\PolicyManager.
-Right clic and create a new string value.
-Rename it to Path, double clic it and paste the following route:
C:\Program files\Research In Motion\Blackberry\policy.bin and acept.
-Open Desktop Manager and conect your BB wait that in Sync with DM and after this IT Policy will be removed and you can disable user code
Br,
Tito Millo
Micro-Box Team
The Following User Says Thank You to tito millo For This Useful Post:
Old 01-22-2010, 08:26   #8 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,696
Hi,
Just to update here instead of this it policy process here use this personally tested one click Solution for Phone Code Removal and It policy Disabling
http://forum.gsmhosting.com/vbb/show...15&postcount=1
it works for all Known BB and its Easy as well
Make sure u have OS under 4.5
Old 01-22-2010, 08:37   #9 (permalink)
Member: 34379
Thanks Meter: 101
8310 dont have sms option in menu
If i do it policy remove procedure its also fixing this isue to?
Old 01-22-2010, 08:59   #10 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
solved after remove it policy hier link for remove that
http://forums.crackberry.com/f3/remo...lackberry-569/
thanks to all for suport
br.
Old 01-22-2010, 15:44   #11 (permalink)
tito millo's Avatar
Member: 390642
Sonork: 100.1573430
Thanks Meter: 2,476
Thanks for you report we are happy that you got your phone unlocked with our software.
Br,
Tito Millo
Micro-Box Team
how to unlock lgGD510 with micro?[ANSWERED & SOLVED] ahmedbarra Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 1 03-06-2010 14:50
Not happy with microbox[ANSWERED & SOLVED] gamesandgrooves Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2 02-03-2010 15:53
plz add imie change option blackberry[ANSWERED & SOLVED] snkhan70 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 5 01-29-2010 16:00
bb 8900 PROBLEM FOE UNLOCK[ANSWERED & SOLVED] iliya _angelov Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 4 01-22-2010 20:26
I have one strange problem with nokia 7650 GazI Nokia Hardware & Hardware Repair 18 01-04-2006 00:51
Page generated in 0.26477 seconds with 10 queries
